Page 5 of 126 FirstFirst ... 345671555105 ... LastLast
Results 61 to 75 of 1890
Thread: What have you done to your Caponord today?
  1. #61
    Jun 2014
    Ipswich, UK
    Pictures!
  2. #62
    Jun 2014
    Ipswich, UK
    First, I fitted a new radiator protector to protect, in particular, the lower oil radiator. As you can see from the first photo, the short length of the front mudguard results in a lot of mess hitting both radiators and there's already some minor damage at the bottom of the oil radiator.
    Before
    After
    [/QUOTE]
    New extended mudguard is on order.
    Then, I got it on the road for the first time in 2015 and gave it an Italian tuneup
  3. #63
    Jun 2014
    Surrey, UK.
    Today I fitted a 44 Tooth rear sprocket. Noticeable improvement, no more need to slip the clutch out of slow corners and round roundabouts. Quite pleased with that.
    My mods so far:
    MRA X-Screen with sport spoiler, cured the buffeting and noise.
    Garmin 390LM fitted using Engimoto mount, used bikes power cable modified to take Garmin plug.
    R&G Radiator and oil cooler screen, essential I think.
    Fiamm AM80S horn, replaces the original child's toy supplied!
    Ultimate Add-ons phone holder and power cable with RAM mount.
    Sent from my iPad using Tapatalk
  4. #64
    Jun 2014
    Ipswich, UK
    What does that sprocket do to the top end speed?
  5. #65
    Jun 2014
    Surrey, UK.
    Quote Originally Posted by GregKingston View Post
    I don't think it'll make a big difference, I rarely go near top speed what with speed cameras etc. it does make it more pleasant to ride and sixth is less of an overdrive gear.
  6. #66
    Jul 2008
    Mare Island, Ca. USA
    I commuted to work and back in the sf bay area, 80+/- miles. Richmond to san mateo and back. this capo is really an awesome commute bike. the cruise control really save on gas. i ride with side cases and little red top box. filtering is not an issue. prius drivers are the issue.
    i actually commute every day on the capo. my 40-60 minutes each way would be 1.5-2.5 more time in a cage.
    Dadsafrantic
    2015 Red Caponord #64
  7. #67
    apriliaforum prov-nov motojo's Avatar
    Aug 2014
    Eureka, Calif.
    B787MECH, I would like to go with a larger rear sprocket also. Can you tell me, is it a simple unbolt and replace? Do you know of any instructions I should read? And last, did the stock chain work? Thanx, joe
  8. #68
    Sep 2013
    Sydney, Australia
    Quote Originally Posted by motojo View Post
    Please don't take this as being rude but if you don't know how either get a friend to show you or get a shop to do it. It's not hard but it's not something you want to have go wrong.
  9. #69
    Aug 2014
    Eureka, Calif.
    Was hoping I wouldnt come across as a know nothing. I have worked on automobiles and motorcycles for over fourty years. Timing belts,install cams, brakes,carbs, distributors, and complete frame off restorations, by myself, no help. Just looking for pointers fredaroony.
  10. #70
    Dec 2013
    Sydney
    Joe
    You will have no problem at all. Simply remove the back wheel and replace the sprocket. Just use a bit of loctite (if you prefer) and make sure to torque up the bolts properly. I don't believe chain length will be an issue for a few extra teeth.
    You will find this forum helpful. Keep asking.
  11. #71
    Jun 2014
    Surrey, UK.
    Hi Motojo, the sprocket is bolted to a sprocket carrier which fits into the cush drive in the wheel. Not a difficult job if you are a confident mechanic. The stiff nuts should be replaced for safety, loctited and torqued up. They have had a tendency to come loose on previous models and should be checked frequently. My bike came with a chain that was too long so fitting a 44T rear sprocket actually put the chain adjusters back where they should be.
  12. #72
    Sep 2013
    Sydney, Australia
    Fair enough and hence why I said don't take it as being rude. It's just that if you're asking on a forum regarding changing a sprocket it's hard to gauge your experience level.
    The Caponord is a pretty standard setup so you shouldnt have any issues.
  13. #73
    Aug 2014
    Eureka, Calif.
    Thank you guys for replies, nice straightforward easy job, just what I was hoping for. With new and hi-tech bikes I am always afraid I will come upon something unexpected and not know how to deal with it. I will order those nuts in advance, get the proper loc-tite, and use a torque wrench.
  14. #74
    Feb 2014
    somerset/devon. uk
    hi motojo, ive changed mine to 44t and it is quite straight forward. I think the 2 extra teeth give you a bit more adjustment to play with also.
  15. #75
    apriliaforum Member andydj31's Avatar
    Jun 2005
    near Noale!!
    I've installed a classic Givi rear plate and an extension of side stand. I think the plate are fantastic!
    [/quote]
    P.S. sorry for my bad English!!
    Aprilia Caponord 1200 Rosso Formula
    Aprilia Rst Futura '02
    Aprilia Caponord RR '04 "Gundam" o "Biscottone".
    Aprilia Pegaso Cube 650 '01 "La piccola".
  1. What have you done to your RSV4 today?
    By potere in forum 2010-2018 RSV4 - All Variants
    Last Post: 07-14-2018, 11:12 AM
  2. What have you done to your RSVR today?
    By steelman_2 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 07-11-2018, 01:55 PM
  3. What have you done to your Dorsoduro today.
    By mc18 in forum 2011-2012 Dorsoduro 1200
    Last Post: 06-23-2014, 02:44 PM
  4. Off topic posts from What have you done to your RSV4 today? thread
    By SubZero in forum 2010-2018 RSV4 - All Variants
    Last Post: 06-27-2012, 10:47 PM
  5. quick action throttle fitted what have you done to yours today?
    By RSRITCHIE in forum RS125 Euro-archive
    Last Post: 10-29-2007, 04:01 AM
