Results 1 to 6 of 6
Thread: coolant overflow leaking ?? wtf ??
    Jul 2012
    canuckistan
    This thing has 100 km on the clock and i just got home. I was hearing coolant boiling and the temps was at 104 and the fan running..
    i shut it down and it starts to flow coolant out..è
    what the hell is this ?? bad coolant cap ?? i hope so. i tried to tighten it up but it seems to be fully tight.
    Head gasket??
    what else??
    Jul 2012
    canuckistan
    What am i looking for ? bad quality? My problem is coolant overflow, not a pipe bursting.
    Dec 2008
    Toronto, ON, Canada
    If the coolant boils at 104 C that means the coolant system does not hold the presure. Most likely bad quality cap, but I won't be surprised if it's something else...
    Jul 2012
    canuckistan
    Care to elaborate on the something else ?
    apriliaforum Member standrewscross's Avatar
    Jan 2012
    Melbourne, Australia
    I had these symptoms, it was a faulty radiator cap which wasn't releasing causing a pressure build up in the hoses.
    Fixed under warranty.
  1. Coolant overflow
    By supersonik808 in forum RSV Tuono, Tuono R, Tuono Racing, and Tuono Factory (2002-2005)
    Last Post: 07-21-2008, 09:35 PM
  2. Best way to refill coolant after leak and bleed air out (hose clip broke)
    By Fredbear in forum Tuono 1000 R and Tuono Factory (2006-2010)
    Last Post: 11-07-2007, 12:56 PM
  3. Gas leak, WTF?
    By kmcormick9 in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 08-03-2007, 10:40 PM
  4. coolant overflow
    By Eyeque in forum RSV1000 Mille, Mille R, and Mille SP (1998-2003)
    Last Post: 09-28-2005, 12:14 AM
  5. remove coolant overflow catchtank. how to?
    By ftallner in forum RS250
    Last Post: 01-10-2005, 11:52 AM
