Results 16 to 17 of 17
Thread: What modifications are recommended for the 2014 Sr 50 r?
    apriliaforum Junkie 2Strokesforlife's Avatar
    Aug 2016
    Jenison, Michigan
    If you would've said the slots in the torque driver are c-shaped, that would've cleared up some misunderstanding. I agree with almost everything you've said, except nobody on this forum or anyone I know has ever put in heavier rollers to improve acceleration.
    2009 SR 50 Factory
    Malossi 70cc BBK
    Malossi HPC Crankshaft
    Stage6 Waterpump Impeller
    Arrow Extreme Pipe
    Malossi VL 13
    Ecu De-restricted 2.8.0
    7 Gram Dr. Pulley Sliders
    Stage6 Soft Contra Spring
    Water Trap
    RS 24/10
    Stage6 260mm Front Brake
    Stage6 Torque Control MKII 107mm
    Stage6 R/T Clutch Bell 460g
    Malossi Special Belt
    Malossi E5 Air Filter
    Fuelab 535 FPR
    Glowshift Dual Needle Gauge
    Stock Gears Installed
    ontario
    i appoligize. its not your fault.
    i have been on atleast 7 to 12 other forums on various hobbies and i wipe the floor with their most respected and authoritive many times. yes i have to allways start at the beginning like you. i welcome discussion with open arms. i learn stuff everyday and 80 percent of what im saying is duplicat of others all ready know!
    i think your one hell of a good student. if you have questions msg me or start a thread perhaps. i would love to be more humble but that would be foolish
    --- diploma for engine repair in 2012 --- powder coat painting --- porting and polishing --- custom aluminum parts and machining --- ditech fuel pump service.
    derbi bullet 2006 - piaggio AC - malossi torque driver half - custom GPS dash - TPR 70CC - topperf crank - vl13 reed and spacer- yamaha rt180 kickstand - giannelli shotV4 - phbg 21mm - doppler mesh top venturi filter
    complete wtp volta bmx 2012 - sanko seamless japanese cromoly heat treated and blueprinted frame - 21lbs
    1992 lt250r suzuki quadracer - maier plastics -chromed shearer pipe - chromed works suspension - 220lbs
    previous vehicles - subaru legacy turbo 1991 - mazda mx6 turbo 1990.
    tamiya fighting buggy and sand scorcher
  1. what luggage rack are available for the falco
    By nickodemon in forum SL1000 Falco Forum (all years)
    Last Post: 09-27-2014, 03:30 AM
  2. What tire width do you recommend for the rear?
    By SumWhiteGuy in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 10-31-2009, 01:43 PM
  3. What fork upgrades are available for the Futura?
    By mindfulrider in forum RST1000 Futura (all years)
    Last Post: 02-14-2008, 10:13 PM
  4. What accesories/ upgrades are available for the new rs50?
    By Nickmasson in forum RS50 Technical
    Last Post: 03-28-2007, 02:41 PM
  5. whats the first year for the Ditech SR 50?
    By wctouring7 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 10-04-2004, 01:21 AM
