Results 1 to 15 of 18
Thread: V7 Clutch Rod and Throw-Out Bearing Replacement
    Racing SERVICE Competition Steve / AF1 Racing's Avatar
    Austin, Texas USA
    We've started seeing a few V7 customers coming in with the complaint of sticking or difficult to engage clutches on V7's, V7 II's, and V9's.
    The issue is most commonly the clutch throw out bearing, inner bushing, and rod, as described below.
    9900 North Interstate 35
    Austin, Texas 78753
    direct:512-459-3966 fax:512-482-8319
    Currently:
    '97 RS125 Two Stroke
    Previously:
    '00.5 Mille & '97 RS250.
    Austin, Texas USA
    V7's require a looser than normal clutch lever freeplay setting than most bikes. If adjusted too tight (in other words, not enough clutch lever freeplay) the small disk shaped V7 roller bearing will eventually be crushed and fail. When this happens the clutch bushing it rides on and the clutch pushrod are frequently ground down, and should also be replaced:
    Bad bearing, and worn down bushing and rod (note the missing rollers and brown burn marks on the rod; this rod was actually worn down some 4mm shorter than standard):
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    To begin, remove the clutch cable from the handlebar perch so that it is completely free, as seen below:
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Begin to remove/loosen the swingarm:
    1. Clamp the front wheel so the bike can not roll forward or backward
    2. Support the weight of the rear of the bike by lifting from the frame crossmember beneath the footpegs. (The bike should be supported so that the rear wheel is just barely in contact with the ground and can be spun with relatively little hand force.
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Loosen the bellows clamp on the driveshaft at the transmission mount:
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Loosen and let hang from the top mounts the RH and LH rear shocks:
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Remove the Swingarm Pivot Lock Nuts from each side of the swingarm:
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Loosen the allen key swingarm pivot bolts:
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Note that there is a crucial sandwich washer on the RH side:
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Once each pivot bolt has been removed, pull back the swingarm just far enough to remove the Clutch Engagement arm. (This dis-engages the drive shaft)
    Remove the clutch actuator arm and remove the cable from its end. (Note the return spring!):
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Remove the clutch pushrod and bushing (This step can be challenging, because the worn bushing can become stuck in the bore. Needlenose pliers with sharp teeth are useful here):
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Clean the clutch pushrod bore and install the new rod, bushing, bearing and outer bushing assembly as laid out below:
    (Note: the pushrod assembly only inserts fully in one orientation. Since installation is blind, patience is key here. DO NOT FORCE IT)
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Re-install the clutch engagement arm, clutch cable (not visible) and be sure to correctly seat the return spring:
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Slide the swingarm forward, and re-insert the driveshaft into the engine. Aligning the driveshaft splines is challenging and requires patience. If you are having a hard time aligning it, walk away for a bit, and try again, the alignment is as much witchcraft as it is skill. Once aligned, the swingarm will slide on with very little force. (You know you've got it when the hose clamp retained bellows easily reaches back onto the transmission housing and the swingarm pivot hole lines up with the corresponding hole in the frame):
    Austin, Texas 78753
    Currently:
    Previously:
    Austin, Texas USA
    Reinsert the swingarm pivot bolts, starting with the RH side (remember to put back in the sandwich washer), tighten until the pilot tip of the pivot bolt is engaging the pivot bearing in the frame. (Do not Torque down the swingarm pivot bolt yet):
    Austin, Texas 78753
    Currently:
    Previously:
  1. WTB: 98-2000 RSVR clutch push rod and adjuster
    By Jaypo in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 09-14-2013, 12:53 AM
  2. Replacement clutch perch and lever for Touno V4
    By Touchwood in forum 2012-2017 Tuono V4 - All Variants
    Last Post: 01-25-2013, 09:10 AM
  3. Clutch slave and line replacement question
    By NM Mille in forum SL1000 Falco Forum (all years)
    Last Post: 12-10-2011, 02:25 PM
  4. clutch pin/rod and barrel
    By scottyni in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 06-14-2009, 07:52 PM
  5. Head bearings and front brake pad replacement
    By 02Prilia in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-03-2003, 02:07 PM
