Page 4 of 11 FirstFirst ... 23456 ... LastLast
Results 46 to 60 of 154
Thread: testing a cheap and easy fix for hot start issue
  1. #46
    Oct 2015
    Australia
    amauri, I checked the auto shops for 12 gauge here in Oz and I just get blank looks, so I googled 12 gauge converted to mm & it says 2mm is equivalent to 12 gauge ? 2mm wire seems thin for the job, am I missing something ?
  2. #47
    apriliaforum prov-nov SylaR's Avatar
    Dec 2016
    Germany
    I had a similar problem with comparing gauge / mm. Found some wires 12 gauge on eBay, you could give that a try?
  3. #48
    apriliaforum expert surfmonster's Avatar
    May 2013
    NYC
    12 AWG as an add on to the existing wire is fine. You are just adding more copper to the circuit, thus lowering the overall resistance. Think of it as adding 2mm to the diameter of existing loom wire. It's not really as straightforward in real life, there is a formula to clalculate the exact value, but basically same logic applies. As one of the previous posters noted- adding an even thicker wire would be better electrically, but as Amauri stated- a lot more difficult to install due to terminal size on solenoid.
  4. #49
    Oct 2015
    Australia
    Ok thanks, just checking that 2mm is equivalent to 12 gauge, just seemed small compared the the pic amauri posted.
  5. #50
    Sep 2014
    Portland, Oregon
    Ahh,it's not equivalent to 2mm squared.
    it's one of those in-between sizes.
    2.5mm squared is 17% smaller in area.
    4 mm squared is 33% bigger in area.
    In the US, a unit known as "Circular Mil Area" is often used to describe electrical current carrying capability.
    Or, we use the really archaic and confusing AWG system.
    Using the metric system makes a lot more sense (in this case).
  6. #51
    May 2013
    NYC
    12AWG wire is 2.05mm in diameter.
  7. #52
    Dec 2016
    Germany
    so this is a 12g wire. 5cent coin for scale
  8. #53
    May 2013
    NYC
    The AWG or mm˛ or diameter in mm refers to conductor size. Wire sheath or jacket thickness or overall size of jacketed wire could vary widely based on a lot of different factors and specific purposes for that wire.
  9. #54
    Oct 2015
    Australia
    I haven't disconnected the battery before, should I expect it will throw any faults ?
  10. #55
    apriliaforum prov-nov X_Splinter's Avatar
    Jun 2016
    Portugal
    Quote Originally Posted by stoner1 View Post
    I haven's disconnected the battery before, should I expect it will throw any faults ?
    I did it to install a charging cable... had no faults.
    Just the clock that is reset...
    Enviado do meu SM-G935F através de Tapatalk
  11. #56
    apriliaforum expert flossy's Avatar
    Jan 2012
    Seq/Qld Auzzieland
    The only fault it will throw is ydrie, [you don't ride it enough,] how's the new house Pedro, hope its great, give us a call if your going for a scoot, my burgers aren't the same without ya, and what is haven's, is that a new harlem haven you haven't showed me yet,
    Spent my day after work adjusting clickers all round by 10 in here and there, not one to muck around with a turn of one or two, even if some only have 3 turns, running some dunny alpha Q3's at the moment, stick alright, catch up ya dog,
  12. #57
    Jan 2007
    Hammond, Indiana - USA
    If you go to any auto parts store, the 12 gauge wire is sold as "primary wire".
    Hoosier, not hoser.
    2016 Tuono 1100 Factory
  13. #58
    Feb 2017
    Perth
    Hi All,
    I too had a couple of hot start issues occur with my RSV4 13 Factory.
    I had the fairings of one day and noticed how close the exhaust headers are to the starter motor.
    So i got to thinking and came up with the below fix for me.
    My bike regularly sees the temp hitting 104C, as its currently 38C average daily where I live.
    The below pictures hopefully say a thousand words.
    Before image, showing how close the Ti Akro Race headers actually are to the Starter Motor:
    DIY Insulated Thermal blanket, for the starter
Name:	rsv4 starter motor thermal blanket 2017-02-25.jpg
    Blanket as it will appear installed on the starter:
    Blanket installed around the starter:
    Starter motor with new blanket, reinstalled:
    Header reinstalled. and wrapped in Ti Thermo Wrapping aswell.
    I've only done a couple of short runs with the bike, maybe an 1.5hours atmost. I had 2 hot (relatively) starts on the ride, and there was no issue.
    As an aside, the Ti Thermo Wrapping on the headers has seemingly reduced the engine operating temp by 3C (degrees Celcius). It also assists the radiators in flushing the hot, latent air normally trapped between the radiator and the front of the engine, as the air temp here has been reduced. Now when the engine temps gets up over 100C, it is now quicker in flushing the hot air out.
    I have yet to wrap the rear headers, but hope this will help reduce the temps that the fuel tank and my nards see.
  14. #59
    Nov 2013
    Toronto, Canada
    http://www.knowyourparts.com/starter...hot-heat-soak/
    Makes sense if your starter is getting cooked to protect it...
  15. #60
    Oct 2015
    Australia
    Any more reports from those who tried amauri's 12 guage wire idea ?
    By Roadcraft in forum 2012-2017 Tuono V4 - All Variants
    By livharder in forum 2010-2017 RSV4 - All Variants
    By jim pittsburgh in forum 2012-2017 Tuono V4 - All Variants
    Last Post: 05-24-2013, 09:31 AM
    Last Post: 07-31-2010, 05:16 AM
  5. cheap and easy work table
    By 5axis in forum RS250
