Page 4 of 126 FirstFirst ... 234561454104 ... LastLast
Results 46 to 60 of 1890
Thread: What have you done to your Caponord today?
  1. #46
    Dec 2013
    Canberra, Australia
    I use Metro View on an iPhone 4. Speed is fairly small but the overspeed alarm stands out on the screen well enough for me.
  2. #47
    apriliaforum Junkie idiakez's Avatar
    Jan 2014
    Singapore
    Woke up for work today.
    It was raining the whole night.
    Warm up the bike and poooof, white smoke came out from the exhaust(only for a few minutes). Not sure if there's water inside the exhaust cause I parked my bike in a covered carpark.
    Anyway, I read somewhere in the forum abt this white smoke issue but can't really remember what it is all about.
  3. #48
    Sep 2013
    Sydney, Australia
    Quote Originally Posted by idiakez View Post
    Mine does that all the time and it's just water/condensation. If it doesnt go away after a few mins then you need to get it checked out.
  4. #49
    Jan 2014
    Singapore
    Quote Originally Posted by fredaroony View Post
    Roger that! Thanks mate!
  5. #50
    apriliaforum Member Yukon's Avatar
    May 2012
    Australia
    Australia has moved to a position of importing most of it fuel in the not so clean bowels of ships.
    This imported fuel is a dye laden heavey waxey crude compared to the sweet light crude that has supplied Australia's energy needs from the Bass Strait Oil fields in the past .
    If your bike has a lay off you will find that the dye in the fuel will form a residue in supply lines and low spots.
    I believe from your purchase date fuel has only a 3 week shelf life
    A friend recently commented that it smelt like some sought of onion concoction ?
    Due to this developing problem I have installed a inline conical filter to prevent time consuming costly strips
    The good old days may be over
    Bike shown is a 650 Pegaso , but really looking forward to throwing the leg across the new Caponord
  6. #51
    Jun 2014
    Ipswich, UK
    Surely that cannot be correct - a 3 week shelf life?! If so that's a huge refining error!
  7. #52
    May 2012
    Australia
    Yeah the degradation starts at about that time according to the lab techs that I work with .
    i work in oil and gas in Victoria Bass strait fields.
    These days if the bike sits for too long I dump the fuel and relegate it to mower use only.
    Also due the dye/residue problem I close the tank isolation valve and run the Carbs dry to prevent the residue drop out.
  8. #53
    Jun 2014
    Ipswich, UK
    There are going to be a host of claims coming up if that's the case. My Caponord was last run a month ago and probably won't see a road in anger again until March, or when they stop salting the roads.
  9. #54
    May 2012
    Australia
    Given its March till you hit the road again I definitely would close the valve run it dry and dump the fuel and go for a fresh refill of juice in March
    If you carnt do that I would drop about 500ml of mentholated spirits into the tank after a lengthy lay off
    As to making a claim against the oil giants its as useful and as hard as herding cats
    Do you know if the Caponords have a inline filter?
  10. #55
    Jun 2014
    Ipswich, UK
    No idea on the filter, but I've never had any problems leaving the fuel in my bike over winter in England. I'll turn it over occasionally, but that's pretty much it.
  11. #56
    May 2012
    Australia
    Carb bikes are more prone than EI bikes to the residue drop out of the added dye
    I suspect the Uk has a better and cleaner refining situation than Australia now has
    Most of our light sweet crude is shipped offshore ��
    Spoke with Aprila dealer service Tech today ahead of a test ride and they also give fuel a 3-4 week life before it starts to degrade.
    Test ride: plenty of good rides around but The Capo is right up there in the top shelf , bit of the wet stuff around left it in road mode , envious
    Good luck
  12. #57
    Dec 2013
    Canberra, Australia
    I shouted mine a new set of Bridgestone T30 tyres. Will report on how they feel/grip/wear as I go.
    These replaced a set of Dunlop Roadsmarts, which I only got about 4000km out of. Stuck like $hit to a blanket, great in the twisties, but not suited to the Capo's weight and highway miles I don't think.
  13. #58
    apriliaforum expert dsgfh's Avatar
    Nov 2005
    Melbourne
    That could explain my bikes behavior starting after 6 weeks off
  14. #59
    Jan 2014
    Singapore
    The EFI sign been coming out together with the Warning light for the past 3 days. Have to make time to go for a check up.
  15. #60
    apriliaforum prov-nov Niclas's Avatar
    Jun 2014
    Sweden
    Today I installed Bi-xenon projectors and 2 small LED lights to improve lighting... Works well!
  1. What have you done to your RSV4 today?
    By potere in forum 2010-2018 RSV4 - All Variants
    Last Post: 07-14-2018, 11:12 AM
  2. What have you done to your RSVR today?
    By steelman_2 in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 07-11-2018, 01:55 PM
  3. What have you done to your Dorsoduro today.
    By mc18 in forum 2011-2012 Dorsoduro 1200
    Last Post: 06-23-2014, 02:44 PM
  4. Off topic posts from What have you done to your RSV4 today? thread
    By SubZero in forum 2010-2018 RSV4 - All Variants
    Last Post: 06-27-2012, 10:47 PM
  5. quick action throttle fitted what have you done to yours today?
    By RSRITCHIE in forum RS125 Euro-archive
    Last Post: 10-29-2007, 04:01 AM
