Page 2 of 13 FirstFirst 123412 ... LastLast
Results 16 to 30 of 184
Thread: testing a cheap and easy fix for hot start issue
    Westminster, CA - USA
    Gabro, I do remember those starting problems with the early bikes.
    At first Aprilia released a bulletin with the different crank timing sensor that didn't help.
    But that starting problem was not the same as many are experiencing on the newer bikes with the newest maps (like the two bikes I'm testing).
    That old hot starting problem was a case where the starter would engage and spin at normal speed, but the engine would not fire and run.
    Installing this wire will not fix that one.
    This hot start problem is very different because the starter is acting very lazy and doesn't want to spin the engine at normal speed, sometimes not at all until you give it time to cool off.
    I suppose that the first step is to first identify which starting problem we are dealing with.
    apriliaforum prov-nov X_Splinter's Avatar
    Jun 2016
    Portugal
    Any idea if this will fix earlier models problem?
    what is the difference between the earlier model problem and the newer problem?
    apriliaforum newb Johnboy71's Avatar
    Sep 2014
    Wales, UK
    Nice work around! I've been working on this issue in the UK, and although I make a full cable kit for the V4, which is a more elegant way of solving the issue, you've nailed the problem by improving the current carrying capacity of the starting circuit.
    the V4 only has a 10mm2 cable to start with ( excuse the pun) so is on its absolute limit of being able to draw enough current to the starter motor. So when the engine is hot, they do tend to nip up a little ( just like the Vtwins) so your starter physically can't draw enough current through the standard wet string that Aprilia install at the factory.
    Jan 2007
    Hammond, Indiana - USA
    Amauri, do you remember what size for the two crimp ring terminals?
    Hoosier, not hoser.
    2016 Tuono 1100 Factory
    The bolt on the battery terminal is 6mm diameter on the older bikes or 5mm on the newer bikes.
    The bolt on the solenoid terminal is 5mm.
    Jan 2007
    Thanks.....
    Hoosier, not hoser.
    apriliaforum Junkie cb77guy's Avatar
    Jan 2016
    Wichita, Kansas
    I am having the problem with my 2016 and am wondering if I used a piece of 8 gage wire instead of 12 gage wire for the supplemental wire would cause any problem. I just happen to have some left over from a home wiring project.
    2016 Aprilia RSV4 RF LE #11 of 200
    2011 Honda CBR1000RR Repsol Edition ( Sold 6-5-18)
    2002 Honda RC51
    1980 Honda CBX
    1965 Honda CB77 Vintage Roadracer
    Feb 2014
    United States
    you simply add the wire right? you're not removing the old stock 8g wire right?
    apriliaforum Junkie the kapitein's Avatar
    Nov 2015
    the Netherlands
    I did do the update today. Just like you wrote in your first post.
    If the winter is leaving The Netherlands I hope to do some tests. Do you think it needs an extra cable to the starter motor?
    Marco.
    Jan 2007
    Quote Originally Posted by Tekniqs View Post
    Yes, you're adding a piece of 12 gauge wire in parallel with the original 8 gauge wire.
    Hoosier, not hoser.
    Quote Originally Posted by the kapitein View Post
    So far, with the two bikes I'm testing, the single 12g wire to the solenoid has fixed the issue.
    I don't think there is a need for another wire between the solenoid and starter.
    If you can, please test and see how the single wire addition you've installed works out for your bike.
    Feb 2014
    United States
    awesome!
    apriliaforum Member dmc1's Avatar
    S.F. - CA
    I will second this statement. I just finished the mod and it seems to have plenty of current running to the starter now.
    I was able to start it even with gearing engaged. The secondary wire amauri suggests is plenty for helping alleviate the burden of running the accessories while cranking the engine.
    Thanks and kudos, amauri!
    Thanks for the feedback, hopefully others will report back with their experiences.
    And thanks for doing a better job explaining the idea behind this second wire:
    "The secondary wire amauri suggests is plenty for helping alleviate the burden of running the accessories while cranking the engine."
    That was my reasoning for trying this.
    By Roadcraft in forum 2012-2018 Tuono V4 - All Variants
    By livharder in forum 2010-2018 RSV4 - All Variants
    By jim pittsburgh in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 05-24-2013, 08:31 AM
    Last Post: 07-31-2010, 04:16 AM
  5. cheap and easy work table
    By 5axis in forum RS250
