Results 1 to 4 of 4
Thread: After market LED blinkers and stop light
    Apr 2013
    seattle
    I took the rear blinkers off and replaced them with LED stop light and blinkers attached to the plate frame. Now I get an dash error saying my lights are burnt out. Is there a work around?
    Apr 2013
    seattle
    this should have gone in 750 section 2009 shiver
    Aug 2015
    Gilbert, Arizona (USA)
    Did you get your answer? Typically, LED's need a resistor to be added so the rest of the electronics (flasher relay, etc.) sense the proper draw.
    2014 DD 750 ABS - Spark exhaust, Arrow decat, headers (all ceramic coated), BMC filter, FatDuc, BikeMaster DLFP16-BS LiFePO battery, GPR steering damper, DD 1200 fully adjustable rear shock w/spring swap, 2016 Tuono Factory wheels, 15/44 520 conversion (PBR/Superlite/DID), Strada-7 fork preload adjusters, Samco 2-piece hose kit w/clamps, Engine Ice, Renazco Racing seat, EvoTech tidy tail, Aprilia grab handles, shorty levers, crank-case breather mod, evap-can delete... and a Rapid Bike EVO on order...
    Feb 2012
    Sierra Nevadas
    Some turn signals come with resistors built in (such as ADVdesigns), but it sounds like yours didn't.
    You can probably use a multimeter to determine the resistance of the original bulbs vs the LED, and order tiny resistors through an electronics store to make up the difference.
  1. After market brake and clutch levers
    By swannie007 in forum 2012-2017 Tuono V4 - All Variants
    Last Post: 04-17-2012, 11:46 AM
  2. best after market forks and shock
    By elad_101 in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 12-07-2009, 04:42 PM
  3. after-market replacement for tail lights (brake and turn signals)
    By rxv in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 11-28-2006, 07:36 PM
  4. after market pegs and pedals
    By Dr. Theo in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-11-2006, 03:40 AM
  5. After market rear light assembly
    By Mustard in forum RS250
    Last Post: 02-08-2005, 01:58 AM
