Results 1 to 15 of 22
Thread: aprilia rsv 1000 tuono 2003 burning oil
    Aug 2013
    Bulgaria
    Hallo i got my Tuono 5 days ago.Very fast and great bike. This is my first V2 bike, But i have a problem for 2 days my oil from MAX gone to MIN.
    thanks
    apriliaforum Member bigbrit71's Avatar
    Oct 2007
    It's dry sump as long as oil in the tube when u start do not worry have a look in the book for the check method
    Aug 2013
    Bulgaria
    yes i know it's with dry sump I check it's the right way
    Aug 2013
    Bulgaria
    i have lots of oil in air filtar and and in the plugs in rear cilynder
    Aug 2012
    Finland
    All rsv tuonos push some oil in the airbox,If you dont clean it up every once in a while it will become a real mess.The oil should be checked after a proper ride,like at least 20min.How much oil shows up is directly related to the temperature(=how thin) the oil is.Ride the bike like in 3-4000rpm,stop and check the level with the engine running and bike upright.
    If its burning oil its most likely the clutch diaphragm,its a easy and relatively cheap repair that most people with some tool knowledge can do.If its not the clutch diaphragm then you most likely have a serious engine issue,but this is very very rare on these bikes.
    Aug 2013
    Bulgaria
    I understand i clean airbox and over 2 days in airbox the same mess.I forgot to say .When i started the bike cold smoked gray over the tailpipe
    thanks for the help
    Try running the oil level a little lower. About half way between low and max.
    Only check the level when engine fully up to operating temperature with bike straight up and either idling or immediately after killing.
    More Here
    Aug 2013
    Bulgaria
    i check the oil every day 3 days everything is good but a last 2 days oil gone extremely fast. may by a big problem i dont know this fucking Bulgaria no parts no service for Italian bike
    Aug 2013
    Bulgaria
    I forgot to say this 5 days bike going very good . No have changes in engine work
    Im sorry for my not good English language
    Aug 2013
    Bulgaria
    Hallo today i put 600ml oil this is crazy HELP
    apriliaforum expert weasel221's Avatar
    Mar 2012
    in my house, on my street in Ohio
    you mean when you start it, no oil is showing on/in the tube?? the 1st month i had my T, i to would always give the bike a quick 'glance' to make sure nuttin's falling off, etc... so, i fire it up, NO OIL SHOWING, SHIT...shut it off, add about 1/2 qt, ahhh, now it's showing, but on the low side...add MORE oil 1/4-1/2 qt...fire it up, shit, now it's over max, tube is filled all the way...it had almost a full gallon of oil by this time...drained some out, etc... when i do my oil changes now, when it's all said and done the bike's got 3.75 qts in it...as long as the motor isn't making $$$$ noises with 'no oil in the tube' there IS oil in the motor...
    rulz, we donn neeeed no steeenkin rulz....
    inside rulz!!
    Aug 2013
    Bulgaria
    You lonna say me , i can drive my T with no oil in the tube and everything is Ok .Have I understood you correctly
    Don't even bother looking at the site tube when the engine is cold. Set the oil level at the end of a ride when fully up to operating temperature. Then you know it is ready for the next ride.
    apriliaforum expert madart's Avatar
    Aug 2011
    Australia
    When the engine is cold, you will see little, if any oil in the tube.
    When the engine is hot (76-80 degrees on the guage), it will be between half way and the full mark.
    This is normal.
    If you keep topping up the oil when it is cold, you will be overfilling it, and you will end up with the smoke you've experienced.
    Aug 2013
    Bulgaria
    I check the oil when the engine is hot. and oil be in the MIN mark.In the begginig i bought a bike with hot engine oil be in the MAX mark .This is my problem.Drive a bike one week ago, and city is mine
  1. FS: 2003 Aprilia RSV 1000 Mille R in CO
    By gts455 in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 12-23-2012, 09:03 AM
  2. FS: Aprilia RSV 1000 Mille 2003
    By jling11 in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 05-21-2012, 09:16 PM
  3. aprilia rsv 1000 carbon parts tuono factory 2003
    By cumpartot69 in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 12-19-2011, 02:40 PM
  4. 2003 Aprilia RSV 1000 only 7862 miles ALWAYS garaged SUPER CLEAN!!!!
    By Fox Fader in forum Aprilia Motorcycles and Scooters for Sale / Wanted
    Last Post: 04-14-2009, 12:21 PM
  5. Aprilia RSV 1000 R Nera
    By rs50nut in forum General Motorcycle Talk
    Last Post: 06-17-2004, 09:01 AM
