Results 1 to 7 of 7
Thread: lost front cylinder fire time to time
    Jul 2013
    canada
    hi
    its me again so after my rebuild the rpm in idle go to 2100rpm to 3200rpm and i just found out why i lost front fire i go to a litel street test ride and wen the front got the fire man this ting is crazy but then burrrrr no more front cylender and im in a drz400 :P and i broke my gasket again .... the front coil is brand new i realy dont know what the problem , it was doing this beafor i rebuild it (gasket broked) and i change everyting piston liner valve crank bearing. i know the motor is ok
    san francisco
    Sounds like either spark or fuel. I would try swapping injectors between cylinders or coils?
    Jul 2013
    canada
    and now my starter just die LOL i just put 3k in the motor man.... wen i will finish everyting will be new on this bike lol
    Jul 2013
    canada
    so after i put the motor on my work table again... i found that its my front cylinder that the head gasket broke so my guess is that the front work good and its the rear one that i lost fire time to time so all the load go to the front and eventualy the gasket broke so i just put a new order on aprilia superstore :P for a nice new starter and coil and gasket lol so i will try this in 2 week :P wen i will have the parts.
    by the way wen i removed the sparkplug cap some of the internal part of the cap stayed on the sparkplug so maybe sometime it was doing some good contac and sometime not. o well i hope its just that. im looking for a used injector to , just to be sure its not that.
    apriliaforum Junkie Sxv rider's Avatar
    Sep 2012
    New south wales
    The spark plug caps are known to break that would be part of the problem I'd say, i had similar happen to me the bike had a definite miss when idling once o put a new plug cap on it it was fine.
    Aug 2007
    Baltimore, Md
    As to the broken gasket and which cylinder lost fire, I am not sure your theory holds water. I would suggest you guess less. If you are running on one cylinder you can spray fluid, like water, on to the head pipes where they come off the head to see which one is colder. The colder one is the one that is not firing. If you don't have something to spray on it, spit on it. But being sure of which cylinder is dropping should go a long way towards helping you figure out why.
    Jul 2013
    canada
    yea i will for sure wen the part come in i will make more test. but like i sai the front coil and plug are brandnew and wen the gasket broke the exhause smoked whit like hell lol so the front one was hot enought to eveporate prestone and the front exhaust pipe was full of water after it cooled.
  1. New rebuild-ed Aprilia SXV 4.5 tilting on rear cylinder form time to time
    By Akigarfield in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 12-15-2016, 04:22 PM
  2. 0-60 times (immature?) - time to be honest guys...
    By Charles in forum RS50 Technical
    Last Post: 01-28-2006, 06:20 PM
  3. Time to join the fray (of SQUIDS that is?)
    By 2pist in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-27-2003, 05:35 PM
  4. Time to install a clutch...any tips or tricks?
    By Smoke Eater 41 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-19-2003, 01:08 PM
  5. Nearly time to de-restrict
    By DolbyGuy in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-18-2003, 09:34 AM
