Results 16 to 30 of 70
Thread: Check your rear wheel hub (Factory)
    apriliaforum expert Rob Jarvis's Avatar
    Feb 2013
    London
    this is why i investigated.. Noticed a wobbly sprocket while on the paddock stand.
    RSV4 Factory - Race ECU - Bazzaz Z-Fi TC QS - Pipercross - Domino XM2 QAT - AR GP2 - 16/42 - Race fairing - Carbon Fibre - Brembo - Ohlins - Pirelli - HM Racing set up.
    apriliaforum Member fasteddie13's Avatar
    Jul 2014
    The Grove
    Thanks for that clip, Rob. Gonna check mine today...
    ...and it checked out fine
    2013 RSV4 Factory "APESHOT"
    2007 Honda CBR 1000RR
    1987 Porsche Carrera
    1999 Porsche Carrera (Flat6 3.6 build)
    Feb 2013
    London
    Quote Originally Posted by fasteddie13 View Post
    no worriers.. good news mate :-)
    apriliaforum Member Vee's Avatar
    Sep 2014
    Malaysia
    Good sharing Rob ! I'm changing my tyre very soon, def will check this too
    apriliaforum expert NUMBER41's Avatar
    Wilmington, NC USA
    Another update. Mounted a new set of tires last week. After retorquing and loctite last year, mine were still good.
    I find tinsel very distracting.
    apriliaforum expert Danfinarch's Avatar
    Dec 2013
    Hampshire
    Can anyone confirm that these are the bolts in question? An 09 R
    2009 R
    Race ECU. Domino XM2, Shorty Akrapovic. Retro Fit APRC Qs. RCS 19 and RCS clutch perch
    HEL lines throughout. GiaMoto Rearsets, Puig, Pipercross Air filter. SC1 for road and Superbike Slick SC1/SC2 track
    Aug 2007
    San Antonio
    Damn that's filthy.
    apriliaforum Member RSV4_Ghost's Avatar
    Jun 2014
    Southern Point of Africa
    Dan, yes those are the bolts everyone is talking about. as far as I know all the R model rear wheels have that bolt pattern/configuration. I went from the factory rim (as per my earlier post) to the picture you have posted just the newer 3 spoke version. Ridden it for several months and on my last tire change all was still in order.
    One thing that I find odd is you don't have the 90 degree valve stem, mine came with it as standard
    - '10 RSV4RF
    - '14 636 ABS
    Live.to.ride.ride.to.live.initiative
    Dec 2013
    Hampshire
    Quote Originally Posted by snikwad View Post
    Damn that's filthy.
    Hence a deep clean as we speak
    2009 R
    Dec 2013
    Hampshire
    Quote Originally Posted by RSV4_Ghost View Post
    Thanks mate no right angle valve and it's the Bain of my life with front wheel! Thanks for your help mate
    2009 R
    apriliaforum expert Markey's Avatar
    Aug 2012
    Swansea UK
    Dan, I bet those bolts were super tight on those cast wheels ?
    The problem is not with those but just the forged lightweight ones where the torque is much lower
    Dec 2013
    Hampshire
    They were spot on mate yeah. Actually did take abit of aggro getting them out, but they had been loctited to the end of the earth!
    Always nice to know for sure
    2009 R
    apriliaforum Member NixK7's Avatar
    Jan 2015
    Carlisle UK
    2014 Factory, half of mine were loose, not finger tight loose, but no resistance when trying to undo them, had the hub off as part of my ongoing investigation into my chain problem
    http://www.apriliaforum.com/forums/s...hain-correctly
    Miniscule amount of loctite on the very top of some of the bolts (so would not have reached to the threaded part of the hub) cleaned it up, blue loctite applied and did them all back up
    Westminster, CA - USA
    When applying Loctite to a screw that is going into a blind threaded hole, apply it to the threaded hole instead.
    If you apply it to the screw, the air trapped between the screw and blind hole will push the Loctite out and not allow it to reach the threads.
    http://www.henkelna.com/industrial/u...cker-14064.htm
    Jan 2015
    Carlisle UK
    Not a blind hole Amauri
    At least not on my 2014 Factory
  1. loose bits on rear wheel hub
    By fatjim in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 03-29-2009, 03:53 PM
  2. FS: RXV rear wheel Hub 2007
    By apsik in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 12-09-2008, 02:25 PM
  3. AZIrish... What ever happened to your rear wheel...
    By colo_heff in forum RST1000 Futura (all years)
    Last Post: 08-07-2007, 07:23 PM
  4. Rear Wheel/Hub Fux0red
    By tian647 in forum RST1000 Futura (all years)
    Last Post: 04-09-2007, 12:59 PM
  5. Check your Rear...
    By Carbon Can Kat in forum SL1000 Falco Forum (all years)
    Last Post: 03-25-2005, 01:03 PM
