Results 16 to 19 of 19
Thread: Modified Ignition Coils
    apriliaforum Junkie pugwash's Avatar
    Jun 2008
    Selby, North Yorks, England
    Quote Originally Posted by FuturaWales View Post
    I bought 4x Peugeot v6 coils, which i thought were the same as the Citroen ones, but the spark end connector looks like this.
    Clearly this cannot connect to the HT lead in the same was as there is no pin.
    Do the ones you have referenced to have the pin, and the only difference is that they are shorter on the end? Can someone send a picture to confirm?
    That was I can maybe just buy the correct ones instead of trying to modify these ones.
    Sent from my SM-G955F using Tapatalk
    The ones I bought had a stepped pin for the HT contact same as the Aprilia coils and only difference was the length of the coil end. However I have since done another coil and that one just had a flat plate for the HT lead to connect to, some folk have soldered a brass screw in there to create the peg but I just cut up an old Aprilia coil and managed to extract the brass HT connector and just swapped this to the new coil.
    Incidentally Carparts4U who supplied my coils were having a sale the other day with 20% off so if that's still on new coils are even cheaper.
    Pugwash
    Remember, you cannot outrun a motorola!
    2003 Caponord
    2007 FJR1300AS
    2010 KLX250
    apriliaforum prov-nov FuturaWales's Avatar
    May 2017
    Neath, Wales
    Ok, thanks.
    Suppose it's a bit hit and miss then on the coils.
    When you cut the old one up, how did you go about attaching that end to the new coil?
    Soldering?
    2002 Flame red RST1000 Futura
    StainTunes Exhaust
    Wilbers Rear Shock (high/low rebound and preload adjustable)
    Brown plug removed - 13.9v currently
    05 map (staintunes with baffles)
    DIN/Hella 12v power outlet
    X-grip phone holder with built in charger
    Jun 2008
    The brass connector from the old coil was an interference fit into the new one so just pressed it into place same as original.
    Pugwash
    2003 Caponord
    2007 FJR1300AS
    2010 KLX250
    May 2017
    Neath, Wales
    Quote Originally Posted by pugwash View Post
    Pugwash
    Ok, thanks
    StainTunes Exhaust
  1. ignition coils
    By darren in forum RS125 Euro-archive
    Last Post: 02-05-2006, 05:56 PM
  2. Ignition coil replacement
    By drkecskes in forum RST1000 Futura (all years)
    Last Post: 01-22-2005, 12:27 PM
  3. Need ignition coils in the US for Cup Bike
    By WERA 365 in forum RS250
    Last Post: 11-18-2004, 05:10 PM
  4. ReCoil, Ignition coil, that is
    By Blue Liter in forum RST1000 Futura (all years)
    Last Post: 10-28-2003, 04:01 PM
  5. Fuel Pressure Modifier/Ignition Amp - Opinions?
    By hank in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-10-2003, 07:33 PM
