Results 1 to 5 of 5
Thread: Stage 6 Digital Speedo Fuel Reading/Level Problem HELP !!
    apriliaforum Member max.sr50's Avatar
    Jul 2013
    Birmingham, United Kingdom
    I fitted a stage 6 speedo a while back and got it fitted by an auto electrician, he never wired the fuel level wire up because he said without a resistor the speedo is to sensitive so it thinks the fuel tank is always empty.
    So i am asking, what resistor (ohm) do I need to put between the fuel sensor wire and the speedo wire for it to give an accurate reading?
    Aprilia SR50r 2008 Carb Piaggio Engine. --- SOLD for 850 -- NOW HAVE A KTM DUKE 125 13 PlATE :P
    • Motoforce 50cc Kit
    • Motoforce Adjustable Racing Clutch
    • Motoforce Racing Variator
    • Pedmoto Series 1 Exhaust
    • Stage 6 3g Rollers
    • Stage 6 Digital Speedo
    • TNT Bar Conversion
    • TNT Rear Shock
    • TNT 65mm Jack Up Kit
    • R&G Tail Tidy Kit
    • Malossi Gear Oil
    • Carbon Front Indicators
    • Custom Red Paint Job
    • LED Rear Light
    • Racing Carb
    • Fast Heating All Weather Continental Tyres
    • Ceramic Brakes
    • Iridium Spark Plug
    • RMS Side Stand
    • Alarm/Immobiliser
    • Stealth Mirrors
    Jun 2013
    croatia
    300, 800 ohm
    depending on the clock model you have
    Jul 2013
    I have this one mate http://www.pedparts.co.uk/product/70...hermo-fuel-etc
    I've found the 300 ohm resistors and 800 but theres different watt variations. Like 1/4W and 1/2W but there both 300ohm. What wat resistor will i need mate? Thanks.
    • TNT Rear Shock
    • R&G Tail Tidy Kit
    • Malossi Gear Oil
    • LED Rear Light
    • Racing Carb
    • Ceramic Brakes
    • RMS Side Stand
    • Alarm/Immobiliser
    • Stealth Mirrors
    Jun 2013
    croatia
    just take that type of resistors
    http://upload.wikimedia.org/wikipedi...6/Resistor.jpg
    take few of them they are cheep and you can try them out
    Jun 2017
    Krimea
    Hi. Please say that resistor those needed. I buy that resistor, but that not helped me. Please help me!!!
  1. 2002 Caponord fuel consumption problem. Help!
    By Caponerd in forum 1000cc f.a.q
    Last Post: 01-13-2015, 01:08 PM
  2. Stage 6 Digital Speedo Fuel Problem!!!???
    By max.sr50 in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-30-2013, 05:33 PM
  3. rs 50 speedo cable / drive problem, help
    By adiehorrocks in forum RS50 Technical
    Last Post: 01-19-2009, 06:51 AM
  4. Aprilia Sr50 Fuel Problem-help!!!
    By matth in forum Scarabeo 50, SR50, Mojito 50, Rally, Fly 50
    Last Post: 08-08-2008, 07:15 AM
  5. help please! oil level problem...
    By drift in forum General Motorcycle Talk
    Last Post: 08-01-2006, 02:01 AM
