Page 4 of 7 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 100
Thread: my tuono v4 horror story. i need advice.
  1. #46
    Dec 2016
    Orlando
    No the connecting rod is there you can see the top of it through the hole in the top of the damaged piston ��. It is the extended warrantee company not aprilia who I'm fighting hopefully soon with the attorney. And from my reading of this forum, I thought you can't swap with rsv4 engine.
    2012 Tuono v4 aprc 12k miles blown engine just happened Dec.
    2000 zx9r. 55k miles currently a tip to tail check and overhaul
  2. #47
    apriliaforum Junkie Handy Rodder's Avatar
    Jul 2013
    MI
    valve hit the piston. broke and rattled around and busted everything else. gee wiz i wonder how a valve dropped after valve adjustment. things that make you go hmm.
    what cylinder? front or rear bank?
    13 Tuono
    08 CRF450R
    06 K1200R
    03 YZ450F
    02 GSXR-1K
    96 CBR900
    86 Fazer 700
  3. #48
    Dec 2016
    Orlando
    Rear bank.
  4. #49
    Dec 2016
    Orlando
    Dealer says they can't say for certain what happened. They filled with warrantee co. Saying they believed can chain tensioner failed throwing off timing.
  5. #50
    Westminster, CA - USA
    Quote Originally Posted by the sofa king View Post
    Bulshit
  6. #51
    Let me elaborate a bit.
    If a tensioner failed or if sprocket bolts loosened up, you would have valve to piston contact on both cylinders.
    Did the shop who adj the valves give you a log of what the clearances were at before they adj them?
  7. #52
    apriliaforum expert marcodarq's Avatar
    Jun 2006
    south florida
    While i agree with Amauri, is it possible that the dealer is trying to file a claim that the warranty company is more likely to accept and approve the repair?
    M
    marco bjishkian
    Rocket Ride Cycles
    1855 SW 4th Ave B-17
    Delray Beach FL 33444
    561.455.2840
    Authorized DynoJet Tuning Center
  8. #53
    That could be, but keep in mind that the extended warranty companies have their own experts who know how to analyse engine failures.
    The dealer should not be making up a BS story, instead they should just tell it like it is... a valve broke and fell into the cylinder. Simple as that.
    Question for the OP:
    What exhaust do you have on the bike, and do you have a Race map?
  9. #54
    apriliaforum expert PRC001's Avatar
    Feb 2013
    Cape Town, South Africa
    Very good question. I haven't seen that kind of mess since my 2 stroke days!
    2015 Tuono V4 1100 Factory
    Brembo RCS19 MC, Akrapovic Exhaust, GRT ECU, DNA filter, Lightech levers, rear-sets & chain adjusters, Evotech tail-tidy, Evotech fork & swingarm sliders, Cox Racing Rad Guard & Aprilia Factory Forged Alloys.
    2012 Tuono V4 APRC Fast
    Black.... Sold
    Yamaha MT-10 SP... sold, boring Jap appliance.
  10. #55
    Dec 2016
    Orlando
    The bike is totally stock. Yes, their view was it could have been a floating valve (which company won't cover for some reason) or cam tensioner, so that is what they filled as. The adjustment specs. ... i remember seeing them at one point but i don't have them personally to display. They did say not all needed adjustment.
  11. #56
    Jan 2007
    Hammond, Indiana - USA
    To prove it was not valve float caused by over revving the motor, you can inspect the valve stems on all four valves for the broken cylinder. Examine the upper part of the stems - spring side. If one of the stems shows a brittle fracture with no signs of bending, then that is the valve that initiated the failure, and it's likely a manufacturing defect of that one valve. If all the stems show bending and ductility, then it's likely valve float that caused the failure. However, if it was valve float due to over rev, you would expect to see bent valves in all cylinders. I'll bet you see one valve stem with a brittle fracture.
    Hoosier, not hoser.
    2016 Tuono 1100 Factory
  12. #57
    Dec 2016
    Orlando
    Is there possibly to get an Aprilia rep to inspect the engine himself to create a report that could help me? The dealer either is unwilling to place a specific cause or uneducated to do so, or perhaps worse knows they screwed up and is doing what they can to hide it.
  13. #58
    Dec 2016
    Orlando
    Hmmm, just a thought. Since I have the factory repair manual I need to review the valve adjustment process to see if "special tools" are required. And ask the tech next time I'm there if he has one.
  14. #59
    Jul 2013
    MI
    very good point
    13 Tuono
    08 CRF450R
    06 K1200R
    03 YZ450F
    02 GSXR-1K
    96 CBR900
    86 Fazer 700
  15. #60
    apriliaforum expert MishMashRSV4's Avatar
    Feb 2011
    Glendora, CA
    Yes, there are indeed "special" tools required to do adjustment on the V4. I can think of two very distinct ones unique to the Aprilia V4 that are needed.
    Update - See this thread: http://www.apriliaforum.com/forums/c...in-the-chassis
  1. Yet another huge bill for my Tuono V4
    By Rizla V4 in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 06-12-2016, 06:51 AM
  2. My Tuono V4 has a flat spot at low revs
    By Koopz in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 06-19-2015, 12:29 PM
  3. Just bought a Tuono V4 in Brisbane, Aus, need some advice...
    By Nath88 in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 06-05-2015, 09:48 PM
  4. [REPORTAGE] On Track @Misano World Circuit with my Tuono V4 Aprc
    By thebiker in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 10-20-2014, 09:19 AM
  5. Where to put the Gopro on my Tuono V4
    By Kalu76 in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 02-27-2014, 04:33 PM
