Results 1 to 15 of 19
Thread: Modified Ignition Coils
    apriliaforum Junkie pugwash's Avatar
    Selby, North Yorks, England
    Ok there has been some discussion on here of late about alternative coils and how to make them work on our beloved caponords. Over 2 years ago I modified some Renualt V6 pencil coils to fit as others had done however I believe I did the HT lead end differently to how some have and seeing as mine have been fine for some time now even in the sunny weather we get in Yorkshire (!) I guess it was a successful way to go and thought it was time to share this.
    Right before I start if you want to go monkeying around with your bikes ignition system feel free to follow my way however if you get it wrong or don't win the lottery this week don't blame me!!!
    I decided to make up a spare coil as I'm off on a big euro trip, two up, as far as Italy this year and working on the principle that if I have a spare with me I won't need it thought it a good idea to do this. I used a Haas coil part number 413 74 5171 and bought this online for just over £18 delivered, I take no credit for working out these work on our bikes but the low tension connection is identical so no bike wiring mods are needed.
    New coil alongside a standard Sagem coil.
    First thing is to remove the HT rubber boot and contact spring from the new coil.
    As you can see the HT connection at the bottom of the new coil is much shorter that the OE one and this is where my way to mod a coil differs I believe, what I do is make a sleeve to fit on the new coil to make the dimensions the same as the OE unit and to do this I use......
    One of these, a simple cartridge nozzle, first thing to do is drill out the threaded opening until its a nice snug fit over the base of the new coil. To do this I use a cone drill and just drill out the first couple of threads.
    When this is a nice snug fit I cut off the nozzle at the required length so when fitted to the new coil it is the same length as the OE one.
    I then superglue the sleeve onto the base of the new coil, then I cut off the redundant mounting bracket off the new coil and dress the cut up with a file to smooth the body up.
    I also cut off the LT connection webbing as it stops the rubber mounting boot going on fully.
    Wrap some insulation tape around the top of the sleeve and swap the rubber boot over from the old coil and your done!
    Now I go one step further and wrap my spare coil in plastic bags like this
    And then cable tie it to my Givi pannier rack support behind my number plate
    You can just see it in this photo, its out the way and protected from the elements by the bags, I have carried one of my old coils as a spare there for years with no issues.
    Total time to do all this is less than half an hour and total saving against a new OE coil is massive! I have moved the front coils to the back on my bike and made a bracket up to carry them at the back of the fuel tank. All I have to do now to change any coil is remove riders seat and I believe I could change a coil out at the side of the road in less than 45mins using the one stashed on my pannier support.
    Pugwash
    Remember, you cannot outrun a motorola!
    2003 Caponord
    2007 FJR1300AS
    2010 KLX250
    May 2008
    GREECE
    The coil's ht connection seems very similar to the new aprilia coils
    https://www.pols.gr/poll-pl-si-stes-...a.html?search=
    Jun 2010
    Netherlands & Türkiye
    Quote Originally Posted by bros400pgm View Post
    that webshop sells a car coil with a cutted off mounting bracket
    01 Futura [infinity blue]
    apriliaforum expert Dogslobber's Avatar
    Aug 2013
    Alaska
    Thanks for posting the detailed process. I don't think we can have enough detailed threads on how to fit different coils.
    May 2008
    GREECE
    That coil is oem aprilia... Probably aprilia watched the forum
    Sweden, Linköping
    So It seems the part number is AP81248646.
    There is also a AP8124864-W1 which comes with a new lead which may be something the German distributor wedel came up with.
    Mar 2016
    Greece
    I hope this is the correct thread(since it says "modified"),now to the message.
    Since my capo burned the rear cylinder coils and had them changed with used jcis,I also bought 2 after market renault megane ones.the problem with them is that they use a different connector,so I've been wondering whether there are male-female connectors of the coils the capo uses.
    So what type of connector do the capo coils use?
    And what type of connector does the megane?
