Page 1 of 3 123 LastLast
Results 1 to 15 of 39
Thread: DD1200 ecu reflash
    Roma, Caput Mundi
    DD1200 ecu reflash
    Just did my first DD1200 yesterday
    after 2 years working on RSV4/TuonoV4 (same ECU), finally got occasion to work over one ot this big twins
    Used lastes 1338EA7 map as base.
    Bike had de-katted Arrow silencers and DNA stage2 filter. Here below the results (did not yet did individual cylinder mapping with 2 wideband lambda's, will do that today. Yesterday i've only used one wideband):
    www.gabroracingteam.it
    Visit my FB page and like it!
    Roma, Caput Mundi
    here a small video too
    https://youtu.be/SAVHzmupAoc
    Roma, Caput Mundi
    as you can see in the first picture, bike arrived on the dyno with 15w50 Motul V300 oil... it was a lot noisy after some pulls, so we did an oli change on the dyno using fresh ENI 10w60. Way better sounding motor!
    apriliaforum expert lanter's Avatar
    May 2009
    Guilford CT
    Those numbers look good! Awesome!
    2011 Dorsoduro 1200
    Roma, Caput Mundi
    here some ignition timing trick in the upper revs:
    Roma, Caput Mundi
    i was expecting a bit more excitment
    apriliaforum Member Mike06's Avatar
    Sep 2013
    La Gaude (France)
    Roma is too far for me, i'm in Nice (France) near the italian frontier ! Maybe one day you'll go to my area for some remapping sessions...
    2016 Aprilia Tuono V4 1100 RR Portimao grey
    Aug 2014
    Sverige
    Great job!
    What can you do with a Caponord 1200?
    Maybe it will be worth a trip from sweden to Roma!
    Roma, Caput Mundi
    Yes, i'm tooled for it. I've already did a test re-flash over a Caponord in February, but i'm still searching for a test-bike to finalize the base tuning over my dyno.
    it's all the same Marelli 7SM ecu family, not much differences from the RSV4 ecu, even the Traction control mapping is similar. Once done with the Caponord i'll move to the Guzzi Caliafornia 1400 re-flash (basically same ecu too).
    Dec 2013
    Canberra, Australia
    It would be interesting to see what gains could be made with standard exhaust and air filter versus this bike.
    Roma, Caput Mundi
    will do at first occasion!
    Jul 2004
    geyserville,ca
    Now, how to export this to the states??
    Roma, Caput Mundi
    ship-in / ship-out.
    here a datalog screenshot from dyno wide open throttle pulls: in yellow RPM and AFR from stock map comparing with the graph in pink were RPM and AFR are from one on my early stage map with ignition advance and throttle openings still not changed, but fueling roughly adjusted, and rised rev limiter. wideband lambda probe fitted in the exhaust Y prior of the Arrow cans.
    You can see how lean is the motor with the stock map in the lower rpm range, but fueling is about spot-on above 7500 rpm:
    apriliaforum Junkie spank36's Avatar
    Mar 2012
    Australia
    Do you think economy would be improved?
    Current bikes - 2012 Tuono V4
    Blog/Website - www.onthebackwheel.com
    May 2009
    Guilford CT
    Whats the turn around time?
    2011 Dorsoduro 1200
  1. Ecu reflash
    By unofear in forum 2006+ Pegaso Trail / Strada / Factory
    Last Post: 04-27-2017, 01:28 PM
  2. ECU reflash
    By bstar360 in forum 2010-2018 RSV4 - All Variants
    Last Post: 08-12-2011, 03:40 AM
  3. Removing ECU for reflash, do I need to "disconnect" it from the dash first?
    By waxfang in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-20-2009, 07:47 PM
  4. Pegaso i.e. ECU adjusting knob
    By takisgr in forum Pegaso 650 Cube and IE
    Last Post: 09-23-2002, 01:57 AM
  5. ECU UNIT
    By DKELLNERTRIADRRCOM in forum ETV1000 CapoNord (2001-2007)
    Last Post: 04-03-2002, 08:37 PM
