Page 2 of 2 FirstFirst 12
Results 16 to 23 of 23
Thread: Won't Start Intermitantly
    Nov 2015
    Wiltshire UK
    Quote Originally Posted by diegole View Post
    Any ideas
    I cleaned the started motor, switch/kill,,,,,,,
    https://youtu.be/d-btjv4iRNk
    Try keeping your thumb on the button for a few seconds after the starter cuts out. I bet it will turn over again.
    Worth a try.
    Mar 2015
    S.S. de los Reyes
    thanks for the reply.
    I have done that, press continuously, but do the same, after 8 or 10 attempts it starts normal.
    does it once every 30-50 days, without following a pattern
    Sep 2013
    Sydney, Australia
    Mine did that maybe 3-4 times and I had to give it some throttle to get it started. Almost like a carby bike lol
    Sep 2013
    Shropshire UK
    Quote Originally Posted by fredaroony View Post
    Plus 1. Mine has done this a hand full of times. Turns over but no start. I have to resort to some throttle while turning over. Splutters and clears with some gassing. Not very dignified. It does feel like a vapour lock in the FI.
    I have to say that although I get this and the stalled starter issues every so often, my bike has always started within a minute or so regardless. I have read that some Tuono V4's won't start from hot at all.
    Nov 2016
    Lincoln
    Regarding the kill switch, there is a delay on the 750 as well. It's something like half a second. If the computer knows where each stroke is, it counts a full cycle once every 85 milliseconds per cylinder at idle - why would it need to wait five whole cycles before stopping? I think the delay is just there to prevent accidental operation - remember early bikes had the combined starter / kill-switch and used the starter to cycle throttle maps.
    There is no cam position sensor, so I'm not sure how the ECU knows what stroke it's on anyway. I don't think it's that clever, personally.
    I think a lot of the reluctant starting issues are down to the starting sequence on the ECU itself (e.g. oil pressure interlock), sensor degradation and possibly also self-learning.
    2009 Shiver (White) | UK
    Jul 2017
    Yorkshire Coast
    At the end of the day, a 1200 Capo has a high compression engine with whopping 600cc pistons flying up and down My 1200 Guzzi sometimes struggled to start and occasionally blew a fuse when you pressed the starter. If it was the old days with kick starter technology only, I could imagine losing skin off my shins trying to start such a motor.
    40 odd powered two wheelers over 40 odd years. Currently in the garage are a 2016 Tuono V1100RR and a '79 Honda CB550F
    apriliaforum Member kostisfg's Avatar
    Mar 2015
    Greece
    I had the same problem and finally i solved. With a more powerfull batery.
    apriliaforum Junkie wthammond's Avatar
    Feb 2013
    Magnolia, TX
    I had a similar experience. I upgraded the stock Yuasa 14A with a 16 A designed for UTVs I think. Largely addressed the issue, but not 100%. Next battery will be LiOn.
    Quote Originally Posted by kostisfg View Post
    __________________________________________________ __________________________________________________ ____
    Current: 2015 Caponord, 2015 Moto Guzzi V7 Special
    Gone: 2009 Aprilia Mana 850,
    2001 Aprilia Scarabeo 50,
    2002 Futura
  1. Won't Start
    By 01RSVRrider in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-16-2003, 12:15 PM
  2. Help: Engine won't start
    By chikara111 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-30-2003, 07:54 PM
  3. new SR50 .. won't start! >:
    By falseguardian in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 06-26-2003, 07:47 AM
  4. Bike won't start, no spark, any ideas?
    By armourbl in forum RS50 Technical
    Last Post: 05-15-2003, 05:50 PM
  5. Scooter dies, won't start, then works fine, dies.........
    By Joseph Pagan in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 03-27-2003, 12:15 AM
