Results 1 to 11 of 11
Thread: Suggested crankshaft for the 2014 aprilia sr 50 r
    Jan 2017
    North Lincolnshire, Humberside
    I'm going to be ordering the stage 6 sport pro mk2 70 kit and I've been advised to change the crankshaft due to it having over 11,000 kms on the standard one.
    Should I buy another standard crank?
    Other tuning suggestions welcome and appreciated
    ontario
    ok. for that you need a full circle crank and 3 bearings/ 2 new seals and most importantly a reed valve spacer to lower the primary compression a little.
    if you cant find any reed spacers available - i can make you one from scratch.
    -derbi bullet 2006 - piaggio AC - malossi torque driver half - custom GPS dash - TPR 70CC - topperf crank - vl13 reed and spacer- yamaha rt180 kickstand - giannelli shotV4 - phbg 21mm - doppler mesh top venturi filter - TTO tempurature gauge
    -1992 lt250r suzuki quadracer
    Jan 2017
    My bad it has just over 14,000km on the clock
    ontario
    aircooled? better of with the topperf trophy- the exhaust port can let the heat out for 9hp solid engine. the others only 8 hp.... the s6 sport will be a money pit and never see more than 10 hp for a few miles before it melts the rings off the next time the wind blows in your face.
    for liquid cooled - better off with a 12hp topperf 2plus 70cc and a yasuni city 16. 1200 usd to build
    Jenison, Michigan
    I think the Stage6 Sport Pro MKII might be a little overkill unless you like changing piston rings every 500 miles.
    http://www.maxiscoot.com/stage6-cyli...7214043-3.html
    http://www.maxiscoot.com/metrakit-cr...75v1910-3.html
    http://www.maxiscoot.com/mvt-cranksh...vt-vi12-3.html
    http://www.maxiscoot.com/stage6-reed...9040-vt-3.html
    http://www.maxiscoot.com/stage6-exha...9114003-3.html
    This is what I would personally get if I wanted good, yet reliable power. You're at about 425 not including rollers, clutch, belt, re-jetting, a couple spark plugs, and the other little things that nickel and dime you until you get the setup just right.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
    Jenison, Michigan
    I've been doing some reading on this and it seems that the Stage6 cylinders are hit or miss with quality. Top Performance does make some mighty fine sports cylinders for about the same cost. They have a couple different cast iron options which are great for everyday riding and longevity.
    http://www.maxiscoot.com/top-perform...9931270-3.html
    http://www.maxiscoot.com/top-perform...9920590-3.html
    The 2 piston ring setup will not allow for as high of an RPM, but will create more stability for the piston causing a decrease in cylinder wear.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Arrow Extreme Pipe
    Malossi VL 13
    Water Trap
    RS 24/10
    Fuelab 535 FPR
    ontario
    [QUOTE=JakeMan1;4207353]My bad it has just over 14,000km on the clock
    what are your upgrades? please type it in your signature so we dont have to guess.
    again if its aircooled and driven in traffic a simple trophy 70cc kit - a yasuni r and a vforce reed and a 17mm carb and its done besides a 5000rpm clutch. ---that is about 10hp.
    Jan 2017
    It's liquid cooled, currently derestricted with a techigas exhaust no other modifications apart from the stage 6 jack up kit
    ontario
    Quote Originally Posted by JakeMan1 View Post
    so wich carb do you guys get stock? the 17.5? then a yazuni r or c16/city 16. a vforce reed. the tp 2plus 70cc and tp crank. a malossi 5000rpm fly clutch.
    - if you get the c16/city 16 you also need a malossi 2000 variator and rear torque convertor half. you might be ok with the yasuni r if you dont want to change the variator and rear torque convertor.
    thats how i see a decent midrace kit - but the carbs will be a night mare if you go and delete the airbox and fuck the build up by switching carbs.
    leave the carb and needle and airbox all matched together. no need to shoot yourself in the foot
    ontario
    which tecnigas do you have?
    ontario
    if i were you i would get the city 16 and keep the carb and airbox and needle all stock. the peakyness of the regular c16 will be harder to dial in the stock carb.
  1. Mechanic for an 2013 Aprilia SR 50 Ditech
    By Penguino67 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 05-07-2016, 02:03 AM
  2. Service questions: 2014 Aprilia SR 50 Motard
    By KVorkian in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 02-06-2015, 07:41 PM
  3. What is the standard jet size for 58 plate aprilia sr 50
    By Dan445 in forum Other Stuff For Sale
    Last Post: 11-20-2013, 05:12 PM
  4. is the 2001 aprilia sr 50 direct inject?
    By nicholaschase29 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-02-2012, 08:32 PM
  5. Exhaust suggestions For Aprilia SR 50 R
    By polepeach in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-24-2012, 12:43 PM
