Results 1 to 5 of 5
Thread: Don't have to remove the oil drain plug on the cases if your changing the filter
    apriliaforum expert BigGlen's Avatar
    New Rochelle, NY USA
    I'm doing my oil & filter change as I've done over the last 11 years and just now realize that if one is opening up the filter housing, all the oil in the cases will drain from there without having to remove the drain plug that's right next to it. Right? Or am I missing something? In fact the oil filter housing is slightly lower than the drain plug.
Name:	Oilfilter space.jpg
    2003 Tuono: Leo Vince slip-on, Factory Pro Chip, custom mapped Power Commander III, HiFlo AFE air filter, '00 snorkle, Forged Alum-Marchesini Wheels, Ohlins Shock, GP Suspension internal Showas, EVO Fuel Pres Modifyer, 525-16/43 final drive (after I wore out the 520), TCM low rear sets, Scorpion Lithium Battery, Pirelli Angel GT's.
    N. Cal
    The housing is lower but the oil pathway is not. I get quite a bit of oil out of that drain plug. You have the good oil plug bolt, not the hex key so get some crush washers and do it proper, you are already there.
    06' Caponord
    Quote Originally Posted by Matt fe2o3 View Post
    I had removed the drain plug and drained it before I removed the filter cover. The drain plug is a new addition this time around. But, now I know to continue doing using it in the future.
    apriliaforum prov-nov Kennibear's Avatar
    Washington State USA
    The factory drain plug has a magnet on it and you definitely want to remove it every oil change just to check it for steel shards and trash as it is an indicator of serious trouble inside the motor. Some fine crud is not huge but large shavings or chunks are a flashing red light! Take it out carefully and check it every time!
    KB
    True that.
  1. I'm sooo glad we don't have to deal with this in the US
    By High Gain Tuning in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-19-2012, 03:28 PM
  2. What size socket to remove the drain plug for the oil?
    By _eug_ in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 02-17-2012, 01:12 PM
  3. removing the plastic plug behind the metal oil drain plug getting it out
    By george mitchell in forum Aprilia and Piaggio 500cc
    Last Post: 08-03-2011, 01:08 PM
  4. proper method to remove the oil pump?
    By Steve / AF1 Racing in forum RS50 Technical
    Last Post: 12-22-2004, 11:52 AM
