Results 1 to 5 of 5
Thread: Water trap question
    apriliaforum expert Beavinator's Avatar
    Jun 2011
    vancouver bc
    Water trap question
    Hey guys I was just wondering where is the best place to order the barb adapters for the water trap? Thanks
    apriliaforum Junkie Louder North's Avatar
    Nov 2011
    Ottawa, ON Canada
    Quote Originally Posted by Beavinator View Post
    I got my at Home Depot in the plumbing section. Call ahead if you have a choice of stores to go to as they may not all stock the male 1/4 NPT to 5/16 adapter (assuming you have 5/16 fuel injector hose).
    2007 SR 50 Factory Ditech (Morini) 9000 kms
    Buzzetti side stand 03/18/12
    PIAA 'Slim Line' Sports Horn 05/21/2012
    Porter Cable water trap 06/19/12
    ECU completely derestricted ver 2.8.0 (YES! Thanks HGT 08/10/12)
    LV ZX-R 09/10/12
    Motul Scooter Power 2T oil (100% synthetic)
    NGK ZMR7AP spark plug, indexed, gapped to .030
    Malossi Multivar 2000 w. 7 gm rollers, Malossi Special Belt, White contrast spring @ 8000 km 11/12/12
    8mm Mirror Riser Extender 05/12/2013
    Michelin Power Pure tires @ 9000 km 05/18/2013
    90 kph on slight down hill
    Also in the garage: 1987 BMW R80
    apriliaforum expert fapfap's Avatar
    Oct 2010
    Houston, Texas
    A hardware store.
    2009 SR50 Factory - 49cc Piaggio Engine
    Engine:
    ECU derestricted (unknown map)
    AGIP City 2t oil
    +3º key
    NGK 7411 spark plug (CPR8E) .035"
    Husky W/T
    BGM PRO Evo 23mm intake manifold
    Marchald Filter
    Malossi VL13 reed
    HGT fuel reg. (~130psi)
    Transmission:
    6.25 gr Dr. Pulley sliders
    LV red clutch springs
    Malossi green contrast spring
    Exhaust:
    LeoVince ZX-R
    Status:
    220lb rider
    58mph not tucked
    65mph tucked
    both on flats
    F/S : I have a new set of 5.0 gram sliders;
    Jun 2011
    vancouver bc
    I am going to go with this one I think. I have a good idea for a mounting bracket. I will just make a U shaped piece of metal that the top of the trap slides into and I will drill matching holes on each arm of the u that the fittings screw into. First I will mount the upside down u to the bike and then slide the trap in and screw in the air fittings to hold it in place. Hope you guys can understand that lol.
    http://www.avsontheweb.com/product.p...322&bestseller
    May 2010
    San Jose, CA
    Grainger is good option:
    http://www.grainger.com/Grainger/WIL...288?Pid=search
  1. Water Trap question.
    By Rosscofat in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-10-2011, 11:48 AM
  2. Water Trap Question
    By shrubman in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 01-22-2009, 05:44 AM
  3. Another water trap question
    By nedrager in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 12-01-2008, 12:53 PM
  4. water trap questions...doing project today
    By gatsuga in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 09-20-2008, 07:31 AM
  5. Water Trap Question
    By Cotts23 in forum Scarabeo 50 Ditech, SR 50 Ditech, SR Factory
    Last Post: 08-07-2008, 08:46 AM
