Results 16 to 20 of 20
Thread: Handlebar options - Pro taper Carmichael bend
    apriliaforum expert redratbike's Avatar
    Oct 2009
    with my modded collectors,Kent,UK
    If you have clearance issues make some adjustable lockstops Click image for larger version.
    please get in touch if you would like a modded collector,adjustable lock-stops or quick release tank and seat pins
    apriliaforum prov-nov mrk_d's Avatar
    Sep 2013
    Santa Barbara, CA
    Quote Originally Posted by redratbike View Post
    I've been thinking about getting something like these B&G stoppers
    but that looks clean...I'll drop a line now.
    EDIT: Can't seem to send you a PM, maybe I don't have enough posts. How much do your adjustable stops run and will you ship to the US?
    apriliaforum Junkie alleycatdad's Avatar
    Nov 2014
    Real Northern CA. Not the freaking bay...
    Wheel weights on the stops will reduce turning angle in give you more clearance. Cheap and fast way to see if you can live with it.
    apriliaforum Member tipper63's Avatar
    Feb 2014
    New Zealand
    Quote Originally Posted by speedfiend41 View Post
    As requested. It's hard to get a shot that shows the whole bar at the right angle. They're perfect for me though, and somehow by being pulled forward I feel a lot more 'in' the bike.
    How did you mount the factory bar weights??
    2003 Tuono Racing, Tigcraft Ti can, collector modifed, Gabro F255 chip, 16/43
    2016 Tuono Factory, only mod is a Radar detector!!
    Sep 2013
    Santa Barbara, CA
    Late update but if anyone's on the fence, I can't recommend redratbike's adjustable lockstops enough. They work great and made it possible to fit the Carmichael bend bars.
    For my bar ends, I used the G2 threaded bar end mount. You tap the bars, then install a threaded (on the inside and outside) nylon rod into which the bar end bolt is installed. Works well and they haven't loosened up on me yet, but they take an 8mm bolt so the stock bar ends won't work with this system. It's a nice way to go for Rhinomoto bar ends, though.
  1. Best Pro Taper bend + risers for Capo?
    By Kelt Kurmudgeon in forum ETV1000 CapoNord (2001-2007)
    Last Post: 10-10-2012, 04:53 PM
  2. Pro Taper?
    By Mr SXV in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 11-21-2007, 09:02 AM
  3. RENTHAL or PRO TAPER ?
    By ADROCK in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 11-20-2007, 05:30 AM
  4. Caponord Pro Taper Bars
    By geoprofjon in forum ETV1000 CapoNord (2001-2007)
    Last Post: 07-29-2005, 07:03 PM
  5. Handlebar Options
    By DeTuono in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-30-2004, 02:40 AM
