Results 1 to 15 of 15
Thread: Need some help
    Oct 2016
    Georgia
    Need some help
    Hello, I'm newbie im motorcycles. Recently I bought scooter Aprilia SR Sporter. It has 160km on speedo. Can anybody tell me please in what year scooter was released and how many "cc" it has.
    Top speed of my scooter is near 110km and fuel consumption 7-8L per 100km. Is it normal for this scooter? What speed and fuel consumption it must have?
    Jun 2013
    croatia
    the sr sporter was made in the 125 and 150 cc range produced between 99-01 but they were sold till 03
    for the right information check the VIN plate on which it says what year and what cc it has
    since it uses 7-8l its not really adjusted right
    it should be about 4.5-5.5l / 100km
    Oct 2016
    Georgia
    Quote Originally Posted by jog View Post
    VIN plate was changed I think not original
    VIN plate shows me 49.26cc on it.
    Well how is about top speed of my scooter in stock complectation? As I mentioned earlier scooter does not go more than 110 km.
    Jun 2013
    croatia
    when stock it goes up to 130 on the clock but 110 sounds like a healthy engine with just a worn belt weights and maybe a slightly clogged muffler
    Oct 2016
    Georgia
    What tire pressure is recommended for front and rear wheel?
    Jun 2013
    croatia
    1.8 bar front
    2.1 bar rear
    Oct 2016
    Georgia
    What oil is recommended to use: mineral, semi-synthetic oil, synthetic oil? Maybe specific brand, label? May I add new oil over old one If they are identical/not identical?
    Jun 2013
    croatia
    you can use a api tc, jaso fd standard oil (synthetic)
    preferably agip (eni) iride city hitec, or castrol power 1 racing (tts), also shell advance ultra 2 and motul 710 are proven to work excelent
    Oct 2016
    Georgia
    When I ride my Aprilia SR sporter with passenger behind (65kg), the shock absorber always knocks(strikes) when i even run into the very small pit. Is it normal or I have to replace it already? (SORRY FOR MY BAD ENGLISH)
    Can you recommend me the cheapest online shops where I can buy original or at least compatible spare parts for my scooter?
    Oct 2016
    Georgia
    Dec 2015
    Cambridge, MA
    you are bottoming out....you might want to think about getting a new shock....not a replacement one....i just measured mine original shock with the bike on the stand...i measured eye-to-eye, and looked online ...what part of the world will you want to order from?
    2003 Vespa ET2 50cc
    2001 Triumph TT600
    Oct 2016
    Georgia
    Quote Originally Posted by jixaw View Post
    I want to order from Georgia
    ontario
    try racingplanet or scoottuning.com. they are both in usa and have free shipping. you need to measure yours first. i think jixaw is still waiting for his new shock too. we looked at everything and we both decided the motoforce aluminum shock was a good choice at around 140usd.
    his was 285mm stock / the motoforce is 280mm mf88.88001 at scootertuning i think.
    Dec 2015
    Cambridge, MA
    Quote Originally Posted by kargaral View Post
    you mean Georgia near the Black Sea , correct?....i think Sublunacy thinks you mean Georgia, the city in the usa.....
    in europe try scooter-attack ...they are in germany
    2003 Vespa ET2 50cc
    2001 Triumph TT600
    ontario
    yeah i have family in georgia usa. try racing planet.uk maybe
  1. Need some help on power serge
    By jin88 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-14-2003, 02:47 PM
  2. Hey guys need some help on finding?
    Last Post: 08-15-2003, 01:21 AM
  3. Need some help with part sizes and torque specs.
    By Chief in forum SL1000 Falco Forum (all years)
    Last Post: 07-07-2003, 10:10 AM
  4. Need some help
    By jj008 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 05-14-2003, 11:30 AM
  5. Just pick up a 2001 Scarabeo, I need some help and advise
    Last Post: 04-28-2003, 05:16 AM
