Page 4 of 4 FirstFirst ... 234
Results 46 to 58 of 58
Thread: How do I get more power?
  1. #46
    apriliaforum Junkie 2Strokesforlife's Avatar
    Aug 2016
    Jenison, Michigan
    Quote Originally Posted by JakeMan1 View Post
    I don't have a ditech though, I'm not looking to spend loads of time building it and spending loads on it because come September when I'm 17 and I'll be getting a car and taking my car test and hopefully getting a 125! But for the next 8 months a really want to enjoy my 50 without spending a bomb to make it enjoyable, I just thought I could throw a 70 kit straight on it a couple months ago until I got told I would need a new crank and I gave up with the idea because of without funds!
    Sent from my iPhone using Tapatalk
    I know. We're in the carbed section. I just threw the DiTech part in for an example. They're more expensive and complicated to tune with only 2 options for cylinders. At 50cc, yours can be a great and reliable bike that wakes up when the basic mods are done.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 Torque Control MKII 107mm
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
  2. #47
    ontario
    2strokesforlife is a charmer and an asset to the communty! thanks for posting. i think in a way you saved the day. the diatech itself is a great choice on a small motorcycle with cvt.
    --- diploma for engine repair in 2012 --- powder coat painting --- porting and polishing --- custom aluminum parts and machining --- ditech fuel pump service.
    derbi bullet 2006 - piaggio AC - malossi torque driver half - custom GPS dash - TPR 70CC - topperf crank - vl13 reed and spacer- yamaha rt180 kickstand - giannelli shotV4 - phbg 21mm - doppler mesh top venturi filter
    complete wtp volta bmx 2012 - sanko seamless japanese cromoly heat treated and blueprinted frame - 21lbs
    1992 lt250r suzuki quadracer - maier plastics -chromed shearer pipe - chromed works suspension - 220lbs
    previous vehicles - subaru legacy turbo 1991 - mazda mx6 turbo 1990.
    tamiya fighting buggy and sand scorcher
  3. #48
    Apr 2014
    Northwich
    If you're looking for the most bang for you buck go for what i said before, it's all in stock on Pedparts which was an Airsal sport kit for 112, a box of Dellorto Stage 6 6mm 60-82 for 15, 6 x stage 6 5.25g 19x15.5 rollers for 8 and a box of Polini clutch springs for 10 which adds up to 145. For 145 you will struggle to get anything quicker.
    Black Sr50r 2014
    Current mods
    Stage 6 RT 70
    Stage 6 RT crank
    Flowed engine case
    Stage 6 R 1400 with RT end can
    Stage 6 water pump
    Doppler inner rotor ignition
    Stage 6 R/T shock absorber
    stage 6 v force 3 reed block
    Stage 6 black f1 mirrors
    Stage 6 112mm clutch with Malossi MHR black springs (Much better than the stage 6 springs )
    Stage 6 oversize variator 5.0g rollers
    Stage 6 oversize rear pulley
    Stage 6 oversize belt
    Stage 6 medium torque spring
    Ngk b-e 10.5 spark plug
    BGM boost bottle
    Stage 6 metal inlet manifold
    Stage 6 28mm RT flatside PWK- 122 main jet second clip down
    No airfilter (won't run with one )
    stage 6 1:2.53 gear up kit
    Top speed- fast......
    Next mods
    Mvt Premium inner rotor ignition
  4. #49
    Apr 2014
    Northwich
    Actually add 5 to that to get a new small end bearing to be safe- http://www.pedparts.co.uk/product/41...needle-bearing
  5. #50
    Jan 2017
    North Lincolnshire, Humberside
    My bike has done just over 14,000kms so would that mean I need a new crank too?
  6. #51
    ontario
    sounds about right but i thinks snipez is suggesting a new rod bearing at the piston / and put some more miles on it.
    you can do a couple simple tests to check the crank while you have the cylinder off. no sweat.
  7. #52
    Jan 2017
    Quote Originally Posted by TheSnipez View Post
    If my bike has done more than 14,000 kms will I need a new crank?
  8. #53
    Aug 2016
    Jenison, Michigan
    If there's nothing wrong with your crankshaft now, then it should be fine. If it starts to knock or the crankcase bearings go bad, it'll have to get taken apart and replaced. If you have the money for it, replacing the crank at the same time you go to 70cc is a better choice because you can get it all done at one time instead of having to take it all apart again.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Arrow Extreme Pipe
    Malossi VL 13
    Water Trap
    RS 24/10
    Fuelab 535 FPR
  9. #54
    Jan 2017
    So if I can't hear knocking then it's fine? Don't want to go to put the 70 kit on and see the crank needs replacing because then I won't be able to ride
  10. #55
    Aug 2016
    Jenison, Michigan
    I rode all last year with 70cc and a stock crank before I had to replace it. Like I said, even if you do just the basic mods, it'll be a better machine that is reliable. Be careful, once you start adding the mods, you'll want to do more. Lol! It's addictive...
    2009 SR 50 Factory
    Malossi 70cc BBK
    Arrow Extreme Pipe
    Malossi VL 13
    Water Trap
    RS 24/10
    Fuelab 535 FPR
  11. #56
    Jan 2017
    Quote Originally Posted by 2Strokesforlife View Post
    Okay thanks a lot man
  12. #57
    Aug 2016
    Jenison, Michigan
    I'm just saying to start small because even if you do eventually go to 70cc, you'll have to do those mods anyway.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Arrow Extreme Pipe
    Malossi VL 13
    Water Trap
    RS 24/10
    Fuelab 535 FPR
  13. #58
    Apr 2014
    Northwich
    As 2stokesforlife said it is damn addicting XD I've spent a ridiculous amount of money on my bike over the 3 years i've had it. Your stock crank should be fine too with that kit and your exhaust because it isn't revving all that high. My friend has an Aerox which has a weaker crank than the sr with 30000km's on it and he's got a stage 6 racing mk2 and a yasuni c16! He's used it like that for about a year now and the crank is still going strong even though he rags the poor thing. On the other hand though my friends SR with not that many km on it destroyed the cranks big end bearing with just a malossi mhr replica and a stage 6 pro replica exhaust. It's all luck of the draw really whether your crank can take it or not but using good 2 stroke oil and not riding like a maniac definately improves the chances of the crank lasting with a 70.
    Black Sr50r 2014
    Current mods
    Stage 6 RT 70
    Stage 6 RT crank
    Flowed engine case
    Stage 6 water pump
    BGM boost bottle
    Next mods
  1. how to get more power from the rs 125
    By recessionracing in forum 2009 RS125-USA
    Last Post: 07-18-2014, 02:14 PM
  2. How do I get full power from a 78 KW Tuono?
    By Twinpipes in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 08-09-2011, 12:05 PM
  3. how to get more power?
    By 03v60 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 05-11-2009, 02:33 PM
  4. how do you get a good clutch start from 0mph at lights
    By memphisrs50 in forum RS50 Technical
    Last Post: 06-19-2003, 03:58 PM
  5. How do I get to see newer posts?
    By jlb43 in forum Aprilia and Piaggio 500cc
    Last Post: 11-13-2002, 02:26 AM
