Page 2 of 2 FirstFirst 12
Results 16 to 17 of 17
Thread: SR50 R Throttle problem *help*
    Jenison, Michigan
    Yup, it's carbed and oil injected. The rollers are stil 19x15.5 and the ones that came with the pipe are a good starting point for your engine. The DiTechs don't have a kickstart. We're screwed if we get stuck with a dead battery. No worries, we still like you
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
    Oct 2016
    UK
    Haha! We finally figured it out! Will be putting in the rollers soon thanks for the help!
  1. SR50 front fork problems help
    By Gbgfactory in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 02-14-2011, 02:58 PM
  2. SXV 2008 Throttle problem..Help please
    By Hisham in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 06-12-2010, 08:00 AM
  3. SR50 Ditech 2005 Problem HELP!!!
    By Jackniksmith in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 07-26-2009, 06:24 AM
  4. Need Urgent Help With SR50 DiTech - Crank Problem!
    By Ste-V in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 10-12-2006, 10:32 AM
  5. SR50 Problems - help!
    By SFsr50 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 02-26-2004, 09:59 AM
