Results 1 to 9 of 9
Thread: Stainless steel bolts
    Jul 2009
    Hi I'm looking into replacing some of the non-load bearing OEM bolts with stainless ones. Has to be A316 quality (A4 it's called). I don't want to pay Pro Bolt prices though.
    It's difficult to find Flanged Hexagon bolts in A316 though. I found this place on Ebay UK (I'm from the Netherlands). I'm wondering if anyone has experience in dealing with them.
    http://stores.ebay.co.uk/AccuGroup
    apriliaforum expert old git's Avatar
    Sep 2009
    Worcester, UK
    know I will get flamed for this, but ive used A2-70 on both the future & Falco, without issue.
    Your bike, its up to you but I cant believe 10+ year old corroded original bolts are better than new stainless whatever grade
    Just my 2p worth
    Fire Red Falco, my 1st Love.
    sidestand mod (Hayabusa), charging mod, larger sealed airbox, Gabro chip lower Buell rider pegs, braided lines, custom rider seat, home brew hard panniers, OHlins bouncer
    Add Two Tone RS Touring Futura'04, knock-off levers, charging mod, 05map, NWS hugger, Ohlins shock, 12v socket, lowered rider pegs, 848 twin exhausts, revamped plate hanger with pannier support.
    What's not to love!!.er
    Jul 2009
    Oh it's got to be a316 (AKA A4) for sure. Haven't figured out the thread specs though (fine, metric blabla etc).
    Jan 2015
    Midlands (UK)
    Old thread, but just for the record, A2 stainless is more than adequate for motorbike bolts. A4 (A316) is marine grade, which is ideal if you want to immerse your bike in the sea... but that will wreck your bike anyway... even though the bolts will still be corrosion free!!
    Jun 2016
    North Yorkshire, England.
    A2...A4, that's just the corrosion resistance grade of SS. More important is the -70, -80 digits, as these indicate the tensile strength of the metal.
    Dependent on where you're fitting the fastener, I'd say this is the number you should be thinking about.
    A4-80 is equivalent to 8.8 carbon steel, tensile strength wise...remember all the Jap bikes of old that had 8.8 embossed on their bolt heads?
    Jul 2009
    My bolts are mostly a4-70. Have a hard time finding 80. I believe even Pro-Bolt is grade a4-70.
    apriliaforum expert J.R. Bob Dobbs's Avatar
    Aug 2008
    McGaheysville, Va
    That's because, generally, Stainless steel is not as strong as Carbon steel.
    Jap bikes suck.
    Aug 2006
    Santa Cruz, CA
    <?xml version="1.0" encoding="ISO-8859-1"?>
    -<VDoc VehicleIdentificationNumber="1D4HD48D05F563997" DateCreated="07/28/2016 03:36PM" VATDatabaseName="NDOVR0GB.VAT" SoftwareBuildNumber="1.6.0.17402 US" SoftwareBundleNumber="16.2" PlatformSerialNumber="116SLE541963" PlatformName="SOLUSEDGE">
    -<VDocSection Name="COMPONENTDATA">
    -<DataItems attributeName="ActionSelection" componentName="Scanner">
    <Item value="Dodge" name="MAKE"/>
    <Item value="2005" name="YEAR"/>
    <Item value="Durango (RWD)" name="MODEL"/>
    <Item value="5.7L V8 MPI" name="ENGINE"/>
    <Item value="CCN" name="SYSTEM"/>
    <Item value="" name="BEN"/>
    </DataItems>
    -<DataItems attributeName="CodesDisplay" componentName="Scanner">
    <Item value="2005 Dodge Durango (RWD) 5.7L V8 MPI " name="TitleBar"/>
    <Item value="" name="InfoBar"/>
    </DataItems>
    -<DataItems attributeName="Codes" componentName="Scanner">
    <Item value="Systems detected : 11" name=""/>
    <Item value="Engine - Codes : 2" name=""/>
    <Item value="Transmission - Codes : 1" name=""/>
    <Item value="Antilock Brakes - Codes : 0" name=""/>
    <Item value="Airbag - Codes : 5" name=""/>
    <Item value="Central Gateway - Codes : 0" name=""/>
    <Item value="Heat Ventilation A/C - Codes : 0" name=""/>
    <Item value="Instrument Cluster Module - Codes : 8" name=""/>
    <Item value="Occupant Classification Module - Codes : 0" name=""/>
    <Item value="Radio - Codes : 2" name=""/>
    <Item value="Tire Pressure Monitor - Codes : 0" name=""/>
    <Item value="Wireless Control Module - Codes : 0" name=""/>
    <Item value="" name=""/>
    <Item value="Engine" name=""/>
    <Item value="EGR Position Sensor Circuit High" name="P0406"/>
    <Item value="O2 Sensor 2/1 Circuit High" name="P0152"/>
    <Item value="Transmission" name=""/>
    <Item value="Battery Was Disconnected - Stored" name="P1684"/>
    <Item value="Airbag" name=""/>
    <Item value="CAN B Bus - Stored" name="U0019"/>
    <Item value="Battery Voltage Low - Stored" name="B210D"/>
    <Item value="Occupant Classification Undetermined - Stored" name="B1BA6"/>
    <Item value="Occupant Classification Module (OCM) DTC Present - Stored" name="B223D"/>
    <Item value="Ignition Run Only Input Circuit Open - Stored" name="B212D"/>
    <Item value="Instrument Cluster Module" name=""/>
    <Item value="Cargo Lamp Control Circuit Open" name="B1629"/>
    <Item value="Right Heated Seat Low Indicator Control Circuit Low" name="B1221"/>
    <Item value="Right Heated Seat High Indicator Control Circuit Low" name="B1219"/>
    <Item value="Left Heated Seat Low Indicator Control Circuit Low" name="B1215"/>
    <Item value="Left Heated Seat High Indicator Control Circuit Low" name="B120D"/>
    <Item value="Right Heated Seat Switch Input Circuit Low" name="B1088"/>
    <Item value="Left Heated Seat Switch Input Circuit Low" name="B1085"/>
    <Item value="Transfer Case Range Select Switch Circuit High" name="C1402"/>
    <Item value="Radio" name=""/>
    <Item value="Audio CD Read Error / Inoperable Disc - Active" name="B1421"/>
    <Item value="Lost Communication With Sunroof Control Module - Active" name="U0169"/>
    </DataItems>
    </VDocSection>
    </VDoc>
    Jun 2016
    Quote Originally Posted by Yzf600r View Post
    Westfield Fasteners (UK) supply A4-80 spec stainless fasteners in most sizes, but not 10mm x 1.25mm pitch (metric fine), which I was hoping to replace the front brake caliper mounting bolts with. As I'm not happy using -70 for caliper mounts, I'll buy new original bolts.
  1. Stainless Steel Bolts?
    By mrmoog in forum 2006-2011 Aprilia RXV, SXV, MXV 4.5/5.5 V-Twins
    Last Post: 10-22-2010, 09:16 PM
  2. Stainless Steel Bolts
    By RH_SCOTLAND in forum ETV1000 CapoNord (2001-2007)
    Last Post: 03-14-2010, 12:22 PM
  3. Aprilia racing stainless steel bolts kit for Tuono..
    By SkiN in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 03-06-2007, 07:36 AM
  4. stainless steel bolt torque settings
    By johnr in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 01-20-2007, 02:26 PM
  5. WANTED: Stainless steel disk bolts
    By Deadlock in forum RS125 Euro-archive
    Last Post: 04-01-2006, 01:36 PM
