Page 6 of 96 FirstFirst ... 456781656 ... LastLast
Results 76 to 90 of 1435
Thread: Guzzidiag for RSV4
  1. #76
    apriliaforum expert pauldayona's Avatar
    Nov 2013
    Netherlands
    Quote Originally Posted by ianofbhills View Post
    Is there any advance on being able to enable aprc functions?
    No, still waiting for someone from the Aprilia community who has access to a navigator or pads to do some logging
    Paul
    Daytona 1225, Stelvio 1151
  2. #77
    Jun 2012
    Croatia
    What do you need?
  3. #78
    apriliaforum expert tomik's Avatar
    Oct 2005
    Finland
    Quote Originally Posted by tomi77 View Post
    What do you need?
    You have Navigator/PADS? What is needed is logging the traffic with some software during functions like:
    - Quick shifter enable/disable
    - APRC enable/disable (+other functions for it?)
    - ABS enable/disable (+other functions for it?)
    - Functions for the exhaust valve (self learning, zero search)
    If you have necessary tools for it and would like to help, PM me or Paul and we can hook you up with the developer who can tell details how to do it.
  4. #79
    May 2006
    Germany, Near Nuerburgring / known as Green Hell
    Basic question, I got the cable, installed software and driver. I tried the test software and it is telling me that the cable connection is ok.
    Next step was to switch on ignition; good news is that nothing smelled but I got no data on the screen. I thought I would see at least
    some temperature readings without running engine. I cannot start due to disassembled exhaust, so I had to stop further testing here.
    Is it normal that no data appear on the screen without any rpm’s?
  5. #80
    apriliaforum expert Apriliabåårg's Avatar
    Sep 2012
    Denmark
    I have data on the screen without starting the engine...
    YouTube channel: Motomade78
    Small edit with flyby and more: http://youtu.be/7LY3ym8uQuU
    Aprilia RSV4 R '10 a-PRC retrofitted and Ohlins Factory suspension
    Aprilia Racing Akrapovič EVO | Race ECU | '13 race map | a-PRC Retrofitted | Ohlins forks | Ohlins steering damper | Ohlins shock | Flyhammer top yoke | Puig smoked windscreen | ASV C5 black shorty levers | Samco stainless steel hose clamp kit | Integrated clear taillight | Rear sprocket Superlite SR7 42(+2) | Giles shift shaft support | NGK Iridium spark plugs | Titanium bolts |
    Honda CBR 1100 XX Super Blackbird (2UP Bike)
    Akrapovič Titanium SP-Series | PCIII USB | Custom MAP | MRA smoked windscreen |
    Previous bikes:
    Kawasaki ZX-10R '07
    Kawasaki ZX-9R '98
    Kawasaki ZX-6R '97
  6. #81
    Nov 2013
    Netherlands
    Quote Originally Posted by WILF View Post
    No but first time you choose com port and california 1400 s model, after that you click the connect in the file menu, oder auf deutsch> Datei> verbinden. Motor does not have to run, but ignition on and not the killswitch active.
    Paul
  7. #82
    apriliaforum expert Toohomo's Avatar
    Feb 2013
    Mandlebar HQ UK
    Do you need to download the CD driver that comes with the cable to get it to work?
    Mine should be arriving shortly, first thing I want to know is what RACE map I have, is this info easy to find?
    My tank is off at the painters so hoping I can get this info with out putting the bike back together.
  8. #83
    Oct 2005
    Finland
    Don't install the drivers from CD, follow the links in the Guzzidiag page to download FTDI drivers.
    You will see the map version immediately after you get connected to the ECU in the info section.
  9. #84
    Feb 2013
    Mandlebar HQ UK
    Cool cheers, have downloaded Guzzidiag V0.40 for windows its on my laptop and selected California 1400s so hopefully plug and play when my other cable arrives.
  10. #85
    Nov 2013
    Netherlands
    Install driver before you connect the cable first time.
    An easy install is this one:
    http://www.ftdichip.com/Drivers/CDM/CDM20814_Setup.exe
    download and run.
    Paul
  11. #86
    Nov 2012
    united kingdom
    Hi there,
    do we know is guzzidaig can be used to change what temp the fans come on ?
    Would like mine a bit ealier ?
    ghw1972
  12. #87
    Oct 2005
    Finland
    No, Guzzidiag is just for diagnostic etc. it does not change mapping or functionality of ECU.
    Quote Originally Posted by ghw1972 View Post
    Hi there,
    ghw1972
  13. #88
    Feb 2013
    Mandlebar HQ UK
    Had a play today, all works.
    Great product will send a donation
  14. #89
    Jul 2009
    scotland
    After lots of messing about with drivers and contacting the seller on eBay who just wanted me to return the lead to Germany,I finally got it working.I had spare time today and found the ground pins 4 and 5 on 16 pin blue lead only one was getting ground, soldered a bridge on them and it worked first time ,clue was I never had the LED illuminating at all.
    Great bit of kit.
  15. #90
    Genova/Siracusa
    Does Guzzidiag work on Windows 7 64 bit? Right now I've worked with a windows 7 32 bit version and the last functions (rbw and throttle) work great!
    Will be it possible the exup valve self-learning and disable the SAS valve and lambda sensor? Is it possible to see ECU CLF value right now?
  1. [RSV4] Looking for RSV4 front frame
    By The Law in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-16-2013, 05:48 PM
  2. [RSV4] CF / Kevalr Tank for RSV4 - Tuono V4
    By MTPockets in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-01-2013, 12:17 AM
  3. [RSV4] WTB - Exhaust hanger bracket for RSV4 / Tuono V4
    By MishMashRSV4 in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 07-15-2013, 09:39 PM
  4. accessories and availability for RSV4
    By 1ho in forum 2010-2018 RSV4 - All Variants
    Last Post: 05-31-2009, 08:25 AM
  5. LeoVince GPpro for RSV4
    By Priest in forum 2010-2018 RSV4 - All Variants
    Last Post: 04-04-2009, 05:13 AM
