Results 1 to 8 of 8
Thread: Anyone on a 520 Conversion ?
    apriliaforum Junkie DownUnderDorso's Avatar
    Jun 2009
    Brisbane, Australia
    Question Anyone on a 520 Conversion ?
    Has anyone done a 520 chain & sprocket conversion yet ? The options look few and far between....
    This is the only explicit kit I can find --> http://www.pbr.it/index.php?option=c...mid=99&lang=en
    There seems to be a lot of 520 options out for the RSV4, Tuono etc so I'm wondering what is compatiable with the Shiver & Dorso. (I've read that there is a slight offset differences on the rear between Aprilias but details are thin...)
    Bike Garage:
    2009 Aprilia Dorsoduro - Mods: Akra Ti/CF cans, LV De-Cat, FatDuc, STM Slipper Clutch (w/ see thru!), Samco Hoses, 520 DID/PBR conv, RSV4-R Factory Forged Rims, Power Pures, Matris Fork Inserts, Factory Shock, Braking SK2 Superlights, ProTaper Bars on billet Tuono risers, DNA Air Filter, 'Big Mouth' Air Box, Gel Seat, Evo-Tech FE, R&G Sliders, Ballastic Battery, Ti Nuts & Bolts, Lightech Alloy Nuts & Bolts, Stompgrip, Factory Carbon F... Kompo-tech Tail fairing, Raptor Ti Supermoto Footpegs, OEM less 27kgs and counting !
    2007 CBR1000RR - Modified Track-Ho. 1000RR.NET "BIKE OF THE MONTH" Winner Feb 2014 >>> http://www.1000rr.net/forums/bike-mo...inner-tcp.html
    apriliaforum expert firemoto's Avatar
    Jul 2011
    Myrtle Beach SC
    From looking at AF1's store page, I have deduced that you can use a kit that fits any 09-12 RSV4, 06-10 and 11-12 Tuono.
    '09 Dorsoduro 750
    '95 Kawasaki ZX-6R "project bike"
    apriliaforum expert tubad56's Avatar
    Dec 2010
    Carlisle Cumbria UK
    Was 1 of the things I talked about with the guy who does my servicin .... its the racin option and saves weight but due to lack of funds have been unable to take the project any further.
    Soz DUD cant give you any info
    2010 Factory DD that I want to make FACTORY Factory
    Shes there ... stands at 22.96kg shed.
    Feb 2012
    Sierra Nevadas
    Quote Originally Posted by firemoto View Post
    I believe that is the case. I used a rear sprocket for the RSV4 on my DD; perfect.
    apriliaforum Junkie kenzo's Avatar
    May 2010
    Belgium
    Any news on this?
    did you order tried the pbr chain set?
    Aprilia Shiver My10
    Pazzo levers, Roads Italia carbon muflers, LV-decat, DNA filter, Matris cartridge set, RBT rear sets, Seat cover, OZ Factory wheels, 15T with 520 chain conversion, Rizoma handlebar.
    Goodie's to follow: ProBolt titanium/alu bolt and nut conversion, Samco Hose set.
    Conclusion: Making a factory Shiver
    Jun 2009
    Brisbane, Australia
    Not yet - but definately on my to do list !
    After a little more research, PBR looks to be the only 520 option with a rear greater than 45T....
    Bike Garage:
    Jul 2016
    New York, N.Y.
    I went with DID 520 chain and a 48T anodized aluminum sprocket on a DD. The bikes performance has changed for the better! Much quicker!
    Aug 2015
    Gilbert, Arizona (USA)
    I went with 15/44 when I swapped to 520 size. Wanted to keep it close to stock gearing but lose as much rotating mass as possible. SuperLite steel rear sprocket weighs about as much as any aluminum I've compared. Bike definitely spins up a bit quicker.
    Fairly good thread about the whole shebang... http://www.apriliaforum.com/forums/s...d.php?t=321550
  1. AFAM 520 conversion ... anyone else?
    By whemmle in forum RSVR and RSVR Factory (2004-2009)
    Last Post: 05-20-2004, 07:14 AM
  2. Anyone on here got the FP chip on an 02 model?
    By deputydog95 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 11-11-2003, 08:50 AM
  3. Anyone on here mountain bikes?
    By KneeDownApriliaBoy in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-09-2003, 08:20 PM
  4. Included maintenance if anyone on the RS50?
    By whipcreamdude in forum RS50 Technical
    Last Post: 05-06-2003, 03:06 PM
