Results 1 to 15 of 25
Thread: Confirmed fix for oil wicking thru stator wires
    Westminster, CA - USA
    Many here have reported oil dripping from the stator wires at the white connector, just bellow the voltage regulator on the LH side panel. The oil is actually oozing it's way thru the inside of the wire between the plastic jacket and copper strands.
    Here is a link to the thread:
    http://www.apriliaforum.com/forums/s...hlight=wicking
    I'm also seeing a lot of RSV4s coming in for service with this same issue.
    What I am noticing is that only the late 2012+ RSV4s with the Kokusan stators are doing this. None of the 2010 & 11 bikes have this problem.
    I haven't seen this on any Tuono V4s yet, only on the RSV4-R and Factory.
    It was suggested by someone at Aprilia's Tech dept that the fix is to simply re-route the wire as it exits the stator cover and point it straight up as much as possible.
    At first I didn't think this was going to fix anything, but then I realized that the TV4 doesn't have the problem and it uses the same exact stator.
    The difference is that the TV4 voltage regulator is mounted up high and the wires are routed straight up as they exit the stator cover.
    Attached is a photo showing how I re-routed the stator wires on a couple of bikes that had been leaking quite a bit.
    So far they are no longer leaking and the white connector is dry.
    Just make sure you zip tie the wires to keep them away from the exhaust.
Name:	#stator wires.jpg
    apriliaforum expert MamboItaliono's Avatar
    Jan 2015
    Oahu, Hawaii
    Very cool
    apriliaforum expert gtpandrsvrguy's Avatar
    Mar 2006
    NH
    Thanks for the info. I'll remember this one for sure.
    Oct 2015
    Tasmania
    Excellent & logical, very simple use of gravity.
    Thanks for sharing amauri.
    Nov 2012
    united kingdom
    thank the lord !
    please let it solve the problem !
    apriliaforum Junkie apriliarsv1000r's Avatar
    Apr 2012
    Joplin, MO
    Finally a solution to this annoying problem. Hope it fixes it. Thanks, Amauri! I'll try and do this tonight and will report back in couple of weeks.
    2013 Aprilia RSV4 Factory APRC ABS SBK Special Edition
    2013 Specialized Stumpjumper Marathon Carbon 29
    2010 Cannondale Synapse
    2007.5 Aprilia RSV1000R - SOLD
    Oct 2013
    San Diego, CA
    That's awesome, thanks for posting Amauri. Any idea if there's enough wire to do this trick if the R/R is mounted to the other side of the bike (IE with track bodywork)?
    Quote Originally Posted by cmutza View Post
    Yes, as long as you mount the regulator up high on the frame. Use the two bolt holes where the charcoal canister was previously mounted.
    Run the yellow wires from the regulator across the top of the engine, just behind the radiator and above the exhaust.
    Quote Originally Posted by apriliarsv1000r View Post
    Great, please do try it and give us some feedback after a few long rides.
    Blueridge GA, USA
    Flowing solder into the stranded wire inside the end of the insulation, should help by forming a plug.
    Likely would require connector disassembly.
    '02 Futura, Blue
    94.5k miles and all is well.
    Apr 2012
    Joplin, MO
    Quote Originally Posted by rblue02 View Post
    I read someone tried it but didn't help.
    Apr 2012
    Joplin, MO
    Just rerouted the cable. Will let you guys know in couple of days if it worked or not.
    Apr 2012
    Joplin, MO
    It works! Been on couple of long rides and no oil wicking thru the stator wires. Thanks Amauri!
    apriliaforum expert Turbinepilot2's Avatar
    Oct 2013
    Chicago Suburbs
    possible fix for oil wicking thru stator wires
    Thanks for the info! I just rerouted mine today and went for a couple hour ride and no oil as well!
    Aug 2015
    Leander, Texas, USA
    Going to pop my left side off tomorrow and reroute mine.
    I was in there just recently and noticed this. I used the routing the shop manual recommends.
    It was covered in oil as well.
    I will report back and also provide info on this fix.
    Thank you Amauri for spending the time to debug this.
  1. Oil wicking through stator wires, '13 RSV4
    By Archilla in forum 2010-2018 RSV4 - All Variants
    Last Post: 09-18-2017, 11:29 AM
  2. oil in the stator wire insulation confirmed
    By argh in forum RST1000 Futura (all years)
    Last Post: 10-26-2015, 03:32 AM
  3. Possible fix for Puig windscreen damage?
    By Hejnfelt in forum 2010-2018 RSV4 - All Variants
    Last Post: 03-27-2015, 06:08 PM
  4. Oil leaks trough stator wires
    By TBW in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 07-13-2013, 10:42 AM
  5. Possible fix for starters burning up: Lithium batteries
    By grammerman in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 07-17-2011, 04:33 PM
