Page 1 of 3 123 LastLast
Results 1 to 15 of 41
Thread: Extra Power Points for Accesories
    apriliaforum expert Globalone's Avatar
    Apr 2012
    Tyne & Wear / Lake District
    There is a USB port under the rear seat which is only on with the ignition, it's enough to power/charge a phone when you are on the move
    There is also a switched 12v under the panel behind the clocks for a Sat Nav, cutting the plug off and adding one of these allows you to power a generic type Sat Nav
    If you run a cable to the front of the bike
    S
    Shown to the left of the speedo is one of these from CTEK it is a Battery/ charging indicator and socket/ charger input.
    This comes with longer wires than shown (1.5m) so will run from the battery to the dash, into this you can plug in a charger when the bike is stood for a while or a power lead to power 12v equipment
    One of these from Bluesea can be added in the line from the battery to the CTEK socket.Mine is hidden in the photo by the left handle bar.
    http://www.bluesea.com/products/1016
    This enables me to power stuff in the tank bag (Tablet) and also power the Drift Ghost when it is mounted on the right front indicator stalk
    http://www.apriliaforum.com/forums/s...ality)-charger
    92 Transalp
    97 Transalp
    03 Caponord ETV 1000
    13 Caponord
    13 Tiger XC800
    Gone but not forgotten-- 06 KTM 640 LC4, 11 Dorsoduro 750
    http://s1161.photobucket.com/user/gl...?sort=3&page=0
    Live as if you were to die tomorrow. Learn as if you were to live forever. ------------- Mahatma Gandhi
    apriliaforum expert dsgfh's Avatar
    Nov 2005
    Melbourne
    Thanks Globalone. Great info
    apriliaforum Junkie Mr Pope's Avatar
    Mar 2013
    Isle of Wight, UK
    Nice one dude, keep them coming.
    May 2013
    north yorkshire
    got my heated grips today,took about 20 mins to fit,look decent quality,connectors are behind the clock so very little to dismantle to fit,just remove screen and small panel that fits over back of clocks jobs a goodun
    apriliaforum Member DodgyGeezer's Avatar
    Jul 2013
    Scottish Highlands
    Thanks Globalone. That's helpful. Picked up my bike this afternoon, so very new to me. The manual mentions fuse for GPS, but doesn't mention where connection is.
    Apr 2012
    Connection in under the screen
    Remove screen 4 off bolts
    Remove fake carbon cover 2 off bolts
    Remove next cover that holds top of clocks 2 off bolts
    Find wire with gps socket ( Item 12)
    92 Transalp
    97 Transalp
    13 Caponord
    13 Tiger XC800
    Jul 2013
    Scottish Highlands
    Thanks again Globalone. Off to Mallory now, but will have a look when I get a spare minute!
    apriliaforum Junkie KiwiNinja69's Avatar
    May 2013
    South Australia
    I assume that the item 12 you're referring to is the black plug and not the two white ones?
    Jul 2013
    Scottish Highlands
    Hi Globalone. Just looking at wiring up for Sat Nav, and have found the connector, or at least I think I have. Item 12 in your wiring diagram shows a Blue and Orange/Green, although my wires are Blue and Green. Pic attached. BTW, where did you get the wiring diagram from? Looks useful. Click image for larger version.
    Apr 2012
    Quote Originally Posted by DodgyGeezer View Post
    From a configuration management point you should identify the component by the wire colours as there is no guarantee that the plug colours are the same across the bikes, the one in the photo should pull out a length and looks the same as my GPS one, it should have a thin second colour on the blur wire
    My bike had black (1 off ) for GPS and clear / white (2 off )for heated grips
    If you would like an english wiring diagram send me a pm with an email.
    92 Transalp
    97 Transalp
    13 Caponord
    13 Tiger XC800
    Aug 2013
    Hertford, United Kingdom
    Also of interest is item 14 on the wiring diagram - "Quickshift switch". The Caponord with a QuickShifter; very interesting.......!
    Aug 2013
    Sydney, Australia
    I really, really, really want a quickshifter! I had one on my old bike and I'm now of the belief that every bike should have one.
    Nov 2005
    Melbourne
    For those wondering which plug is what.
    The large black plug at the bottom right is the GPS. This is a switched 12V* Rather than cutting it off, a standard 2-pin plug with some electrical tape to secure it might just do the job. I'll experiment with something like http://www.jaycar.com.au/productView...SUBCATID=991#1 when I get the chance. I just didn't think to measure the pitch when I had it out.
    The matching pair in the middle the Heated Grips. Interestingly these were carrying 12V* when the bike is switched on too, even without grips connected.
    The Blue/Green wires to the left are for the anti-theft LED, if you've got the anti-theft system fitted.
    *Not regulated, so varies with the rest of the charging system.
    Sep 2013
    Sydney, Australia
    Aug 2013
    Wirral, UK
    Quote Originally Posted by fredaroony View Post
    GPS cable with the cover off
    Attachment 232654
    That's a dedicated Tom Tom plug designed to be pulled up behind the screen and used with the dedicated Tom Tom sat nav mount. I cut mine off and used a two way plug in its place and connected my Zumo to it.
  1. Power Valve For Sale???
    By mightymeaty83 in forum RS125 Euro-archive
    Last Post: 07-24-2004, 06:30 PM
  2. Anyone use a Power Jet for the DeLorto?
    By crazekid in forum RS50 Technical
    Last Post: 03-10-2004, 11:25 AM
  3. Power Jet for DeLorto
    By crazekid in forum General Motorcycle Talk
    Last Post: 03-09-2004, 06:56 PM
  4. Power tap for detector
    By Smoke Eater in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 02-26-2004, 06:17 PM
  5. Power Commander for 04 imminent
    By Thunder Factory in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 11-19-2003, 08:14 AM