    Otherwise they are perfect much and way cheaper!
    Στάλθηκε από το SM-G950F μου χρησιμοποιώντας Tapatalk
    apriliaforum expert Prankster's Avatar
    Jan 2006
    Ponca City, Oklahoma, USA
ID:	340751Click image for larger version.
    I wonder if this ford coil would work.
    Loki J. Prankster
    In my life, it's not the choices I make, it's the chances I take that influence my life the most.
    Quote Originally Posted by Ksaplostra View Post
    The coils I used had been found to have the same LT wiring connection and the coils primary resistance was within the specs for an Aprilia coil the only difference being the additional mounting points for its use on a car engine.
    Since I did my write up there has been a lot of development done by others into mounting coils directly onto the spark plug, I would suggest looking up the thread about teaching a caponord Japanese for more info on this.
    Good luck 🍀
    Pugwash
    2003 Caponord
    2007 FJR1300AS
    2010 KLX250
    apriliaforum expert ravenranger's Avatar
    May 2012
    AZ
    Quote Originally Posted by Prankster View Post
    I wondered about those, too. Especially for those of us on this side of the pond. I looked at those when I was doing my Japanese coil mod and debated trying them. If they did work, they're definitely a cheap replacement and easily sourced.
    2006 Caponord • 2006 crashed ST1300 • 1989 NX250
    IBA#22798 • AMA#601202
    apriliaforum Member bkmo's Avatar
    May 2016
    Costa Rica
    I don't think they will work, this is from AEM.........The model 30-2850 & 30-2851 CDI Pencil Coils are specially designed for use with high energy CDI systems on doubleoverhead cam engines. DO NOT USE THESE COILS WITHOUT A CDI SYSTEM. Attempting to use these in a dwellcontrolled system (inductive) WILL destroy your ignition amplifier.
    I wonder if this is the reason some get EFI flashing on decel....... Make sure to apply a liberal amount of dielectric grease to the connector terminals and thetip and body of the spark plugs. Failure to do this may cause arcs to the cylinder head and cause a misfire.
    Mar 2016
    Greece
    Quote Originally Posted by bkmo View Post
    But clio v6 coils are ok right?
    May 2016
    Costa Rica
    You should be able to plug your original coil connector directly into this coil. All the V6 3.0L coils (renault, citroen etc.) should work.
    Mar 2016
    Greece
    Phew I thought I wasted 50€
    apriliaforum prov-nov FuturaWales's Avatar
    May 2017
    Neath, Wales
    I bought 4x Peugeot v6 coils, which i thought were the same as the Citroen ones, but the spark end connector looks like this.
    Clearly this cannot connect to the HT lead in the same was as there is no pin.
    Do the ones you have referenced to have the pin, and the only difference is that they are shorter on the end? Can someone send a picture to confirm?
    That was I can maybe just buy the correct ones instead of trying to modify these ones.
    Sent from my SM-G955F using Tapatalk
    2002 Flame red RST1000 Futura
    StainTunes Exhaust
    Wilbers Rear Shock (high/low rebound and preload adjustable)
    Brown plug removed - 13.9v currently
    05 map (staintunes with baffles)
    DIN/Hella 12v power outlet
    X-grip phone holder with built in charger
  1. ignition coils
    By darren in forum RS125 Euro-archive
    Last Post: 02-05-2006, 05:56 PM
  2. Ignition coil replacement
    By drkecskes in forum RST1000 Futura (all years)
    Last Post: 01-22-2005, 12:27 PM
  3. Need ignition coils in the US for Cup Bike
    By WERA 365 in forum RS250
    Last Post: 11-18-2004, 05:10 PM
  4. ReCoil, Ignition coil, that is
    By Blue Liter in forum RST1000 Futura (all years)
    Last Post: 10-28-2003, 04:01 PM
  5. Fuel Pressure Modifier/Ignition Amp - Opinions?
    By hank in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 10-10-2003, 07:33 PM
