Results 16 to 30 of 58
Thread: How do I get more power?
    ontario
    shit it gets complicated when not working on it yourself. if your a novice with little tools and time then get the q-tre or a touring exhaust.
    Jan 2017
    North Lincolnshire, Humberside
    Just looked on racingplanet and I pretty sure my pipe is the next-r?
    ontario
    like if you had a touring exhaust the setup is stock everything....do you want help picking one out?
    ontario
    Quote Originally Posted by JakeMan1 View Post
    OOOKK - next r is a very good choice. dont change the pipe sheesh. let me restart.
    puff puff hmmmmm...brb
    ontario
    get the m fly clutch.....replace the sparkplug and take a picture of the old one and post it here.
    you will want it 70cc with a clutch and vario....have fun with that!
    then it will haul ass pretty good.
    ontario
    might be to much for you unless you got tools...and time.
    is this your daily driver? get a touring exhaust for cheap.....
    ontario
    the narraku big round one maybe....
    Jan 2017
    This is my daily driver yes, however I do not have enough time to work on her as I am currently studying for my gcse exams so not much free time really, would you be able to post a link of the clutch I need please?
    ontario
    its the hardest thing to change.
    need - vise/ pipewrench for the clutch - and you need a vario locking tool and long ratchet or breaker bar to get the belt off. then its done.
    malossi fly clutch sr50 from racingplanet.uk
    ontario
    that will fix a slow take off with a sport pipe
    Jenison, Michigan
    Check your pipe for restrictions.
    There may be one where the silencer attaches to the pipe as well. Grind the weld off and the restrictor will come out. Don't let it fall into the exhaust.
    Your stock clutch will be just fine. Get these.
    http://www.pedparts.co.uk/product/34...ch-springs-set
    Use the white ones.
    Your pipe gives the exact power delivery that my bike has. The sweet spot is 8500 RPM. Get 5 gram rollers. Any brand, but Malossi is preferred. They'll last longer and are about 10. Size 19x15.5. Watch some you tube videos on how to change the clutch springs. It's not that hard of a job but takes a little bit of muscle.
    No special special tools are needed if you use an impact gun to take it apart.
    https://youtu.be/c2XxAMrs4jw
    https://youtu.be/zsvyOCoWahs
    It'll only take a few hours for all of it and there will be a major improvement.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
    Jan 2017
    Quote Originally Posted by 2Strokesforlife View Post
    Use the white ones.
    Thanks I will definitely look into the clutch springs and rollers and I will check my pipe for a restrictor as soon as I get chance!
    Apr 2014
    Northwich
    The only way you can really get your bike any faster while keeping the stock 50cc cylinder is by getting a better exhaust. Changing the Airfilter, variator and clutch does basically nothing when you have 50cc. This shows the comparison of a bunch of exhausts on a standard 50cc- http://www.pedparts.co.uk/c/asset/te...ndard-50cc.png The best choice would be the technigas triops or the Yasuni R. The Yasuni R will give a bit better top speed while the Technigas will give better acceleration. Also why are you against getting a 70cc? Getting a new exhaust costs around the same as a new 70 kit maybe even more for the Yasuni and you will get much more speed from the 70 kit even if it's a basic one. If you are limited for funds pedparts does an Airsal 70cc for 112 which will make a huge difference to power and it'll still be reliable. All you would need is the Kit for 112, a box of Dellorto Stage 6 6mm 60-82 for 15, 6 x stage 6 5.25g 19x15.5 rollers for 8 and a box of Polini clutch springs for 10. Overall this costs 145 while both exhausts cost around 130 and you will still need to get some new jets and rollers so the price would be 153 so it'd cost more than a new kit.
    Black Sr50r 2014
    Current mods
    Stage 6 RT 70
    Stage 6 RT crank
    Flowed engine case
    Stage 6 R 1400 with RT end can
    Stage 6 water pump
    Doppler inner rotor ignition
    Stage 6 R/T shock absorber
    stage 6 v force 3 reed block
    Stage 6 black f1 mirrors
    Stage 6 112mm clutch with Malossi MHR black springs (Much better than the stage 6 springs )
    Stage 6 oversize variator 5.0g rollers
    Stage 6 oversize rear pulley
    Stage 6 oversize belt
    Stage 6 medium torque spring
    Ngk b-e 10.5 spark plug
    BGM boost bottle
    Stage 6 metal inlet manifold
    Stage 6 28mm RT flatside PWK- 122 main jet second clip down
    No airfilter (won't run with one )
    stage 6 1:2.53 gear up kit
    Top speed- fast......
    Next mods
    Mvt Premium inner rotor ignition
    Jan 2017
    The 70 kits cost more for lc engines
    Jan 2017
    Will all those parts you said that would come up to 145 for my ped? The 70 kit, jets rollers and clutch springs?
  1. how to get more power from the rs 125
    By recessionracing in forum 2009 RS125-USA
    Last Post: 07-18-2014, 01:14 PM
  2. How do I get full power from a 78 KW Tuono?
    By Twinpipes in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 08-09-2011, 11:05 AM
  3. how to get more power?
    By 03v60 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 05-11-2009, 01:33 PM
  4. how do you get a good clutch start from 0mph at lights
    By memphisrs50 in forum RS50 Technical
    Last Post: 06-19-2003, 02:58 PM
  5. How do I get to see newer posts?
    By jlb43 in forum Aprilia and Piaggio 500cc
    Last Post: 11-13-2002, 02:26 AM
