Results 1 to 8 of 8
Thread: Another Gen 1/Gen 2 compatibility question
    apriliaforum newb Senzamike's Avatar
    Kansas City, MO
    Is there any difference between the gen 1/gen 2 cylinder jugs? Looking to do a one stop shop for some parts but need to verify that I can put gen 2 jugs on my Futura...
    Thanks!!
    Sweden, Linköping
    If you mean that gen 2 = single spark plug version, then the exhaust port is different.
    Can be more things as well.
    Kansas City, MO
    yes, I understood the heads were different... I'm referring to the cylinder jugs...
    Sweden, Linköping
    Check if the partnumbers are the same.
    Sweden, Linköping
    Checked it for you.
    The Futura and 2004 -2005 mille have matching partnumbers for cylinder and piston kit.
    apriliaforum Member Aprilia13's Avatar
    Pacific NW
    Ride smarter, not harder!
    Westminster, CA - USA
    The only difference between cylinders on the Gen1 and Gen2 engines is the color.
    Early Mille, Falco, Futura and Capo cylinders were painted a dark grey color, Gen2 cylinders are unpainted aluminum color.
    Other than the color, they are all identical and interchangeable.
    Jul 2009
    Gabro mentioned to me that from 2003 onwards the rear cylinders are stronger. Dunno if he meant the jug or the crankcase.
  1. another big bore gen 2 in the making
    By Chris Law in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 09-27-2014, 06:23 PM
  2. 2nd gen RSV race bike questions
    By aj_day in forum Aprilia Privateer / Club Racing
    Last Post: 07-07-2013, 06:14 PM
  3. Another F#$*&g sprag clutch question!!!
    By FalcoNero in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-16-2005, 03:19 PM
  4. New Futura Owner - Pannier Compatibility Question
    By HarryFutura in forum RST1000 Futura (all years)
    Last Post: 03-15-2005, 02:44 PM
  5. Another F#$*&g sprag clutch question!!!
    By FalcoNero in forum SL1000 Falco Forum (all years)
    Last Post: 03-09-2005, 04:06 PM
