Page 1 of 4 123 ... LastLast
Results 1 to 15 of 55
Thread: Power Distribution Block
    Oct 2011
    Oxfordshire UK
    Hi All
    I have made a power distribution block for my Caponord.
    Its nice and small 50x50x25mm and fits on top of the rear coils under the seat.
    I am running my heated grips, Sat nav & Led running lights from it.
    I had seen a few other power distribution products on the internet but thought them very over priced and on the large side so went off and made my own.
    The screw terminals are rated to 15amps but look like they could take a lot more.
    The other terminal is a Wago cage clamp connector and each teminal is rated to 16amps
    I went for this type of connector as they are easy to terminate to and just require the wire stripped and a terminal screw driver to push the cage clamp open.
    Then just insert the wire and your done.
    They will not vibrate loose and take 28AWG to 12AWG wire sizes.
    A great connector!!
    http://www.wago.com/infomaterial/pdf/51184677.pdf
    The PCB has been potted into the box and is safe from the elements.
    And comes with a lid that can be taped on for extra protection from other objects.
    I am hoping others will like and if interested go to full production and make some more.
    I think it a good alternative to the others I have seen with over inflated amp rating of 30 to 60amps!!!
    Last edited by beasthonda; 12-10-2013 at 12:55 PM. Reason: Added PDF Link about Wago Cage Clamp
    May 2012
    Norton In Hales Shropshire
    Looks really tidy and all the bits and bobs go to one terminal. Will it have a switched live so the the battery isn't flattened if you leave the grips on when you stop.
    Oct 2011
    Oxfordshire UK
    I have wired mine to a relay so it all turns off with the ignition.
    May 2012
    Nice, I'd go for one of those.
    apriliaforum expert timcrasher's Avatar
    Jul 2007
    Feering, Essex
    Thanks a nice, tidy little solution.
    Anyone would think you did this sort of thing for a living
    http://www.youtube.com/user/timcrasher
    http://timcrasher.blogspot.com
    2001 Aprilia Caponord: gone but not forgotten
    1997 Caterham Supersport: The low flying bananaGone up in flames!
    2016 Ducati Multistrad DVT ( or should that be PMT )
    Apr 2007
    Melksham, Wiltshire, UK
    Quote Originally Posted by Saffa Gaz View Post
    Very subtle Gaz ....i know where your going with this...
    (2003 Infinity Blue Capo) - Leo Vince x3 Cans/K&N Air filter/Snorkle-less/Catfish Map/ZX-6R FH016 Mosphet Rectifier/Front Coils re-located/Metal Fuel CRC Fixings/Brown Connector-less/Hyperpro Springs F&R/Rear Hugger/R&G Heated Grips/Krauser Alloy Panniers/Givi G45 Box/BMW GS1150 HandGuards with Touratech Extensions/Kawasaki Z1000 Mirrors/CREE LED's/Wilks Raid Rep Sump Guard & aprilia Crash Bars + Lots of Stickers..
    (2000 RSV Mille Gen 1) Moto GP Rep ..
    (2004 BMW R1150 RT) Bigger touring screen, headlight protector & aftermarket reflective decals ..
    (1990 Kawasaki ZZ-R 1100C1) Remus Innovation S/S Full System, Double Bubble Screen, ZXR750 full lift Carbtops & RenTec rack ..
    apriliaforum Member shi_bumi's Avatar
    Oct 2012
    Turkey
    I got ashamed of my DC bus bar after i see your unit
    "I'm not sure whether I'm an actor who races or a racer who acts." Steve McQueen
    Jun 2009
    oldham uk and soon gibraltar
    Dare we say gb
    May 2012
    Quote Originally Posted by haga lout View Post
    Dare we say gb
    I've no idea what that stands for
    Apr 2007
    Ireland
    Beast id have one, things getting messy and this would sort it. Bang up an email add and we sort something off board
    Brum Brum
    Oct 2011
    Oxfordshire UK
    Hi Shi_Bumi
    That is a real peace of work there.
    I hope all your tool are insulated!!
    Apr 2007
    Quote Originally Posted by beasthonda View Post
    Hi Shi_Bumi
    ...might be a few welded screwdrivers
    Oct 2012
    Turkey
    Hi Shi_Bumi
    Yep, but it's not a state-of-art like yours
    Apr 2007
    Quote Originally Posted by shi_bumi View Post
    ...beasthanda is gifted alright...but yours still looks a good effort Shi...
  1. 2001-2002 power differences
    By MSR in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-20-2003, 09:31 AM
  2. US folks, how much power
    By mrvenjer in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-11-2003, 04:13 PM
  3. chip vs. power commander
    By jronmorgan in forum SL1000 Falco Forum (all years)
    Last Post: 07-11-2003, 10:22 AM
  4. Power and Gearing Question?
    By NYCMille in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-08-2003, 10:53 AM
  5. got the power?
    By rissij in forum SL1000 Falco Forum (all years)
    Last Post: 01-31-2003, 09:16 PM
