This rs is about to be thrown across the garage.
I cant find the problem.
We rebuilt the bike includeing a bottom end and top end rebuild.
Put everything back together and started running it in.
Ran really really well then suddenly starts cutting out after running for a few minutes. Has gradually got worse and now is almost impossible to start.
Have cleaned carb - changed plug - cleaned reed valves - changed the cdi.
Found that the regulator may have been wired up worng so changed that.
Still wont start?
HELP PLEASE!!!!!!!!!
but in my experience of rebuilds it could be anything from the compression in the cil, the plug not sparking, fuel not getting through, the mix being to lean/rich... just for starters.
The ring looked fine when i checked but obviously it wasn't
should be back on the road in a week or so (ordering new parts off craig)..
