Page 2 of 89 FirstFirst 12341252 ... LastLast
Results 16 to 30 of 1324
Thread: Guzzidiag for RSV4
    Aug 2012
    Barbados
    any idea if this tool would work on windows 8?
    Westminster, CA - USA
    Quote Originally Posted by ZR1000A1 View Post
    Thanks. The other reason, I guess, why TB sync function might be helpful is AFAIK the adjustment screws are accessible without removing an air box. In order to do sync the "old" way you'll need to remove/install air box at least twice.
    You'd have to remove the complete airbox once to first install hoses, for each throttle body.
    The air bleed adj screws for cylinders 3 & 4 are always closed all the way, the adjustment is only carried out on #1 and 2.
    Cyl #2 screw can be accessed from outside the airbox, #1 can only be reached with the airbox lid off. No need to remove the airbox base to make the adjustments.
    Ideally you would connect the gauges to each cylinder and adj with the engine fully warmed up running at idle.
    To run the engine with the airbox lid off you would need to make up a fuel hose extension, or somehow plug the hose the feeds the top injectors..
    apriliaforum expert tomik's Avatar
    Oct 2005
    Finland
    Yes exactly. When I was syncing TB's for the first time I didn't notice the rubber plugs on the bottom of the airbox base that provide access to the air bleed screw. So I took the base out every time I did adjustment, and I think I did it 5 times total... What a mess... And how silly I felt when I noticed those plugs
    apriliaforum Junkie pauldayona's Avatar
    Nov 2013
    Netherlands
    How does the navigator know what to turn, what feedback does it have, you have one lambda, no map sensor per cylinder.
    I see a pressure sensor per bank, so Navigator tells you difference between front and back?
    If navigator can find out there should be a signal from the ecu that gives values.
    Found it:
    The control unit receives information on the intake
    pressure in the four ducts from the two pressure
    sensors: as the control unit knows the timing
    phase of the cylinders, it can calculate the individual
    pressure of the four cylinders.
    So do you get 2 or 4 pressure values in diagnostics?
    Paul
    Daytona 1225, Stelvio 1151
    Dec 2008
    Toronto, ON, Canada
    Thanks for the great explanation! I'm still a bit confused: with PADS do you still need to remove airbox and install vacuum gauge hoses, or PADS reads vacuum values from ECU and thereby does not require a gauge, installation of hoses, complete removal of airbox, etc. ?
    Oct 2005
    Finland
    With PADS you don't need to remove whole airbox and you don't need to install vacuum hoses - it just reads from sensor data what needs to be adjusted.
    Oct 2005
    Finland
    Quote Originally Posted by pauldayona View Post
    There is one map for front bank and one for rear bank. But the ECU knows from the timing of the pulses that which one of the front or rear cylinders is causing what pressure. At the moment I have identified the front and rear bank data channel, but not individual cylinder data. I think I know which channels they are, but there is no way of knowing for sure before I read the data live and adjust the bleed screws to see what is going on there. Front and rear banks are balanced by the ECU, the manual adjustment is balancing between left/right cylinders.
    Nov 2013
    Netherlands
    But I see 4 air pressure values in guzzidiag:
    Air pressure R-F-C1-C2
    So suppose rear front, actual values from sensor, and c1 and c2 is the calculated from ignition? If you have these values on screen, they are almost the same when engine runs?
    And if you close one intake a bit with your hand over it, something should change.
    A question, what do these 4 maps display?
    Paul
    Oct 2005
    Finland
    Like I said I haven't yet been able to test that, my bike is no in a shape where I can run it at the moment. But will get there Test i did earlier was just disconnecting whole sensor and seeing which data changes. Then there are 2 additional values which are somehow calculated but I need to have my bike running to be able to test that. Airbox have to be on to be able to run the bike - not so easy as putting your hand on the intake But I would guess is that the front and rear map data are averaged to show whole bank value (for balancing front/rear by ECU) then the other calculated values are used for manual synchronizing - they can be calculated (timed) data for left cylinders for example. That's really all you need to find out the balance.
    apriliaforum expert slothfryk's Avatar
    Ventura, CA
    Paul- are those throttle maps?
    Nov 2013
    Netherlands
    Quote Originally Posted by slothfryk View Post
    They are next to each other in the map file, so or it is for four situations where it can switch, or can you choose out of four maps while driving? It can't be fuel, wrong shape, and wrong grid. I was hoping that someone would recognize them and could identify them. I have more.
    Here two other ones. 24x12
    Paul
    Nov 2013
    Netherlands
    New Guzzidiag version 0.40 with the RSV4 throttle and handle learning function is available online.
    Paul
    apriliaforum expert dastrix's Avatar
    Jan 2012
    on Earth
    Wait, what??? Ie as in a replacement for the Navigator if you change ECU?
    You're a very valuable member of this forum Paul
    Aprilia RSV4 Factory WSBK APX2 Superbike - See the build here or Follow the Build on INSTAGRAM here
    Need Titanium Aprilia Caliper bolts? Buy HERE
    Aims to be an honest/upstanding Trader on the forum - See my feedback here
    Nov 2013
    Netherlands
    Yes that is what it should do, try it.
    Paul
    apriliaforum Junkie ZAWA's Avatar
    Ocala
    Thanks for the update and for your work on it.
  1. [RSV4] Looking for RSV4 front frame
    By The Law in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-16-2013, 05:48 PM
  2. [RSV4] CF / Kevalr Tank for RSV4 - Tuono V4
    By MTPockets in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-01-2013, 12:17 AM
  3. [RSV4] WTB - Exhaust hanger bracket for RSV4 / Tuono V4
    By MishMashRSV4 in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 07-15-2013, 09:39 PM
  4. accessories and availability for RSV4
    By 1ho in forum 2010-2018 RSV4 - All Variants
    Last Post: 05-31-2009, 08:25 AM
  5. LeoVince GPpro for RSV4
    By Priest in forum 2010-2018 RSV4 - All Variants
    Last Post: 04-04-2009, 05:13 AM
