Page 1 of 89 1231151 ... LastLast
Results 1 to 15 of 1330
Thread: Guzzidiag for RSV4
    apriliaforum expert tomik's Avatar
    Oct 2005
    Finland
    Diagnostic tool - Guzzidiag for RSV4
    Just letting anyone interested in diagnostic tool for RSV4 to know about very inexpensive alternative to Technoresearch Centurion. You can get the latest software here: http://www.von-der-salierburg.de/download/GuzziDiag/ There is also instructions of getting the adapter and how to install etc. You can find the adapter(s) in ebay for about 20 euros total.
    I have been testing it last few months on my RSV4, identifying channels etc. and letting Beard know what needs changing and so on. Beard has done good job on this! And there is more to come (throttle calibration etc.), stay tuned
    So to get it working with RSV4 you should choose California 1400 as the motorcycle (it has the same MM 7SM ECU as RSV4). At the moment you can read and clear faults, do some functional testing (for example turn on fuel pump, throttle/handle learning, read sensor data. There are still few channels I'm working on.
    If you get it running and have some comments, or improvement ideas, please let me know! I can forward wishes to the developer. If you like the software, there is donate button to send thanks to the developer, but otherwise the software is free.
    Just to clarify that I'm not selling anything here! I have just been testing Guzzidiag for Beard, since he don't a have bike with 7SM ecu. I just would like to people to know about this free (ok, 20 euros is not free..) tool that can save you from an expensive trip to dealer!
    ****************EDIT*******************
    Due to long thread already, added a FAQ for the newcomers to get started.
    1. What interface is needed?
    a. You need two adapters
    i. USB to KKL (OBD2). Make sure it has FTDI 232RL chip
    ii. OBD2 16-pin to 3-pin, also called as FIAT adapter
    2. Where to get them?
    a. Links to known good cables are at the bottom of the Guzzidiag page
    b. You can get them also from ebay, see #1 for specs. But don’t come asking here is this or this good cable. There are hundreds of sellers and different versions etc. no one has tried and tested them all. Even same seller can have different batches with different specs.
    c. One good source for the cables is this: http://lonelec.co.uk/index.php?route...&product_id=51
    3. What software is needed?
    a. Download IAWDiag software from Guzzidiag web page http://www.von-der-salierburg.de/download/GuzziDiag/
    b. Follow the instructions for the FTDI driver installation in the Guzzidiag page.
    4. Now I’m confused, there are Guzzidiag, IAWDiag, IAWReader, etc… in this web page. What do they all do?
    a. Guzzidiag and IAWDiag were separated to have Guzzidiag dedicated to Moto Guzzis and IAWDiag to other bikes using MM IAW ECUs
    b. IAW Reader, IAW Writer are for programming ECUs.
    5. What I can do with IAWDiag?
    a. Read and clear fault codes (if you have SERVICE text on the dash, it means there is some fault code stored in your ECU)
    b. Read active sensor data
    c. Check map version
    d. Do throttle/handle learning
    e. Do some active tests, activate injectors etc. to help with diagnostic
    f. Install new ECU (race ECU for example) to your bike IF in the new ECU mapping is correct, APRC/ABS/QS configuration is correct to your bike, and CLF does not need encoding (in some very rare cases in APRC bikes the CLF ECU needs encoding to start working with a new ECU). See #6 for the IAWDiag limitations.
    6. What I cannot do with it?
    a. Activate/disable QS, APRC, ABS
    b. Change mapping (as in write new maps to your ECU)
    c. Read CLF/ABS ECU faults or do CLF ECU encoding
    d. Do throttle body balancing
    7. Now I got P0xxx code, what it means?
    a. Get a service manual and search the PDF for the code. You can get the service manual from AF1 Racing for a nominal fee.
    b. Search this forum is it some common fault
    8. Does it work with new 2015/2016 RR/RF and Tuono V4
    a. Yes
    apriliaforum Junkie pauldayona's Avatar
    Nov 2013
    Netherlands
    the chip has to be ftdi 232rl.
    2 known working exaples, shipping worldwide
    http://www.ebay.com/itm/NEW-FTDI-FT2...E/370453504187
    http://www.ebay.de/itm/AutoDia-K409-...item23293bda25
    3 pin fiat adapters are all the same, if they chinese didn't make a mounting error, no electronics inside.
