Results 1 to 2 of 2
Thread: Will changing gearing mess up my speedo?
    ed apriliaforum com
    Guest
    No, not at all. The speed is taken off the rear brake rotor bolts. You will notice a black electrical sensor right next to the rear brake caliper. This is the speedo pickup. You can run whatever gearing you choose, and still have an accurate speedometer. Just, do not change the brake rotor bolts to a non-ferrous metal like titanium (the speedo wont work)
    Note: Unlike most other bikes, the Aprilia speedometer is very accurate, even at high speeds.
    apriliaforum Junkie bananaman's Avatar
    Isle of Man
    Is the odometer also running from the speedo?
    Just a thought.
    A friend said to check this if I change the gearing as there may be a chance that the milage is affected it it reads it from somewhere else.
  1. Replies: 5
    Last Post: 02-02-2007, 03:30 PM
  2. speedo drive help...
    By D@N in forum RS50 Technical
    Last Post: 05-17-2006, 01:14 PM
  3. is my speedo cable the problem?
    By tony532 in forum RS125 Euro-archive
    Last Post: 03-22-2004, 03:26 PM
  4. Help Changing the Gearing
    By RSVR1 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 12-16-2003, 06:28 AM
  5. Changing gearing
    By JonnyRS50 in forum RS50 Technical
    Last Post: 10-28-2003, 11:03 AM
