Page 1 of 11 123 ... LastLast
Results 1 to 15 of 165
Thread: testing a cheap and easy fix for hot start issue
    Westminster, CA - USA
    Many RSV4's and TV4's are experiencing difficulty starting when the engine is hot, the starter cranks but struggles to turn the engine over fast enough, as if the battery is dead.
    This usually happens when you stop for gas or a short break and try re-starting within a few minutes. Never a problem when the engine is cold.
    First, make sure the battery is good (holds a charge and passes a load test)
    Test your charging system to make sure you have correct charging voltage at the battery, usually 13.5 - 14.2 Volts with the engine running.
    Test the stator (especially 2012+ bikes) and make sure it passes continuity and short to ground tests with engine at full temp.
    If the battery and/or stator are weak, this modification will not help at all.
    I know that many are having good results with the motoelectrics heavy duty battery cables kit, but it is expensive and can be difficult to install correctly for the average person.
    I've been testing a simpler fix on two customer's bikes for a couple weeks now and it seems to be working.
    The starter solenoid does double duty as both the main +12V power distribution point to the whole motorcycle, and it also sends high current or Amps to the starter when you push the start button.
    Take a look at the OEM positive wire from the battery to the starter solenoid, it is a 8-gauge wire.
    Now take a look at the wire from the solenoid going forward to the starter motor, it is also a 8-gauge wire.
    My solution is to install a second wire to supplement the solenoid from the battery.
    Not removing the original wires and replacing with all new wires, just a second wire in parallel with the original.
    The wire I added reduces the voltage drop to the starter and to the ECU, fuel pump, injectors and ignition while cranking the engine.
    Please see photos showing the 15" long 12-gauge wire with crimp terminals on each end and installation routing.
    Of course, the usual precautions must be followed.
    disconnect the battery before you do anything and make sure you route the wire properly so there is no danger of it shorting to metal and possibly starting an electrical fire or worse.
    Like I said, this is not a guarantied fix, but worth a try for those experiencing the issue.
    apriliaforum prov-nov Prospek's Avatar
    Oct 2016
    GVRD Canada
    Thanks Amauri!!! No issues so far but will keep this in mind.
    Feb 2014
    United States
    Will keep this in mind as well! thanks Amauri
    edit: did you make the wire yourself or is this something readily found in stores?
    apriliaforum Member mastro1's Avatar
    Nov 2013
    New Jersey, USA
    Amauri,
    That's a great idea...makes sense. Just did it, hope it works. Easy fix!
    Quote Originally Posted by mastro1 View Post
    Please post your results after a few weeks of ridding the bike with this modification.
    We may have to wait until the weather is very hot again before we know for sure if this will help or not.
    Nov 2013
    New Jersey, USA
    No problem will do!
    Nov 2016
    PROVIDENCE
    did you make your own cables?
    Quote Originally Posted by PJV View Post
    What cables?
    It's one simple piece of wire and two crimp terminals.
    Aug 2011
    Melbourne
    It's coming into summer in here Australia (not uncommon to see 40+C temps where i am), so I'm sure I'll be able to run some tests. I've been caught out with this before. Thanks for suggestion Amauri.
    If the facts don't fit the theory, change the facts. - Albert Einstein
    apriliaforum Member fostytou's Avatar
    Sep 2014
    Aurora, IL
    I ran into this a bunch of times this summer, but only when it was very hot out and I had been riding hard all day. I'll try to give this mod a shot this winter but it'll be a while until I can test in those conditions.
    Thanks for the tip as always.
    This thread is about testing a possible solution that is both easy and inexpensive.
    Any postings not specifically related to testing this single wire addition will be deleted.
    If you have a better idea on how to fix this annoying problem, please start another thread.
    Nov 2016
    PROVIDENCE
    amauri, do you crimp your own cables? Was looking for a tool to buy on amazon
    It is a std wire stripper/crimping tool you can buy at any auto parts store, same with the terminals and 12g wire
    Nov 2016
    PROVIDENCE
    thanks
    Roma, Caput Mundi
    Amauri, you can add a check to first post "be sure you have lastest map loaded in the ecu"
    i had 2 '09 bikes with hot start issues, fixed simple loading a 13A9 map. Older map had a very narrow window to sync pulsation so ecu sometime was unable to phase at startup
    www.gabroracingteam.it
    Visit my FB page and like it!
    By Roadcraft in forum 2012-2018 Tuono V4 - All Variants
    By livharder in forum 2010-2018 RSV4 - All Variants
    By jim pittsburgh in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 05-24-2013, 08:31 AM
    Last Post: 07-31-2010, 04:16 AM
  5. cheap and easy work table
    By 5axis in forum RS250
