Results 1 to 5 of 5
Thread: Can bad front wheel bearings cause warping brake rotors?
    apriliaforum prov-nov essjae's Avatar
    Sep 2005
    Pacifica, CA
    It's a dumb question, but I'm a little stumped.
    My red Futura's front brakes started pulsing around the same time I got some weird grinding/knocking type vibration in the handle bars. At the time I assumed it was all related to warping rotors.
    Got new EBC rotors, the weird feedback didn't go away and now I've got warping rotors again with only a few hundred miles on them. I took the bike back to the shop and they measured the warp and said that they didn't think they could RMA the rotors since it was so slight. They confirmed the "feedback" and said that there was no safety issue.
    It seems odd that I'd get 2 sets of warped rotors in such a short time (especially for regular road riding, no hard breaking, no racing, no stoppies, etc)
    Any suggestions where to start?
    apriliaforum prov-nov georgeb's Avatar
    Mar 2005
    Scruffy Little City, TN
    The obvious place to start is checking your wheel bearings. Take the front wheel off and check for play and roughness. They should turn smoothly, without a trace of roughness.
    Sep 2005
    Pacifica, CA
    Thanks! Kinda where I thought to start, but I didn't want to pull off the front wheel without a little outside input.
    PA USA
    When you replaced the rotors, did you also replace the pads? If not, it would take longer for the old pads to bed-in to the new rotors. The pads may also have some contamination that's resulting in the pulsing. Did you check the old rotors with a dial gauge to see how far out they really are?
    Not saying you shouldn't check the bearings. Definitely worth your time (and butt) to pull that wheel. But if the new rotors have the same "feel" as the old ones and they measure within spec, I'd also have a look at the pads. You'll have to pull the calipers anyway to remove the wheel. Pop out the pads and make sure the friction material is still bonded securely to back plates and maybe give them a light sanding on a flat surface (thick pice of glass works).
    Sep 2005
    Pacifica, CA
    Brake pads were replaced too.
    Thanks for the info. Looks like I have a new weekend project!
  1. Replies: 13
    Last Post: 07-05-2011, 09:41 PM
  2. Front Wheel Bearing details
    By cherryc in forum ETV1000 CapoNord (2001-2007)
    Last Post: 06-08-2006, 07:26 AM
  3. Front wheel bearings spec?
    By boinovRS in forum RS250
    Last Post: 06-07-2004, 11:57 PM
  4. front wheel bearings
    By djjasoncarroll in forum RS125 Euro-archive
    Last Post: 04-25-2004, 04:48 AM
  5. Nacked front wheel bearings
    By ED2O9 in forum RS125 Euro-archive
    Last Post: 06-15-2003, 03:46 PM
