Results 1 to 7 of 7
Thread: What kind of gas for the SR50 CARB model?
    Sep 2016
    FL
    I've been putting in 87 with no oil mix.
    How bad is this??
    Apr 2014
    Northwich
    By no oil mix do you mean you have been running it without any oil in the 2 stroke oil tank?
    Black Sr50r 2014
    Current mods
    Stage 6 RT 70
    Stage 6 RT crank
    Flowed engine case
    Stage 6 R 1400 with RT end can
    Stage 6 water pump
    Doppler inner rotor ignition
    Stage 6 R/T shock absorber
    stage 6 v force 3 reed block
    Stage 6 black f1 mirrors
    Stage 6 112mm clutch with Malossi MHR black springs (Much better than the stage 6 springs )
    Stage 6 oversize variator 5.0g rollers
    Stage 6 oversize rear pulley
    Stage 6 oversize belt
    Stage 6 medium torque spring
    Ngk b-e 10.5 spark plug
    BGM boost bottle
    Stage 6 metal inlet manifold
    Stage 6 28mm RT flatside PWK- 122 main jet second clip down
    No airfilter (won't run with one )
    stage 6 1:2.53 gear up kit
    Top speed- fast......
    Next mods
    Mvt Premium inner rotor ignition
    Sep 2016
    FL
    No!
    I mean I haven't been mixing any oil in the gas tank.
    I've heard I'm supposed to.
    But the manual doesn't mention it.
    As a side note, what kind of oil do I fill the oil tank with?
    I mean an exact brand and type... there are so many to choose from.
    thanks.
    In terms of gas, I tried 89 yesterday, not sure I noticed any difference.
    Jun 2016
    Florida
    I would suggest ethanol free in 87 or 89. Ive used yamalube in my zuma for 10,000+ miles with good results.
    Jan 2017
    North Lincolnshire, Humberside
    My sr50 has an automixer I should think yours should have the same?
    Sent from my GT-N7100 using Tapatalk
    Apr 2014
    Northwich
    I usually use castrol power 1 2t racing
    ontario
    the stock compression is low so it can run the 87 octane.
    -derbi bullet 2006 - piaggio AC - malossi torque driver half - custom GPS dash - TPR 70CC - topperf crank - vl13 reed and spacer- yamaha rt180 kickstand - giannelli shotV4 - phbg 21mm - doppler mesh top venturi filter - TTO tempurature gauge
    -1992 lt250r suzuki quadracer
  1. Tuneboy. What kind of JOKE for a company this?!
    By Ylleskog in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 05-11-2013, 03:49 AM
  2. what kind of gas milage do you get?
    By mr2turbo in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-17-2007, 05:40 PM
  3. Do they actaully make a performance exhaust for the SR50 CARB 2005
    By modrider in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 12-13-2005, 07:18 PM
  4. What kind of exhaust for a Tuono?
    By King Atlas in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-09-2003, 09:57 AM
  5. What kind of transmission oil do the USA guys use?
    By memphisrs50 in forum RS50 Technical
    Last Post: 06-23-2003, 05:11 PM
