Page 4 of 83 FirstFirst ... 234561454 ... LastLast
Results 46 to 60 of 1235
Thread: Guzzidiag for RSV4
  1. #46
    Roma, Caput Mundi
    It's similar but more complex becouse involve some choices.
    www.gabroracingteam.it
    Visit my FB page and like it!
  2. #47
    apriliaforum prov-nov marcoxedge's Avatar
    Dec 2010
    Germany
    I hope I got it right!
    This is from TECHNICAL BULLETIN No. 001-2011
    Accessory ECU, Race Map
    Client has purchased an aftermarket exhaust system and an accessory ECU with Race Map
    for an My 2009-2010 RSV4
    What the Authorised RSV4 Service Centre has to do:
    RSV4 Factory 2011 A-PRC
    1- Replace the standard injection ECU on the 2011 model with the RACE accessory ECU for the
    2009-2010 model
    2- Connect the Navigator to the 2011 model fitted with the RACE accessory ECU
    3-Select REPROGRAMME RSV4 [09/10>] (>SEPTEMBER 2010).
    At this stage, reprogramming with Race map No.1034AD10 RACE A-PRC MAP only is permitted -
    NO PASSWORD NECESSARY
    4 -At the end of the reprogramming procedure, select:
    > RSV4 INJECTION > [09/10>]
    > SETTINGS-SETTABLE PARAMETERS
    THE FOLLOWING PROCEDURES MUST BE PERFORMED:
    - Handle self-learning
    - Throttle self-learning
    - A-PRC (Aprilia Performance Ride Control) - ACTIVATE
    - QUICK SHIFT (electronic gear shifting) - ACTIVATE
    5- Install the Race exhaust system
    this an example. As you can see there is
    "handle self-learning"
    "throttle self-learning"
    "APRC" (obviously without Quickshift)
    "Quickshift"
    So these setting were meant IMHO and have to be done depending on model.
    regards
  3. #48
    apriliaforum Junkie pauldayona's Avatar
    Nov 2013
    Netherlands
    When I read this it looks like you can set "APRC" and "Quickshift" to activate or deactivate? Or more choices?
    Paul
    Daytona 1225, Stelvio 1151
  4. #49
    Dec 2010
    Germany
    As far as I remember, just those two options!
  5. #50
    Nov 2013
    Netherlands
    And the PADS/navigator shows the setting too before you set it? So it shows "APRC" active, and then you can click on deactivate? And the other way arround?
    If I read the Aprilia docu, the aprc and quickshifter set is only needed on aprc bikes. And If it is just an ecu swap, that is standard to race ecu, no setting from aprc or quicksft is needed unless the ecu came from non aprc bike.
    Correct me if I'm wrong.
    Paul
  6. #51
    apriliaforum expert tomik's Avatar
    Oct 2005
    Finland
    You have to disable the APRC functions on non-APRC bike with the latest maps, otherwise you get errors. You use the same maps with non-APRC and APRC bikes, but during installation you have to enable/disable the necessary functions depending on the bike.
    One thing to note is that in new RSV4s there is also ABS and Navigator don't have controls for that, so you need PADS. Beard is waiting for someone to log those APRC setting functions.
  7. #52
    Oct 2013
    San Diego, CA
    Sorry to bring back up more cable questions... would this OBD2 - USB cable work?
    http://www.amazon.com/quality-ELM327...2RL+USB+OBD+II
  8. #53
    Nov 2013
    Netherlands
    No, won't work. ELM is completely different.
    Take this one:
    http://www.ebay.com/itm/NEW-FTDI-FT2...E/370453504187
    Paul
  9. #54
    Dec 2012
    Adelaide
    Quote Originally Posted by pauldayona View Post
    Take this one:
    http://www.ebay.com/itm/KKL-409-1-VW...456653&vxp=mtr
    Even cheaper and they are the same type I think
  10. #55
    Oct 2013
    San Diego, CA
    Take this one:
    Thanks, got it. The issue is with ebay, I refuse to do any more business with PayPal and that seems to be the only way to pay for ebay items these days.
    How about this one? http://www.amazon.com/Cable-Triumph-..._cd_al_qh_dp_i
  11. #56
    apriliaforum Junkie ZAWA's Avatar
    Ocala
    It should work, I use the same cable on my Triumphs and the Aprilia.
  12. #57
    Jul 2012
    england
    My turn to get involved with the guzidiag.
    I have purchased the required adapters from the links in post number 3 but i cant get the system to work.
    I have uninstalled and installed separately both versions of the drivers from the guzidiag website, I've connected in the correct sequence and adjusted the com port settings but still no good.
    When i try to connect using the software it tells me to turn on the ignition (which i have tried both on or off at this stage) it then says "ignition off" and does not connect.
    I have ran the diagnostic test and the result comes up with some garbage characters and a time out error. The red LED does not light up on my lead.
    I have not yet checked the pin out on my adaptor leads yet.
    From reading this thread these symptoms are very similar to those experienced by xcrozx who finally managed to get his working by getting a new cable so I guess that is my next course of action.
    Any other ideas other then a new cable?
  13. #58
    Roma, Caput Mundi
    maybe the adapter is cross-wired.
    try to connect the obd cable straight to the 3 pin port using single wires
  14. #59
    Nov 2013
    Netherlands
    If you look in device manager, and at the com port at the driver tab ,what driver does it show installed?
    The testprogram tests if the pc can communicate with the FTDI chip, not if it connects to the bike.
    The led on the adapter should go on if you connect it to the 3 pin on the bike and the red crocodile to the battery. If that is not working it might be a wrong wired 3 pin adaper, sometimes someone has been sleeping in China, and made the wrong connetions. The 3 pin adapter has no electronics in it. You can measure if it is ok.
    To check:
    Quote Originally Posted by ianofbhills View Post
    Paul
  15. #60
    apriliaforum expert Toohomo's Avatar
    Feb 2013
    Mandlebar HQ UK
    Just bought the cables, look forward to trying to figure it out, I have no doubt there will be questions
  1. [RSV4] Looking for RSV4 front frame
    By The Law in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-16-2013, 05:48 PM
  2. [RSV4] CF / Kevalr Tank for RSV4 - Tuono V4
    By MTPockets in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-01-2013, 12:17 AM
  3. [RSV4] WTB - Exhaust hanger bracket for RSV4 / Tuono V4
    By MishMashRSV4 in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 07-15-2013, 09:39 PM
  4. accessories and availability for RSV4
    By 1ho in forum 2010-2018 RSV4 - All Variants
    Last Post: 05-31-2009, 08:25 AM
  5. LeoVince GPpro for RSV4
    By Priest in forum 2010-2018 RSV4 - All Variants
    Last Post: 04-04-2009, 05:13 AM
