Page 3 of 7 FirstFirst 12345 ... LastLast
Results 31 to 45 of 100
Thread: my tuono v4 horror story. i need advice.
  1. #31
    Dec 2016
    Orlando
    They also told me 2011-2015 specifically tuono engines all fit. Confirmation? Anything I need to know that could aid in my search of an engine? Cause so far I've only seen a 2014 engine on ebay.
    2012 Tuono v4 aprc 12k miles blown engine just happened Dec.
    2000 zx9r. 55k miles currently a tip to tail check and overhaul
  2. #32
    Dec 2016
    Orlando
    I tried to post last night and had issues. Marco, I definently will be in contact with you after i get this up and running again. No, I wasn't hitting Rev limiter or anything. I'm one of those who set the shift light low as to not hit red line, i loved my baby. In fact i changed my oil twice as often as the manual says to do. I truly believe the dealer screwed up but the warrantee company is only denying my engine claim based on their assumption that I did not maintain it. I have my proof I maintained it more than I have proof that the dealer did anything wrong.
  3. #33
    Apr 2016
    OC, CA
    I hope you get it sorted! At that kinda mileage, either Aprilia or the warranty company should do something. Not too long ago, Kawasaki authorized a $2k warranty repair on my bike even though it's been out of warranty since last summer. Now, that's standing behind your product right there!! And it was even partially my fault for removing something I shouldn't have. That really makes me want to pick up another one when the time comes.
  4. #34
    Dec 2016
    Orlando
    Inside pics
    Oh the horror
  5. #35
    apriliaforum expert vfr1200's Avatar
    Jun 2011
    Azle, Texas
    Yeeeeouch thats bad.
    2017 Sherco 300 SER Factory
    2016 Tuono 1100 Factory
    2015 TREK 7.3
    https://www.amazon.com/s/ref=nb_sb_n...alan+golightly
  6. #36
    Dec 2016
    Orlando
    Aprilia USA basically said sorry. It's a low mileage bike and all but it is a 2012 manufacture warrantee ended 2 years ago.
  7. #37
    Apr 2016
    OC, CA
    Wow, that looks terrible!!
  8. #38
    Dec 2016
    Orlando
    There are metal shavings from the butterflies down to the oil pan. The dealer did tell me after I had them tow it in. That "we started it up and it ran, but now it's seized". That really suprised me considering I brought it in suspecting that it blew and when we tried to get the mileage to write up the R.O. the dash had every warning don't run this engine light it could show. That didn't make me to happy to hear that they did that. Can't you spin the crank by hand with the tibial of one side cover?
  9. #39
    Dec 2016
    Orlando
    Removal*
  10. #40
    apriliaforum expert BitSar's Avatar
    May 2012
    Melbourne, Australia
    Farken hell.
    Sent from my SM-G920I using Tapatalk
    BLOG = http://bitsar.blogspot.com.au
    Life
    is Complex
    :: {It has an (i)maginary component && a (R)eal component}
  11. #41
    Oct 2015
    Tasmania
    Wow that's one of the most unique valve jobs I've ever seen. tough to replicate. lol.
  12. #42
    May 2016
    Ohio
    Quote Originally Posted by the sofa king View Post
    You should have DEMANDED that they did not crank the motor over. You said you 'suspected' that the engine blew?...With damage like that, it had to be apparent.
    The dealer couuld have easily stuck a borescope through the cylinders to see the damage instead of trying to start it...not that it mattered at the point. That dealer is retarded. You need to put their name on front street so people are aware of these idiots.
    u
    Current rigs:
    '16 Tuono RR -street
    '13 RSV4 -race
    '13 Harley Davidson Night Rod Special
    '13 Yamaha WR450F
    '12 GSXR 600 - race
    '07 GSXR 750 - race x 2
    '03 KDX 200
    '17 Tao Tao Hellcat - pit bike
  13. #43
    Dec 2016
    Orlando
    She felt FN great after the valve adjustment for those 60 miles. That is until i headed to work, 4 miles in I started feeling a hesitation. No warning lights ever came on and when I looked over my shoulder for a lane change, I see a trail of oil smoke behind me so I start to pull over on the interstate. Before i make it to the show lane the engine shuts off and I coast down the off ramp where it then started leaving oil out. I can't say the damage was our wasn't done yet and didn't know they were planning on trying to start and run it. I wish I could put the name or there but I won't at this time. It's in the attorney's hands at this point.
  14. #44
    Oct 2005
    Slinger, WI.
    Any updates on the discussion with the warranty company? Have you filed a complaint with the state?
    2016 Aprilia Tuono 1100
    2016 BMW S1000XR
    2016 Yamaha Super Tenere
  15. #45
    Mar 2016
    Altoona, PA
    Just had my motor blow to smithereens (valve dropped) at 5500 miles. Kept up with maintenance and didn't run it on rev limiter. Factory warranty expired a little over 1 month prior. Go after the warranty company because I can almost guarantee Aprilia will be of no help based upon my experience. I ended up putting in an 1100 motor with less than 1000 miles in my 2014 (had a valve inspection done on new motor prior to install to be safe). As another thread mentioned...You will need a new dash, ECU,and the new motor if going to an 1100. The dealer will likely need to purchase some other small bits and pieces for the swap but those are the big 3 items you'll need. Just a ballpark estimate you might expect is $1500-2000 in parts and labor not including engine, ECU, and dash. I'm planning on doing a full write up of my experience in the near future after I get her back on the road. Definitely, don't buy a new Motor until you've absolutely exhausted your warranty company option first. YOU PAID/DESERVE that protection
  1. Yet another huge bill for my Tuono V4
    By Rizla V4 in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 06-12-2016, 06:51 AM
  2. My Tuono V4 has a flat spot at low revs
    By Koopz in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 06-19-2015, 12:29 PM
  3. Just bought a Tuono V4 in Brisbane, Aus, need some advice...
    By Nath88 in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 06-05-2015, 09:48 PM
  4. [REPORTAGE] On Track @Misano World Circuit with my Tuono V4 Aprc
    By thebiker in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 10-20-2014, 09:19 AM
  5. Where to put the Gopro on my Tuono V4
    By Kalu76 in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 02-27-2014, 04:33 PM
