Page 2 of 2 FirstFirst 12
Results 16 to 25 of 25
Thread: Confirmed fix for oil wicking thru stator wires
    Denver, CO
    Yes, as long as you mount the regulator up high on the frame. Use the two bolt holes where the charcoal canister was previously mounted.
    Run the yellow wires from the regulator across the top of the engine, just behind the radiator and above the exhaust.
    I now have my wiring routed this way and can confirm that the issue did not reappear after a track day; it's dry as a bone. Thanks for posting this!
    Oct 2015
    Tasmania
    Had my side & lower fairings off to give the inside a good clean & checked the stator connection.
    Oil wicking up to connector on RSV4RR with 4800km on clock,
    My dealer just lost Aprilia dealership; so currently nowhere to take it locally.
    Not that it should be necessary, it's a pretty easy fix, I hope.
    Lucky we have this forum.
    I rerouted as per amauri's instructions, hope that solves it.
    apriliaforum expert Turbinepilot2's Avatar
    Oct 2013
    Chicago Suburbs
    I've ridden it since the fix a bunch of times and so far no leaks still
    apriliaforum expert MishMashRSV4's Avatar
    Feb 2011
    Glendora, CA
    Just did this on a friend's 2014 Factory - He was having oil wicking. This solution appears to be working! Kudos again Amauri
    Oct 2015
    Tasmania
    1200km since rerouting including 2 track days (~200km), no more oil wicking.
    Such a simple thing to fix.
    Thanks again amauri.
    May 2016
    Ohio
    And one more success story hopefully.
    My new to me '13 RSV4 had this oil leak. At first, i thought it was coming from the motor itself since oil was on the inside fairing, and the motor.
    After seeing an accumulation of oil around the white/stator wire connector, I started the research and came across this thread.
    When I disconnected the connector, oil actually dripped out of the connectors.
    Wiring has been re-routed and zip tied back to keep away from exhaust.
    Current rigs:
    '16 Tuono RR -street
    '13 RSV4 -race
    '13 Harley Davidson Night Rod Special
    '13 Yamaha WR450F
    '12 GSXR 600 - race
    '07 GSXR 750 - race x 2
    '03 KDX 200
    '17 Tao Tao Hellcat - pit bike
    Sep 2017
    Fortuna California
    Hey folks..... day late here.... Been a lurker... first time posting.... Have this same exact issue on my 13 factory LE. gonna clean it up and move the wiring around and see if this cures the issue... had a few track days now and have had lots of oil all over my fairings.... thought it was weeping from above... looked at the loom and it kinda appeared a tad glossy like the oil was coming from the valve cover area... either way... had not had a chance to dig into this much. I looked at my stator thinking.... HUH.... cant be bleeding through the individual conductors from the stator winding now could it???? Well low and behold it looks like IM WRONG. I will clean up everything... again.. ugh... and re route the wires and see what gives. I hope this fixes it.
    I'll put a few hundred miles on it and see if it (gravity) fixes it. Thanks to all for posting up and helping find this "fix"
    Cheers, Wallace
    Westminster, CA - USA
    No need to report back in a few hundred miles.
    If your's is leaking oil thru the stator wires, the wire re-route will eliminate it.
    Even Aprilia has started re-routing the wires on the 2017 bikes now, takes them a little while to implement things like this.
    Sep 2017
    Fortuna California
    Excellent news Sir! thanks!
    May 2016
    Ohio
    Good for them that we have you and others to do the R & D for them. You're on Aprilia payroll right?
    Current rigs:
    '13 RSV4 -race
    '13 Yamaha WR450F
    '12 GSXR 600 - race
    '03 KDX 200
  1. Oil wicking through stator wires, '13 RSV4
    By Archilla in forum 2010-2018 RSV4 - All Variants
    Last Post: 09-18-2017, 11:29 AM
  2. oil in the stator wire insulation confirmed
    By argh in forum RST1000 Futura (all years)
    Last Post: 10-26-2015, 03:32 AM
  3. Possible fix for Puig windscreen damage?
    By Hejnfelt in forum 2010-2018 RSV4 - All Variants
    Last Post: 03-27-2015, 06:08 PM
  4. Oil leaks trough stator wires
    By TBW in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 07-13-2013, 10:42 AM
  5. Possible fix for starters burning up: Lithium batteries
    By grammerman in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 07-17-2011, 04:33 PM
