Page 3 of 13 FirstFirst 12345 ... LastLast
Results 31 to 45 of 184
Thread: testing a cheap and easy fix for hot start issue
  1. #31
    Aug 2007
    San Antonio
    If you're not having a hot start issue but just want a better start the 1st time. Do you do this mod?
    Does it make for better starts, period?
  2. #32
    Westminster, CA - USA
    You tell me.
    Try it and report back.
  3. #33
    apriliaforum prov-nov SylaR's Avatar
    Dec 2016
    Germany
    Well, I will just install this mod when doing the aprc upgrade. Won't hurt, that's for sure. :-)
    Will report back!
  4. #34
    Aug 2007
    San Antonio
    Hmmm. That's a good idea, I'm gathering parts to add aprc to mine too.
    So to be clear. We're just buying standard automotive wire cable and crimping our own ends on to it. 15' or are we buying pre-made stuff and I miss that somehow?
  5. #35
    apriliaforum expert comfysofa's Avatar
    Sep 2012
    Bristol, uk
    That's right... I did this mod to my hypermotard.... So far so good....
    Sent from my SM-P900 using Tapatalk
  6. #36
    apriliaforum Member RosscoB's Avatar
    Oct 2008
    Austin, TX
    I put one together and installed it last night. Now, I just need to find time to ride.
  7. #37
    Oct 2008
    Austin, TX
    I rode to work today which heats up the bike from excessive idling. The additional 12ga wire did not fix the issue on my bike.
    However, I have a 2013 that still has the original battery.
  8. #38
    apriliaforum expert Hellgate's Avatar
    Mar 2009
    AUSTX
    Interesting. Have you checked your stator? The upper half of mine is turning a "light toast" color.
    Sent from my SAMSUNG-SM-G900A using Tapatalk
    Pete
  9. #39
    Quote Originally Posted by Hellgate View Post
    Yes, thanks for the reminder.
    Testing the stator and the battery is the first step in troubleshooting this hot starting slow cranking issue.
    Installing the wire I suggested will not fix a weak battery or a shorted out stator.
    Also make sure that the cable connections at the battery, solenoid and starter motor are clean and tight.
  10. #40
    Oct 2008
    Austin, TX
    I have not checked the stator, but that is next.
    I'm sure the battery connections are all tight. I'll need to double check the starter.
  11. #41
    Jun 2014
    Southern California
    Appears to have worked for me. Thank you kindly for posting!
    2012 Tuono with new model stator and fairly recent new battery. It never seemed to start super strong when hot but never didn't start, until the other day. Cool running temps and ambient temp... pulled off to fuel....went to start and it acted like nearly dead battery. Jump started it. Came home checked voltages and they were ok. Installed wire as in first post. Did a couple test rides with shut down after hot, and it restarted each time. Awesome.
    PS At the gas station I attempted an assisted "bump start" and it was laughable!! Jumper cables did the trick though.
  12. #42
    apriliaforum prov-nov Smg604's Avatar
    Nov 2016
    Vancouver
    HeyGuys,
    So I have about 800 km so far on my new Rf...and I have started to experience hot start after a couple hour ride even tho its like 5c (40f) up here...
    any ways....i just bought the wire...and i had in my head 8 gauge ... now I read it supposed to be 12g....can I still add the 8? or should I go buy the 12g like
    amauri said to do.?
    thx
  13. #43
    Dec 2016
    Germany
    I *think* that should be fine. However, few bucks for that wire, you could just buy a 12g.
    Let's see what amauri says. :-)
  14. #44
    apriliaforum Member dmc1's Avatar
    S.F. - CA
    Quote Originally Posted by Smg604 View Post
    HeyGuys,
    amauri said to do.?
    thx
    Quote Originally Posted by SylaR View Post
    8ga is fine.
    It's a little bigger than it "needs" to be, but it will work the same. 12 gauge was the recommended due to ease of use and fitment.
    Getting 8 gauge is overkill, BUT, it's not going to cause any problems when using it if you route it and install it per the recommendations here.
  15. #45
    8 gauge will be a very tight fit on the small terminal at the solenoid, you really should use 12 gauge.
    By Roadcraft in forum 2012-2018 Tuono V4 - All Variants
    By livharder in forum 2010-2018 RSV4 - All Variants
    By jim pittsburgh in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 05-24-2013, 08:31 AM
    Last Post: 07-31-2010, 04:16 AM
  5. cheap and easy work table
    By 5axis in forum RS250