    Nov 2013
    Netherlands
    These are shipped worldwide and tested with guzzidiag, the fiat 3 pin adapter is allways working
    This one is send from Germany and works too:
    Nov 2013
    Netherlands
    Quote Originally Posted by tomik View Post
    The 3-pin adapter is correct for sure, and the USB-KKL adapter looks right, but there are different versions of the FTDI chip in these adapters and it does not say which one it has (or does it even have FTDI chip..). Anyway if it has FTDI chip it is matter of getting the correct driver to go with it, so you should get it working regardless. I would install the FTDI driver that is listed at the end of guzzidiag web page before connecting the adapter to your PC, just to be sure and avoid having to uninstall the drivers Windows installs automatically.
    This one is correct: http://www.ebay.co.uk/itm/3706237361...84.m1423.l2649
    do you have that one, because it has a 232BL chip, and I thought they don't work, only 232RL
    Paul
    Daytona 1225, Stelvio 1151
    Nov 2013
    Netherlands
    RL is a newer chip, BL is not good enough I think.
    Most time supporting Guzzidiag is gone to people buying wrong adapters. The ones sold through Amazon give most problems because you don't know what you get there. For them any KKL is the same.
    these ones were tested and work:
    Paul
    Oct 2005
    Finland
    Thanks Paul for getting the FTDI chip version straight! I actually copied the link above from your post on animaguzzista.com, but it could have been old information
    Roma, Caput Mundi
    yes, ground is the middle pin (green/blue), K line is the blue/white wire
    www.gabroracingteam.it
    Visit my FB page and like it!
    Roma, Caput Mundi
    you have to connect the K-line to the cable pin 7, +12v to pin16, GND to pin 5 or 4.
    pin 5 and 4 are the bigger ones in the upper row of the male OBD connector. They are usually bridged in the connector but not always... so try both.
    a pic from the web:
    do not blindly trust to ebay FIAT adapter, they are not always cabled correctly... sometimes are reversed.
    Nov 2013
    Netherlands
Size:  38.3 KB the 4 and five normaly get connected in the kkl adapter
    Paul
    Nov 2013
    Netherlands
    For Guzzidiag newbees, I made a series of Youtube movies where you can see it in use, with mapping and the use of tunerpro.
    http://www.youtube.com/playlist?list...2WQON3vjTPtW2r
    Paul
    Nov 2013
    Netherlands
    What are DIY mapping options there are with the 7sm marelli ECU now?
    Paul
    Oct 2005
    Finland
    Rexxer basically, that's about it. Then there are individuals who can do programming with their own way, but it is not a DIY really..
    Apr 2012
    Bangkok
    http://www.ebay.com/itm/200975737136...84.m1497.l2649
    This is what I have, can you confirm this is ok or not please.
    Nov 2013
    Netherlands
    well looks ok, but they didn't specify chip, so not 100% shure. If you are in bangkok, why not order one from Hongkong?
    And if you have it already, then test if it works. Then you know it.
    Paul
    Dec 2008
    Toronto, ON, Canada
    Beard is working on the MacOS and Linux versions before release, but I'm expecting it to be ready in next few days.
    No plans for the TB sync yet since it can be done the "old" way with vacuum gauges and it is more of a feature of the PADS/Navigator telling how much to turn which air bleed screw than ECU test mode which is commanded from diagnostic system. That being said I'm doing TB sync for my bike soon and I'll try to figure out how to interpret the sensor data to see when the TBs are in sync. I'll let you know how it turns out.
    Thanks. The other reason, I guess, why TB sync function might be helpful is AFAIK the adjustment screws are accessible without removing an air box. In order to do sync the "old" way you'll need to remove/install air box at least twice.
  1. [RSV4] Looking for RSV4 front frame
    By The Law in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-16-2013, 05:48 PM
  2. [RSV4] CF / Kevalr Tank for RSV4 - Tuono V4
    By MTPockets in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 10-01-2013, 12:17 AM
  3. [RSV4] WTB - Exhaust hanger bracket for RSV4 / Tuono V4
    By MishMashRSV4 in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 07-15-2013, 09:39 PM
  4. accessories and availability for RSV4
    By 1ho in forum 2010-2018 RSV4 - All Variants
    Last Post: 05-31-2009, 08:25 AM
  5. LeoVince GPpro for RSV4
    By Priest in forum 2010-2018 RSV4 - All Variants
    Last Post: 04-04-2009, 05:13 AM
