Results 1 to 15 of 16
Thread: Fork Seals
    Jun 2006
    Columbus, GA
    2007 Tuono 1000R Factory
    Cored OE Racing Cans‡Map2‡Pazzo Knock-offs‡15-40‡AF1 Link Plates‡Aprilia Sliders
    Laminar Windscreen‡Lowered Pegs‡LED City and Tag Lights
    ProTaper Mini-Low‡Clear Signal Lenses
    Retired - DJ, Turntablist, Creator and Mixologist.
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Sweden, Linkφping
    If I still had the showa fork I would go with these http://www.motoracingshop.com/en/skf...st-inside.html
    All videos for this SKF seal, show a really low friction seal.
    Mods: Modified Φhlins fork from mille R, EBC brake discs, HEL front brakelines, Carbon RS 250 front fender, Wiring mod for charging. Engine related:05 map, Iridium plugs, tuneboy, derestriced intake, old mille airboot, staintunes exhaust. Lambda bung hardbrazed in the "breadbox". Φhlins mille R rear shock with 110N/mm spring and the integrated hydraulic preload adjuster. LED Voltmeter installed inside the dash for monitoring charging. Duc 999 radial m/c for brake and clutch. EBC 320mm brake discs
    PA USA
    and those videos speak volumes to just how slick/non-stick those seals are.
    Jun 2006
    Columbus, GA
    Quote Originally Posted by Fox Fader View Post
    Dang, you're making me want to spend more money.
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    PA USA
    On the flip side - All-Balls claims their seals have very little stiction. Not seen a side-by-side comparo, but they claim their seals are far slicker than OE.
    Jun 2006
    Columbus, GA
    I did elect to go with the All-Balls 56-133.
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    Jun 2006
    Columbus, GA
    All went well with the 56-133. The dust seal was tight and took a bit more work to get them seated.
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
    apriliaforum Member futura_fox's Avatar
    Feb 2015
    Kansas City, MO
    I'm in the process of trying to seat that duse wiper seal. Any pro-tips on how you got it in all the way?
    PA USA
    Quote Originally Posted by futura_fox View Post
    You can try warming them. It'll both make the rubber a bit softer and unlike metal, rubber actually contracts when it gets warm - think of fan belts that squeal when they're cold and then quiet down as they get warmed up and get tighter.
    Can also use a very light coat of oil on the outside of the seal to help it slide into place.
    Haven't done the Fut's seals, but my Yamaha's dust seals (not the oil seals) can just be pushed in by hand.
    Mar 2014
    California
    You need Eine Spritz.
    This is my best advice to the guys in the workshop, "du brauchst ein Spritz!" when they are struggling with a hose, fitting, bolt, or especially a rubber seal. Use a dab of WD-40 to wet the seal. WD-40 is a lousy long-term lubricant, but that's what I am counting on. Just wet the circumference, and the seal will scootch right in with minimal effort.
    Afterward, unlike when using silicone, the seal will stay in place nicely.
    Bob
    Jul 2017
    Vermont
    I just installed these on my Futura showa forks last weekend. They installed with little effort, but I have not ridden the bike since because winter has set in around here. Just wanted to let those interested in trying them that they do fit and install OK.
    Carthage, NC
    I use the All Balls seals all the time and have never had a problem with them .
    Ron
    MSgt USMC (Retired!)
    N2 CR
    WERA # 45
    IBA #38812
    RST Futura
    2007.5 Tuono
    Feb 2015
    Kansas City, MO
    Well, I tried and tried and could not get the dust seal to get seated. Even if I got it on most of the way it would pop off with movement of the fork. Definitely a manufacture defect.
    I googled and found on SV forum that they've had the same issue. One person even tried using a hydraulic press with no success! Someone said that All Balls corrected this problem with model number 56-133-1. No way to confirm this.
    http://www.svrider.com/forum/archive/index.php/t-165438.html
    I eventually gave up and shelled out the extra $$ on a set of the SKF seals. Dust seal pushed in with ease.
    Tried to save money and ended up wasting $25. Also All Balls doesn't refund or replace items purchased on ebay. FYI.
    Lesson learned...
    PA USA
    Lesson learned...
    Clearly, something was wrong with those seals. The oil seals take some persuasion to seat in place, but those dust seals should go in pretty easily.
    Jun 2006
    Columbus, GA
    I agree the dust seals should have fit in easier, but I did get mine to go. May have left a 1/2 mm gap, they went.
    Slammin' Tunes!
    HF152, 10-26954
    HF564 .024-.028
  1. Fork seals
    By falcofra in forum SL1000 Falco Forum (all years)
    Last Post: 05-10-2008, 12:57 PM
  2. fork seal help needed
    By doug in forum RS250
    Last Post: 08-10-2003, 04:52 PM
  3. blown fork seal
    By DesmoPilot in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-07-2003, 01:43 PM
  4. Ohlins Fork Seals?
    By curvecrazy1 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-19-2003, 07:35 PM
