Results 1 to 10 of 10
Thread: Mana "Gear" issues
    May 2016
    Dover uk
    Mana "Gear" issues
    Evening guys,
    help needed.
    bought my mana couple of month ago.
    Last couple of days been having "Gear" warning issues.
    GEAR SYMBOL and warning light will come on 2-3 times during a 20mile journey.
    the bike will not change up or down and will be stuck in the gear it was in when it goes into GEAR warning.
    seems to happen at random intervals, mainly after hard acceleration and the easing off slightly or at around a70-90mph constant speed.
    bike will come up with GEAR SYMBOL and will be stuck in the gear it was in. When you come to A stop the bike wants to lurch forward. I then have to switch off and back on sometimes several times to reset it.
    apriliaforum prov-nov Gdaz's Avatar
    Oct 2015
    Australia
    Search this forum for "Variator Threads" or "Greasing Variator Threads". If your bike is an early model it is likely that this may be the cause. If you got it from a dealer, take it back under your warranty and have them perform the work for you (if as in Australia, you get a 3 month warranty on second hand motor vehicles from a dealer).
    May 2016
    Dover uk
    Thanks for the reply.
    been away, just got back and stripped the cvt.
    there seemed to be grease in the variator threads. Cleaned it out and re greased. All back together and taken for a run. No change. Gear light comes on, no rain, touring or sport showing, just the gear symbols. Any other thoughts?
    Mar 2012
    United States
    Hey, welcome to the club (
    i am suffering from the same thing for a year or two....
    there was a guy from Luxembourg (if i remember right) who manage to get rid of it by changing potentiometer but this requires to retrain TCU while here in Michigan I have no Aprilia service (so no aprilia diagnostic tools) at all......
    Dec 2014
    Chelmsford, Essex, UK
    Hi Guys, if you have no other apparent symptoms of belt wear or variator problems this might be the relay that switches things. It has been the subject of several threads on here and I tracked down a link to one of them for you.
    http://www.apriliaforum.com/forums/s...ghlight=relais
    Mar 2012
    United States
    i have changed this thing already and overall transmission behavior became somehow smoother however "gear" still persists....
    Mar 2012
    United States
    Hi Pharao,
    i am thinking about the same thing and I even purchased a new sensor, but in order to replace it I have to retrain TCU.... but since I have no Aprilia service around me I got stuck.....
    in the dealership where I purchased my MANA the only think they have is GameBoy for aprilia scooters but I doubt it has TCU retraining option....
    May 2016
    Dover uk
    Update,
    the bike has has been sorted.
    several resets and software updates later.
    the issue was found.
    the platic transmission shaft inside the transmission was bent, and the two bearings worn either end, probably done at the the belt service.
    Bearings and shaft replaced and it's all good.
    i know I have seen posts about the same issue, get a mechanic to check this, it solved my issues and now have a very happy Mana
    apriliaforum newb dhodesigns's Avatar
    Oct 2014
    Seattle, WA - USA
    Requesting your insight on this problem you got fixed.
    Quote Originally Posted by Gumball View Post
    Update,
    My 2009 Mana recently went through what you had discribed. I sent my local Aprilia mechanic this thread but we are a bit unclear on which part you got replaced to solve the problem. Can you please take a look at the attached image and see if you can point out which part you mentioned. Thanks so much.
    dho
    apriliaforum prov-nov jpsplus's Avatar
    Aug 2009
    Athens, Greece
    the only plastic shaft in this region is:Name:  intermediate shaft.jpg
    please correct me if I am wrong
  1. Stage 6 13/39 Gear set issue.
    By Rosscofat in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 10-01-2012, 08:07 PM
  2. gear box issues
    By woftam1 in forum RS250
    Last Post: 10-20-2011, 01:49 AM
  3. Gear selection issues - Solved
    By Hinckley in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 12-02-2010, 01:28 PM
  4. Gear Box Issues
    By Brain_stew87 in forum RS125 Euro-archive
    Last Post: 10-07-2007, 03:22 PM
  5. Gear box issue
    By ismell33 in forum RS125 Euro-archive
    Last Post: 04-18-2007, 07:45 AM
