Page 4 of 51 FirstFirst ... 2345614 ... LastLast
Results 46 to 60 of 753
Thread: Caponord 1200 Photo Gallery
  1. #46
    Aug 2013
    Hertford, United Kingdom
    Here's a pic of my Caponord (in the best colour - white!) on it's holiday in northern Spain. 4200 miles so far.
    It's been back to the dealer for replacement parts that were damaged when I took delivery (Mirror, bar end weight, rear shock) also to have the washer and pin put in the left hand footrest (missing), cat convert bolt (vibrated loose and fell off), clutch reservoir cap (vibrated loose and fell off).
    Also been back in to the dealer in an effort (failed so far) to cure the appalling surging at 30mph - Sometimes its barely noticeable other times it's virtually unrideable in traffic (Paris, 40 deg C) - and the snatchy throttle. B******d Euro 3 emmisions!!$"! Map update from Aprilia did diddly squat for the problem, perhaps the new "altitude/3000rpm" update will cure it, but I won't be holding my breath!
    BSD Performance are going to work on it in a few weeks to see if they can remove the closed loop that's causing it, with the Rexxer ECU remapping gizmo (see the Dorsoduro/Shiver forums, they have the same problems). If they can't then I'll fit a couple Fatducs to it and see if that does any good.
  2. #47
    apriliaforum Junkie KiwiNinja69's Avatar
    May 2013
    South Australia
    The new mapping definitely helps Chris, not 100% but maybe 50-75% better.
  3. #48
    apriliaforum prov-nov sanausbe's Avatar
    Sep 2012
    Istanbul
    Fresh in the shop...
    We have added a topcase for the city. As you probably know, it is made by Shad. I couldn't resist for putting the Arrow, when I see it. They have made an incredible discount, so I have added it.
    Chassis number ended by 18. The base version. The last mapping on the PADS is loaded.
    S.
  4. #49
    apriliaforum expert dsgfh's Avatar
    Nov 2005
    Melbourne
    A few pics of my faithful steed.
  5. #50
    Sep 2012
    Istanbul
    Very nice pictures, is it easy to put the R&G Racing radiator protectors?
    S.
  6. #51
    Nov 2005
    Melbourne
    Quote Originally Posted by sanausbe View Post
    S.
    Thanks. Borrowed my missus Sony RX100 to snap a few pics since I hadn't taken any decent ones for here or facebook since getting the bike.
    On the radiator guard, it's one bolt at the bottom & 3-4 cable ties to secure. Took a bit of faffing around & a set of pliers to route a couple of the cable ties, so maybe 3/4 of an hour all up including cutting & sticking all the spacer foam to the edges of the radiator while I watched the telly.
  7. #52
    apriliaforum newb boscobiati's Avatar
    May 2012
    Germany
    Here are a picture of my Caponord, at a tour in france(vosges) with my friend on a MS
  8. #53
    apriliaforum expert keithc's Avatar
    May 2007
    Melksham, Wiltshire, England
    OK so one of you has ADD, the other has MS.
    Keith C
    1982 GL1100 Goldwing
    2006 Suzuki Vstrom 1000GT
    2009 Dorsoduro
    2013 Caponord (from 28/9/13)
    https://www.fuelly.com/driver/mzride...ord?fu=6456444
  9. #54
    apriliaforum Junkie Mr Pope's Avatar
    Mar 2013
    Isle of Wight, UK
  10. #55
    Nov 2005
    Melbourne
    Did 300km through the hills with a mate on the weekend. You've got to hand it to the Germans for fit & finish, but the Italians just build engines that I'm passionate about.
  11. #56
    Mar 2013
    Isle of Wight, UK
    Finish may be good on the tractor but, man, is it fugly...
  12. #57
    May 2007
    Had a test ride on one last Saturday and its a good ride too. Then again so was Yoko Ono apperently
    Keith C
    2009 Dorsoduro
  13. #58
    apriliaforum Junkie kadracing's Avatar
    Jul 2010
    australia
    Quote Originally Posted by dsgfh View Post
    Hey mate , where did you get the radiator gaurds from
  14. #59
    Nov 2005
    Melbourne
  15. #60
    Jul 2010
    australia
    Thanks mate. I contacted Rad Guard this arvo. they want to make them , but cant get a bike , so I may go to Coffs in a few weeks and let them take some measurements.
  1. RST1000 Futura Photo Gallery
    By FuturaDuck in forum RST1000 Futura (all years)
    Last Post: 07-01-2018, 06:39 PM
  2. RSV1000 Mille, Mille R & Mille SP (1998-2003) Photo Gallery
    By GanjamanUSS in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 06-12-2018, 02:05 PM
  3. Dorsoduro 1200 Photo Gallery
    By Chriz75 in forum 2011-2012 Dorsoduro 1200
    Last Post: 04-23-2018, 12:46 PM
  4. Photo gallery
    Last Post: 06-28-2004, 04:01 PM
  5. Photo Gallery
    By KissMyRs in forum RS125 Euro-archive
    Last Post: 01-31-2004, 03:01 PM
