Results 46 to 60 of 68
Thread: Check your rear wheel hub (Factory)
  1. #46
    apriliaforum expert NUMBER41's Avatar
    Wilmington, NC USA
    Quote Originally Posted by David_HX View Post
    Since you removed / cleaned and retorqued all 10 M6 bolts to 11 FT/lbs. have you inspected them since then / All OK ?
    Yep, pulled the rear wheel off to do winter maintenance and normal oil change, inspections, etc this past December, and they were still tight.
    I find tinsel very distracting.
  2. #47
    apriliaforum expert PumpinIron's Avatar
    Jan 2011
    Salem, Oregon
    I just checked mine on my 2013 Factory with 5800 miles and they were all tight (thank goodness).
    2013 Aprilia RSV4 Factory SE
    Aprilia RSV4 & Tuono V4 Owners Facebook Group
    Digital Sky Design (My Web Design Company)
    My Facebook Profile
  3. #48
    apriliaforum Junkie slrkappa's Avatar
    Oct 2009
    29 Palms, CA
    Was cleaning my chain yesterday and found the rear hub completely loose at 7k miles on my 2010! Yikes. Reinstalled with thread lock.
    In the garage now 2001 Suzuki GSXR-1143, 2004 RSV Factory & 2010 RSV4 Factory. Somehow ended up with an inline 4, V-twin & V4.
  4. #49
    apriliaforum Member fasteddie13's Avatar
    Jul 2014
    The Grove
    Mine were fine at 4400 miles.
    2013 RSV4 Factory "APESHOT"
    2007 Honda CBR 1000RR
    1987 Porsche Carrera
    1999 Porsche Carrera (Flat6 3.6 build)
  5. #50
    Oct 2015
    San Jacinto, CA
    Quote Originally Posted by Shaman666 View Post
    I had the wheel off today to change the tire, and found this:
    Four loose bolts, two almost back all the way out and the remaining four were anything but tight.
    No sign of thread lock on any of the bolts.
    The wheel took a bit of damage where the hub has been moving/rubbing. I'm going to talk to the dealer about whether or not the wheel should be replaced.
    Then I bent my No-Mar's bar getting the front tire off. *sigh*
    Thanks for the info. I will have mine checked every time a tire is put on. I also discovered a loose nut on my Tuono while cleaning the chain. The bike has 3,200 miles on it. Appreciate the heads up.
  6. #51
    Jul 2016
    New Zealand
    Good info, I had a new set of tyres fitted last week and asked the bike shop to check this once the rear wheel was removed. 4 x loose bolts. There was plenty of blue Loctite present. I will check at every tyre change now. Aprilia RSV4 2014, 6,200 kms ( 3,850 miles ).
  7. #52
    apriliaforum Member lochnessmonster's Avatar
    Jul 2016
    Meadow Lake, Saskatchewan, Canada
    I'll be sure to keep an eye on mine. Thanx!!
    RSV4 RF (Superpole graphics)
    Gen 5 Viper GTS (Adrenaline Red)
    WRX STi ('08 hatch WRB/Gold BBS)
    Honda S2000 (New Formula Red)
  8. #53
    Mar 2016
    Attachment 328828This is a solution I came up with for the loose sprocket bolts its a "nord lock" washer and stover nuts, that combined with blue locktight
    the nord lock washers grab the material really well and actually will tighten more if they are backed out and the stover nuts are far better than a nylon nut
    time will tell but im sure I wont have any further issues
  9. #54
    apriliaforum prov-nov KnoxRider's Avatar
    Dec 2015
    Knoxville, TN
    2016 RSV4 RF, 1300 mile 1st tire change - all the bolts were fine, thankfully
  10. #55
    apriliaforum Junkie V4Missile's Avatar
    Oct 2013
    Hertfordshire, England
    After loctiting on my first tyre change, no probs this change. Have gone for the new Michelin's Power RS, in the 200/55 size. Previous Pilot Power 3's had done 4500 miles, and not flattened out. Pleased with them overall.
  11. #56
    apriliaforum newb Bitaktus's Avatar
    Feb 2015
    Just checked: 17.500 km and the bolts were all tight
    With kind regards,
    My bikes:
    - Aprilia RSV4 Factory '09
    - Aprilia RS250 '96
  12. #57
    apriliaforum expert drvacation's Avatar
    Aug 2013
    las vegas
    Everyone I know with an RAV4 or tuono has had this problem, after retorqueing with out thread locker or any other remedy, all have stayed tight
  13. #58
    apriliaforum prov-nov joeyfrost's Avatar
    May 2017
    New Jersey
    When i purchased my 16' rsv4 rf it also had this issue after a week or so of riding but I did notice many parts throughout the bike have slippage marks (torque paint on it). In aviation we do this after torques so we can quickly see if bolts have backed off or not. This particular item is a maintenance item and should be checked regularly. Along with any other slippage marked items in my opinion... hope this helps
  14. #59
    Jun 2016
    2015 RSV4 Factory - Purchased and received in June 2016
    2500 miles use
    Lubing chain and identified rattle during rear wheel rotation
    4 of the bolts were completely loose and two were partial
    There was minimal wear around the holes
    Removed and reinstalled with loctite
    This is what the view was when first removing the hub
    Thanks for the heads up!
  15. #60
    Dec 2016
    Ontario, Canada
    Thanks for the heads up shaman. I'll be sure to check mine and everything else now since hearing of this!!!
  1. loose bits on rear wheel hub
    By fatjim in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 03-29-2009, 03:53 PM
  2. FS: RXV rear wheel Hub 2007
    By apsik in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 12-09-2008, 02:25 PM
  3. AZIrish... What ever happened to your rear wheel...
    By colo_heff in forum RST1000 Futura (all years)
    Last Post: 08-07-2007, 07:23 PM
  4. Rear Wheel/Hub Fux0red
    By tian647 in forum RST1000 Futura (all years)
    Last Post: 04-09-2007, 12:59 PM
  5. Check your Rear...
    By Carbon Can Kat in forum SL1000 Falco Forum (all years)
    Last Post: 03-25-2005, 01:03 PM
