Results 1 to 11 of 11
Thread: Modify or Reset Code not working for Diagnostics
    Apr 2009
    Hamburg, NJ
    I am able to successfully change or reset my security code on my Tuono V4R. However, when I try to access the Diagnostics on the Menu, I get an "invalid Code" message. I find the Users Guide to be confusing. Can a more experienced user help me out? What am I doing wrong?
    Aug 2011
    Italia
    These are 2 different things. User code is for security ( anti theft of sort of ) , the diagnosis code is another story, is used to check faults , reset service alarm wrench etc. Only dealers have ( at least officially ) this diagnosis code .
    Apr 2009
    Hamburg, NJ
    Thank you Hyper. Do you know if that diagnostics code is the same for everyone or set by the dealer?
    Austin, TX
    diagnostic is the same for everyone.....12412
    user code (immobilizer code) can be set to anything.
    Aug 2011
    Italia
    In other forums this codes have been removed to avoid any problem with warranty claim , that's why I did not write it , anyway I think is better having it available for any occurrence
    How owners knowing the service code would have an effect on warranty I've never really understood? Apart from it allowing you to turn the service icon off it doesn't really allow you to *Do* a lot but it will let the owner identify if there are any error codes showing which at least gives us some idea what might be wrong if they call us from the side of the road.
    Pete
    Professional Goat Burster.
    Austin, TX
    Its also the only way to switch speed units MPH to KMH for all you "weird" countries....someday the USA might go metric.
    That menu is behind the diagnostics menu (where you need that code)
    Aug 2011
    Italia
    If it was a code meant to be known by final users, aprilia should have printed right on the user manual , dont 'u think so?
    Try calling customer service asking for this code as a user ..
    I personally found it useful a couple of times but I've read of someone that did some mess by mistake "disconnecting" the ecu in some menu and finally could not start the bike anymore without dealer intervention.
    Anyway i'm glad it's not a problem here
    apriliaforum expert stinky's Avatar
    Somewhere in the 626
    Which is the option under diagnostics to turn off the wrench? I had service done right before it came on. Is it "reset coupon", "delete errors" or what?
    "The Tuono sounds like a fighter jet made out of biceps!" -Michael Selley
    Check LA weather
    apriliaforum expert telboy39's Avatar
    Aug 2007
    Belfast, Northern Ireland
    According to the owners manual only a dealer / service centre can remove the icon but using the 12412 code and the diagnostic page works under reset coupon.
    "reset coupon" - makes perfect sense lol.
    Thanks, that did the trick.
    Check LA weather
  1. Speedometer not working for Scarabeo 500GT
    By Jelwie in forum Aprilia and Piaggio 500cc
    Last Post: 01-13-2012, 04:52 PM
  2. Service Light - Reset Coupon not working?
    By zslaybaugh in forum 2008-2016 Shiver 750 / Dorsoduro 750
    Last Post: 09-27-2009, 05:54 PM
  3. Solo Seat Complete - Not bad for an afternoon/evenings work!
    By VickersUK in forum RS125 Euro-archive
    Last Post: 07-09-2006, 03:25 AM
  4. **not Work Safe Or Pleasent** But Funny As F**k
    By Falcon in forum RS125 Euro-archive
    Last Post: 09-28-2004, 03:21 AM
  5. Diagnostic Mode - Not working
    By Redlion in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 03-23-2004, 04:18 PM
