Page 1 of 14 12311 ... LastLast
Results 1 to 15 of 210
Thread: Coolant manifold recall - finally
    May 2013
    Johannesburg
    Exclamation Coolant manifold recall - finally
    Just got a call from my dealer, Aprilia have issued a recall for the faulty manifold batch, mine will be getting replaced
    Not sure if the rest of the world has gotten this yet, if not you probably will shortly
    Mar 2013
    Dania, FL
    Nice!......I about freaked yesterday, was riding and at a light and saw my temp shoot up to 224 degrees.....said to myself "welp, this is it, when I stop its all gonna be over"........but nothing happened, not sure if mines one of the faulty ones or not.
    2012 Aprilia Tuono V4 APRC
    2004 Honda VFR800 (sold)
    2010 Yamaha FJR (sold)
    apriliaforum expert PRC001's Avatar
    Feb 2013
    Cape Town, South Africa
    Quote Originally Posted by hdp View Post
    Hi hdp
    do you know the range of chassis numbers/engine numbers? Would rather go to my dealer fully armed with info Thanks
    Aug 2011
    Italia
    I have cheched twice with my dealer and mine is a 2011 and not in the list . Good from on side , bad on the other, since i'll have to pay the labour for the metal replacement maybe i could be able to replace it by myself but i really dont like that f@@@bleep clip on the tb and a little voice inside keeps telling " don't even try this at home " and usually when i don't listen to this voice then i do regret
    apriliaforum Junkie Vehicle 1's Avatar
    Jul 2012
    Minneapolis, MN
    About time!
    Thank god I didn't end up having to pay for getting my billet one in, ended up working out under warranty.
    Hyper, if you end up getting on the list, check out my comments here, just bring it in and try to get them to swap it. Don't call ahead to check. The lower on the totem pole you go talk to, the more chances you have of sneaking it in...
    12' Tuono V4
    04' 636
    Apr 2012
    England
    If it is a faulty batch of parts, then older models should have nothing to worry about as there doesn't seem to have been any issues with RSV4s until recently, and I can't belive they use a different part. However, I may have just temped fate with my 2011 Tuono now............. oops!!
    Aug 2011
    Italia
    Quote Originally Posted by Vehicle 1 View Post
    About time!
    Yes i already read your experience and that's why i was hoping to be in the list
    Oct 2012
    Horsham, UK
    From reading the forums it seems mostly 2012 models. Which mine is... If anyone in the UK hears anything about this recall then please pipe up. I checked the VOSA website and nothing shows up since the RSV4 engine failures:
    http://www.vosa.gov.uk/vosa/apps/recalls/default.asp
    May 2013
    Johannesburg
    Quote Originally Posted by PRC001 View Post
    Hi hdp
    Sorry PRC not sure, they just phoned and said my bike was part of the affected batch. i will try find out tomorrow
    Feb 2013
    May 2013
    Cumbria
    Recall
    Quote Originally Posted by RobertyBob View Post
    I spoke to Fowlers of Bristol ( nb NOT my local dealer ) on another matter, when i gave them my chasis number-They told me my bike had a recall on it for the manifold. Checked with my local dealer and they confirmed. My part will be fitted under warranty next week. My bike is a 2011 Tuono v4 APRC, by the way.
    apriliaforum newb ForAiur's Avatar
    Mar 2013
    Canada
    FYI, I have a 2013 Tuono and its not affected by this recall.
    Feb 2013
    houston
    twice now (once at 600 mile and once at 3500 mile) i've had to top off my coolant. i dont know where it goes but it does not leak when stopped. its almost as if it just burns off during riding? but has dropped from full mark to low mark in the white plastic reservoir twice now.
    is what i'm experiencing normal? or is this a starting sign of this coolant manifold issue?
    thanks for any help!
    FYI: i have a 2012 APRC model
    apriliaforum expert stinky's Avatar
    Somewhere in the 626
    I've lost a little coolant from the hose connection to the radiator on the left side (lower). Enough that after about 2800 miles, the overflow tank was almost empty.
    "The Tuono sounds like a fighter jet made out of biceps!" -Michael Selley
    apriliaforum Junkie ErinC's Avatar
    Mar 2013
    Nashville,TN
    Quote Originally Posted by banky View Post
    Look at the left side of the engine above the stator and make sure you dont have a porous casting. There have been a few bikes that will leak coolant out of the side of the engine case when hot and most of it will evaporate, so it can be easy to miss.
  1. Coolant Manifold Pipe Install
    By Hellgate in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 11-26-2015, 08:51 PM
  2. leak from broken coolant manifold
    By ZR1000A1 in forum 2012-2018 Tuono V4 - All Variants
    Last Post: 06-04-2013, 08:56 PM
  3. anyone know the wiring for the coolant manifold?
    By Ozman2downs in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-14-2008, 06:26 PM
  4. coolant
    By akey1234 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-11-2003, 03:07 PM
  5. Water Wetter vs Glycol Anti-Freeze/Coolant
    By gtoddh in forum SL1000 Falco Forum (all years)
    Last Post: 06-30-2003, 06:39 PM
