Results 1 to 14 of 14
Thread: New highly rated fork seals for the showa fork
    Sweden, Linköping
    SKF (world known bearing manufacturer (Svenska Kullager Fabriken)) has introduced a new fork seal which has received lots of praise especially from the cross and enduro guys. http://www.skf.com/portal/skf/home/p...ntentId=879358
    Here are some videos:
    http://www.youtube.com/watch?v=y4H_kiWl2jM
    http://blip.tv/slavens-racing/wp-skf...-stock-4943603
    It seems that they are not so easy to find but here and here are at least two companies that stock them for the showa fork.
    When I will find them for Öhlins and when It´s time to replace the fork seals I will for sure test them.
    apriliaforum prov-nov Motophile's Avatar
    Jan 2013
    Central Oregon
    Deefred,
    So I take it our Futuras have a Showa 43 series fork? Or is that the diameter?
    2002 RST1000 Futura - Ash Gray/Black, FPR Mod, Airbox Mod, Factory Racing Billet Slave, SpeedBleeders, Bikemaster Heated Grips, FH020AA Mosfet Rectifier. H-Pipe. Yoshimura Exhaust.
    Sweden, Linköping
    43 is the diameter
    Jan 2013
    Central Oregon
    So if I go out and get Showa 43mm fork seals for a different bike they would work? I noticed the link you shared was for a different moto. I suspect the fork seal is universal as long as it's 43mm and for Showa? Sorry for all the questions. Mine are leaking and I want to make the right purchase and not spend a zillion dollars on OEM part numbers.
    apriliaforum expert Robert Borchert's Avatar
    Feb 2013
    California
    The last links above include one eBay vendor that stocks the 43mm Showa version...and it mentions the aaprilia models.
    Hey, it includes the dust seal as well.
    Bob
    Jan 2013
    Central Oregon
    The SKF ones are definitely nice looking! They make good stuff.
    For the sake of peoples sanity and their wallets I have included below a cheaper alternative to SKF and the EXACT measurement of the Aprilia Showa Version Fork Seals and a link to Amazon for a fantastic price on them.
    Fork Seal Dimensions for Showa Units: 43mm x 54mm x 11mm
    Amazon purchase source Non-SKF:
    http://www.amazon.com/gp/product/B00...productDetails
    PA USA
    My buddy with the KTM Duke is pretty hot to replace his (barely broken in) seals for those. The Duke has huge amount of stiction in front. The Fut's front end is far smoother. Maybe it's just the weight differential.
    I just did my fork oil a month ago. Though our seals won't let the tubes slide quite that easily, with some miles, they will still slide on their own from gravity. Would definitely switch to those SKFs when/if mine leak.
    Jul 2007
    Middletown, CT
    holy hell, 40 bucks for a dust and oil seal? For all the seals I've replaced on all my bikes I've never had stiction as bad as what was shown in that youtube video. And I've never paid more than 45-50 bucks for oil and dust seals, for the set of 4. No way am I spending 80 bucks for seals. At least not for a street bike. If my race bike starts developing some noticeable stiction than maybe but otherwise I'll stick with oe for half the price.
    I'm on the app store! Check out Solitaire: Slide it's free!
    PA USA
    Quote Originally Posted by soofle616 View Post
    For whatever the reason, KTMs seem to be pretty dang tight and in need of this. It takes some serious force to move the front fork off the dime on my Friend's Duke. The Futura is smooth as silk in comparison. Could blame it on spring rate, but the Duke's fork really does feel sticky.
    Jul 2007
    Middletown, CT
    Being something resembling a motard maybe the forks are dirt spec and have tighter seals to prevent contamination?
    PA USA
    Yeah, maybe so.
    Except for the seat height (and maybe the seat) and a relative small tank, there's not much that resembles a dirt bike on that thing. All sorts of nice components and shiny machined alloy.
    Feb 2013
    California
    soofle616,
    Man, fork seals have become crazy expensive over the years. AF1 has these OEMS available for $53.98 a pair, and that's just the oil seals. The dust seals are priced individually for another $36 each.
    If I do a little math, that's $126 for a complete set of seals (4 pieces). These prices are close to ones I see elsewhere.
    Ouch.
    I can't see disassembling the forks, and leaving the old wipers in place.
    Bob
    PA USA
    Quote Originally Posted by Robert Borchert View Post
    soofle616,
    Ouch.
    Bob
    Gots to pay to play!
    Jul 2007
    Middletown, CT
    Wow, never actually looked at the seals for a fut. Done my RS250, mille, and cbr but that was always with racetech stuff so I guess I probably should have said racetech instead of OE. That's freaking crazy.
    Of course now that I say THAT i just checked racetech's site and the seals for the futura are 22 and 35 for the pairs (oil and dust). So still not great but a helluva lot better than oe and cheaper than the new ones.
  1. New Carbon Fiber Dash Panels for the 2004-09 RSVR
    By mini_me in forum Aprilia Parts and Accessories for Sale / Wanted
    Last Post: 12-03-2009, 03:23 PM
  2. Ohlins Supersport valve kit for the Showa forks
    By Essveekay in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 08-05-2009, 02:18 PM
  3. New bit of custom bling for the Futura, or...
    By AzIrish in forum RST1000 Futura (all years)
    Last Post: 03-18-2009, 03:20 PM
  4. Replaced the Showa fork seals a couple of weeks ago
    By anthonyk in forum SL1000 Falco Forum (all years)
    Last Post: 05-04-2008, 08:29 AM
  5. Advice for the new guys
    By Smoke Eater 41 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 07-09-2003, 11:00 PM
